Old 02-26-2007, 07:31 AM   #1 (permalink)
pixlpush's Avatar
Images: 124
Difuser & under tray quick release kit, how they holding up?
I did a search on the hanger 111 (available from sector111) quick release kit for the difuser and undertray and found a 2 year old thread from several of you who were about to install the kit. How are they holding up? Any rattle issues? Any broken clips?
I installed the kit yesterday and so far so good. It was a bit of a hassle to install especially removing the stock clips on the sides of the undertray. It seems like it's quite tight and will make pulling the tray and difuser much easier in the future.
2005 Elise, CO, LSS, Hard Top
2006 Mini Cooper S - peper white
1986 BMW E30 325E - 24 Hours of LeMons race turd
The B-Team, 24 Hours of LeMons Race Team
pixlpush is offline   Reply With Quote
Old 02-26-2007, 08:04 AM   #2 (permalink)
Registered abuser
Bman's Avatar
I should get my kit with some other goodies on wed. I agree will make for easier maintenance for the future.
07 Z06
06 CO Exige - ForcedFed 275
05 Ford GT
05 Shelby Cobra (Roush 342RE) SPF#2115
04 Full Race Z06
01 Z06
Bman is offline   Reply With Quote
Old 02-26-2007, 12:40 PM   #3 (permalink)
dwkoski's Avatar
Quick change fastener kit
I've had one of these kits on my S1 since 2002. A hassle to get them adjusted properly and I have had 2 fall off and become lost (in four years.) They are clever and speed removal but are slower to replace than threaded fasteners and I have not installed a kit on the S2 as I have a drive on hoist and can get at the threaded fasteners with an air ratchet which is almost as fast in disassembly and much less fussy in assembly...Dave
dwkoski is offline   Reply With Quote
Old 02-26-2007, 02:19 PM   #4 (permalink)
Ridge Man
Ridgemanron's Avatar
I've ordered two complete kits since mid '05', since
small quantity replacements are not available. I lose
approximately '2 to 4' pieces every few months and
feel that I should have stayed with the oem ones.
Ridgemanron is offline   Reply With Quote
Old 02-26-2007, 02:59 PM   #5 (permalink)
Randy Chase's Avatar
Images: 761
I tried it on my car and removed it. I know Chris Z liked his kit a lot, but I felt I could remove the diffuser almost as fast and with less hassle with the stock fasteners.
Please do not PM me. My box is full. Thanks.
Old 02-26-2007, 03:12 PM   #6 (permalink)
Here's an alternate approach. I bought stainless socket head fasteners. I chucked up the socket heads in the drill press. I held a file against the threaded end while it was running. I put a 45 deg. taper on the ends. Now I can hold the socket end will an allen wrench and pilot them into the holes with ease. I've had the tray off several times now, good improvement for the buck. i didn't invent this, however, they're called pilot screws. Easier to make them than search all day.
MikeW is offline   Reply With Quote
Old 02-26-2007, 04:30 PM   #7 (permalink)
Mike, good idea you could also just get some extra bolts and grind a taper then run a die down to chase the threads..carl
carl is offline   Reply With Quote
Old 02-27-2007, 09:37 AM   #8 (permalink)
Dro
The Original Dro
Dro's Avatar
I also had it and removed it. The fasteners break after awhile and end up being more trouble then they're worth. Also, I think I get less rattle/vibration noise with the standard fasteners.
Dro is offline   Reply With Quote
Old 02-27-2007, 10:19 AM   #9 (permalink)
Registered abuser
Bman's Avatar
Crap, I guess i'l' be sending it back.. Thanks everyone!!
07 Z06
05 Ford GT
04 Full Race Z06
01 Z06
Old 02-27-2007, 10:25 AM   #10 (permalink)
Images: 761
For those who stay with the stock fasteners, if you do this enough, you will keep a couple of tools at hand. One is an 8mm closed end wrench. With this, one can place it over the fastener and spin it quite quickly. This works great for most of the fasteners, including the ones along the front edge. You can get adept at holding it with one finger while spinning it.
Then add an 8mm nut driver to your kit. This works well for those fasteners that do not allow you to spin the wrench. Such as the ones on the very side of the diffuser, or the one between the exhaust tips.
Dropping the diffuser only takes about 5 minutes if I take my time.
Old 03-01-2007, 10:59 AM   #11 (permalink)
TimMullen's Avatar
Images: 19
I prefer my 1/4 inch drive air ratchet. Zzzzzzzziiiiiiiiiippppp!!!!!!!
94 Miata R Package - Black
Old 03-01-2007, 11:31 AM   #12 (permalink)
lancer360's Avatar
JnC showed me this little tool. Makes it very quick to remove and install the bolts.
http://www.lowes.com/lowes/lkn?actio...000&lpage=none
It fits perfectly with the car backed up onto ramps and doesn't have enough torque to break the heads off. I have a different brand, but they are basically the same. The cheap "Task Force" house brand one is only $12.
Thanks JnC!
'05 Lotus Elise Saffron Yellow, Touring, Sport, Stainless Brake Lines, Moroso Oil Pan, RTD Brace
NovaKBS Forumla 600 Powered by Suzuki GSXR
lancer360 is offline   Reply With Quote
Old 03-02-2007, 04:04 AM   #13 (permalink)
LSUFAN's Avatar
Better yet, get a good drill, with 8mm 1/4" drive and a 1/4" driver bit. Instant on and off with no problems. I can even take the two main center bolts off/on with it in seconds.
LSUFAN is offline   Reply With Quote
Old 03-02-2007, 06:09 AM   #14 (permalink)
MyElise's Avatar
Images: 28
I have the kit and have managed to slowly break clips and washers and heads.
However, I really like the fasteners and would like to keep it.
If any of you who have removed the kit would like to sell whatever you have left please sent me a PM. Thanks.
Checker or Wrecker!!!
We're all here because we're not all there.
MyElise is offline   Reply With Quote
Old 03-02-2007, 06:27 AM   #15 (permalink)
lancer360's Avatar
I tried that with by cordless drill, but my ramps don't give me enough room under the car to make it work.
