Old 08-06-2009, 05:30 AM   #1 (permalink)
Drivers window won't go up all the way
There is about a 3/4 inch gap between the soft top and the top of the window when the window is in the up position. Is there a way to adjust the window?
How do I do that? Any tricks to taking the door panel off?
Thank you so much!!!!
Bradley
chiro007 is offline   Reply With Quote
Old 08-06-2009, 06:00 AM   #2 (permalink)
G-200 Driver
kestrel74's Avatar
uberpost. sandsmuseum.com or search
Old 08-06-2009, 06:14 AM   #3 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
Run the window down all the way. Get a flashlight and a #2 philips head screw driver with some length.
Use the screw driver to poke between the rubber seals along the back side of the little triangular bit that the side mirror is mounted to. Use the flashlight to look between the seals. You're looking for the window guide rail. Run your eyes down from the top of that guide rail until you find a philips head screw in it that mounts it to the door. Use the screwdriver to make sure that screw is tight.
Now do the same thing at the back of the door near the push/pull lock.
xtn
Old 08-06-2009, 02:01 PM   #4 (permalink)
Michigan Heavy Metal
ojars's Avatar
I remember doing this a few years ago! These fora helped me with this issue and it has not happened again. Question -- is this normal behaviour or shall we expect to make this adjustment yet again some day?
Storm Titanium, Touring Package (Biscuit), Star Shield -- 01-Jun-05 delivery
mods -- removal of driver's sun shade, Multivex mirrors, CIPA 31000 rear view mirror + adaptor, Battery Tender Plus,
Kumho Ecsta ASX -- 195/50-16 84W and 225/45R-17 94W XL
ojars is offline   Reply With Quote
