#21 (permalink) | |
BANNED
If any application fluid (and 50% rubbing alch is too much- it should be 25% or use an actual commercial fluid) it will evaporate out in a few warm days. Just like how you often have a small bubble under the paint protection film when you pick the car up and once it gets some time in the sun it evaps out. Also alcohol evaps fast. Newman- just makes sure he gives you cast vinyl. If you get calendared sign vinyl your installation will be twice as difficult. I wouldn't even try it with regular vinyl but then again I rarely even stock anything non high perf. since I don't like working with it and am generally doing car stuff anyway. |
#22 (permalink) |
Alarmed & Dangerous
I prefere the interior black look, so I re-trimmed the sills.
#23 (permalink) |
NOT ßANNED!
I'll take two in Hello kitty island adventure please.
#24 (permalink) |
Idle @ 5700rpm
Looks nice! I'd go with silver instead of cutout tho.. :
2005 Saffron Yellow Fed. Lotus Elise [Touring, Sport, Premium and Blackout Pack, Stage 2 Exhaust, Hard/Soft Top] - [Currently @ 6500 Miles] [CF Centre Console, Zoom Eng. CF Rearview Mirror, iTG Cold Air Intake, 55w 8000k HIDs, Engine Dampers, reVerie CF Engine Covers, Raised Rear-Lotus Letters, A/C Bypass Switch] |
#25 (permalink) | |
'08 Mazdaspeed3 |
#27 (permalink) |
POSITIVE!
Vinyl is vinyl.
CF look vinyl is not CF... Too poser-y for me. (Though I'd did consider having some cf covers made...)
2008 Aspen White Exige S240: CF splitter|CF wing|CF diffuser|CF side scoops|CF mirrors|Arquay Titanium|Von-hep delete|Saikou Michi catch can|Cup car airbox|6000K HIDs|Custom short shift|Stan+sector111+ctn shifter mods|vinyl wrapped floorboards|Flat black AC surround & center gusset|Tow hooks|Bootie|Led park & plate lights|Smoked front sidemarkers|DRL delete|Hella Supertones|JVC KDAVX44 head unit|Boyo 420t back up cam. PICS E30GTR Build... too slow... http://www.onyxsyndicate.com/newman |
#28 (permalink) |
BANNED
Wrong.
Certain ones won't work at all for this, and some will work fine. I'd use Oracal 851 or 951 but that's just me. There are different CF vinyls too. From the ultra sh!tty looking printed crap, to the stuff that actually looks real. The later costs about 10 times more, and won't work in this application anyway. ![]() |
#29 (permalink) |
POSITIVE!
I just meant that vinyl is vinyl, in that it's not trying to simulate something it's not.
Even if it was just an aesthetic cover, the only way anything that looks like CF is going on my car is if it really is carbon fiber.
#31 (permalink) |
POSITIVE!
#32 (permalink) |
2005 Ardent Red, Touring
Those ridges are functional foot traction pads and that vinyl would wear out quickly I would think, they are meant to be used for foot traction when getting out of the car, I use them every time I get out of my car, right foot pushes off of the ridges as I lift out to exit.....
"You can run over an insect and know just from the messages coming through the wheel how many legs it had. Was it a beetle? Was it a spider? Hang on......... spider." Jeremy Clarkson - Top Gear |
#33 (permalink) |
Could you make an alum. cover that fits in the channels allowing you a flat surface for the vinyl? Just thinkin' out loud, might make for a better result visually and make for an easier install.
I'm in the bare alum. camp. |
#34 (permalink) | |
POSITIVE!
At least we have an exit strategy...
#37 (permalink) |
Back in the Saddle
Agreed! It's a good thing it's on the passenger side. And... that [nut] cup holder slides in and under the dash, thank goodness.
If nobody ever died doing it, how much fun could it be? |
#38 (permalink) | |
Idle @ 5700rpm
#40 (permalink) |
POSITIVE!
INSTALLED!
Was kind of a pain in the butt. Had to apply it dry, because the contour of the floor made it impossible to squeeze out misted water. I think it looks awesome, still have to see about installing a little graphic. Also wrapped the center gusset, which isn't a gusset at all and is only held in place by 4 plastic tabs... Go figure. ![]() ![]() ![]() ![]() ![]()
