On a slippery slope...
Diffuser detailing?
I've searched and read through the Interior/Exterior forum, no luck. If there is a thread, please point me in that direction.
Stock diffuser is in good shape, except for a couple of what look like watermarks, similar to posts I have seen of using Simple Green on aluminum. I tried Nevr Dull on a test section but that just buffed up the sections where the anodization has been damaged, leaving a shiny spot amongst the rest of the matte finish. Before going bananas and painting the diffuser, wondering if anyone has suggestions on how to correct discolorations on the stock aluminum diffuser?Done a bit of research on the interwebs and looks like best bet is painting/powdercoating the diffuser element, but want to see if there is anything I can do before launching down that route. Cheers, Cap
2005 Nightfall Blue Lotus Elise |
_
I used Plasti-Cote 282 cast aluminum finish on the center section only of my diffuser and it is absolutely impossible to see the difference until your nose is within 6 inches of it.
My Corvette is for sale. |
McLareghini Bugatterrari
If it is something ON the finish... try using a clay bar.
xtn
perfututum futūtor
I had a similar problem with my diffuser ( how do you clean this off? ) and none of the suggestions worked at all to remove the spots.
soft scrub vinegar dawn baking soda WD-40 coke claybar etc I also tried a Mr. Clean Magic Eraser and a few other things. Nothing worked. If you do find something, let us know. |
Yup, same spots, RoadDad (although much less pronounced).
I'll keep looking. Sounds like my biggest problem will be running out of hidden test patches on the diffuser before I find a workable solution. ![]() Edit: xtn missed your post...it appears to be discoloration of the surface coating. Surface feels smooth to the touch so not expecting clay will do much, but heck, i'll give it a go, too.
2005 Nightfall Blue Lotus Elise Last edited by Implosion : 08-09-2009 at 11:51 AM. |
#7 (permalink) |
_
If you want to go crazy, try a green Scotchbrite pad, or Eagle 1 Etching Mag Cleaner. Either will remove excess oxidation (as well as soot), the former mechanically, the latter chemically.
Probably all my previous soot cleaning attempts made the center section turn splotchy white. I did a half-assed job of painting the center, just to see how it would look. The painted area matches the original very closely. The area with the rivets is not painted. Yet.
#8 (permalink) |
Left Lane Assasin
On my black diffuser, I used some engine degreaser on all the under belly panels. I guess my parts washer brush was a bit stiff as it started to take the black paint off the diffuser and make streak marks. Imagine Lotus used a pretty crappy finish/paint when the piece should be powder coated or anodized. Just a great excuse to upgrade to a carbon fiber one.
2007 Exige-All Black and Mean , Factory TouringPak/TrackPak/StarShield/LSD/TractionControl/iPodDock. All stock but not for long.![]() v = square root ((2 * e) / m) |
#10 (permalink) |
Please send me pics
to ciro@cpcardetailing.com as I probably have a very good solution. I just need a visual. I've had tons of success restoring the areas surrounding the exhausts with a few simple things, but I need to know if what I will suggest is for your issue.Thanks, Ciro
CP Car Detailing...http://cpcardetailing.com/lotusdetailing Please feel free to CHECK OUT MY NEW WEBSITE and let me know what you think!! Please feel free to ask me questions on how to keep your Lotus looking gorgeous or for detailing rates!
