Form and Function
Front access panel adjustment for front alarm sensor
I have a 2005 Elise that had the front clam replaced as well as Exige mesh.
After repair, I noticed that when engaging the alarm the front sensor was not pressed down by the left front access panel, thus causing a continuous buzzing sound. Problem is with Exige mesh, you can't take the front access panel off completely....I can unscrew the left part of the access panel to lift it up, but I'm trying to figure out a way to adjust the access panel so that it comes down enough to press on the front sensor (so as not to trigger the alarm)....
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
#2 (permalink) | |
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior. |
You have a PM.
Form and Function
SCC did the work and replaced with an Elise calm with Exige mesh...but it seems the way the Exige mesh was placed at the middle part is it is glued?
I'm not too sure how to bend the access panel to straighten it out - it seems the middle part bows too high? - thus not pressing on the sensor....I don't want to break the access panel by bending it...
#5 (permalink) | |
#6 (permalink) | |
Alarmed & Dangerous
Just glue a spacer on the panel where the switch contacts.
#7 (permalink) |
Form and Function
my thoughts exactly...but spacer of what material?...double sided tape?
