Old 01-11-2009, 02:45 PM   #1 (permalink)
bbb
Fitting Exige Scoops on Elise
Hello all,
Need some opinions on whether this will work...
Basically i am trying to install the scoops without having to:
drill a hole in the body,
drill a hole in the fins,
remove the fins....
Referring to my pathetic drawing below, one way i was thinking was to have 3 x L shaped brackets which screw into the back of the scoop using the original mounting screws. The other half of the L bracket has a hole in it for the cable tie/s. The ties then wrap around the original fins.
To install it you would first tightly screw the L bracket to the scoops, then feed the cable tie around the fins and through the L bracket, then tighten the cable ties by accessing them from the behind the fins.
My concerns are....
Will the cable ties be strong enough?
Will the top front of the scoop be held into the body tight enough due to the cable tie running back to the fin??
So if this method is not ideal any other suggestions??
I noticed another member has made a bracket but I don't think it will work for me with fins still in place...
http://www.lotustalk.com/forums/f92/...-scoops-66875/
Thanks
Brendon
bbb is offline   Reply With Quote
Old 01-11-2009, 02:50 PM   #2 (permalink)
lotusforsale's Avatar
Images: 8
Gonna put in the mesh? Generally it glues into the scoop from the inside, before you mount it. If you do that, you won't be able to get in there to do the cable ties.
Even so, you may be able to get all this nice and snug, but not nearly as good a fit as actually bolting them in.
lotusforsale is offline   Reply With Quote
Old 01-11-2009, 03:08 PM   #3 (permalink)
Baysailor's Avatar
Nobuyasu made a single bracket that holds the scoop on the Elise without having to drill holes.
Checkout this post:
Ebay Carbon Exige Scoops
2006 Lotus Elise - Solar Yellow, HT, LSS, LSD/TC, Touring, StarShield, S111 RTDbrace, S111 microMirror, S111 Carpet Buttons, Painted A/C Surround, CF Center Console, Nitron S/A, Tempest BAB26-12 AGM Battery, Fujita Intake, Top Speed Pro 1 Exhaust, 4Tress Harness Bar, 6000k 35w HID kit, Moroso Oil Pan, Plinthless front clam, Team Dynamics Pro Race 1.2 Wheels w/ RE01-R's for street use, Heater Core By-Pass, Shifter Reinforcement, LETSLA v2 Shift Kit
Baysailor is offline   Reply With Quote
Old 01-11-2009, 03:17 PM   #4 (permalink)
bbb
The mesh is already attached...i think by removing the wheel well liners i can access the ties from the back.
Old 01-11-2009, 03:19 PM   #5 (permalink)
bbb
Yeah thats what i had linked to and thought would not work for me as I wanted to leave the fins in. I think that may be my best option though. Remove my fins and make a bracket like his...
Checkout this post:
Old 01-11-2009, 03:22 PM   #6 (permalink)
Baysailor's Avatar
Ha... sorry about that. I didn't read your entire post.
Old 01-11-2009, 11:02 PM   #7 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
there's a thread floating around here that shows how someone made the brackets from Al or something...
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 01-12-2009, 04:59 AM   #8 (permalink)
Images: 8
That thread involves drilling both into the body and into the fins, both of which the OP wants to avoid.
Old 01-12-2009, 05:39 PM   #9 (permalink)
Love is More
Whiskey's Avatar
Drill and be done.
I presume you have seen my install about the side ducts. Drilling gives you the best means for attachment. It may seem scary to drill, but who cares. These scoops will be on the car when you eventually decide to sell the vehicle. Do you really expect to ever remove the side scoops? Make an install that will be structurally sound for the next owner as well. I do not worry about my installation moving at any speed, considering the pressure of the location. It's an air intake under a lot of force and the lower factory bracket is quite nice.
Elise: My process of adding Exige side scoops
Will
WTB: Elise Hardtop with Hardware - Storm Ti. (Color Code B121) Please send PM
Elise: My process of adding exige side scoops (+ Front Mesh)
| 2005 Lotus Elise : Sport Pack : Biscuit Touring Pack : Storm Ti | BWR Supercharger | Exige Side ducts and front mesh | LETSLA Short Shifter (ordered) |
Whiskey is offline   Reply With Quote
Old 01-12-2009, 08:10 PM   #10 (permalink)
bbb
Well i have decided to make brackets that drill into the original fins instead. When i took the original fins out i didnt like the hole that was left above the scoops when you open the door :S
Originally Posted by Whiskey View Post
Drill and be done.
