Old 12-01-2008, 02:05 PM   #1 (permalink)
CrusaderTBC's Avatar
Front license plate bracket.. again..
I've used up 2 BWR front license plate mounting bracket in the last 4 months. I like the BWR brackets, but both of them have snapped off just under the bolt mount. I guess there's a lot of stress there due to the bracket being push-pulled back and forth from the impacts to the license plate.
Before I buy yet another BWR bracket, does anyone have alternative suggestions for a front license plate mount?
07 Arctic Silver Exige S
00 Raven Black Audi TT
CrusaderTBC is offline   Reply With Quote
Old 12-01-2008, 02:14 PM   #2 (permalink)
Chris Mackey's Avatar
Build your own with the tow hook. I used some scrap aluminum. It just rides around in the trunk. I figure when I get pulled over, I'll BS and put it on, hope for the best.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
Chris Mackey is offline   Reply With Quote
Old 12-12-2008, 11:32 PM   #3 (permalink)
(.V.)
Ripple's Avatar
I used a rail tie. It was cheap and pretty easy to do (took about 10 minutes):
Front License Plate Bracket using a Rail Tie
Ripple is offline   Reply With Quote
Old 12-13-2008, 01:36 AM   #4 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
So far my solution (Front License Plate Bracket) is holding up well. I've replaced the M8 bolt with the Sector 111 front tow hook... easy to install or remove without tools. The plate frame has bottomed numerous times without damaging the mount or the bracket.
Old 12-13-2008, 05:23 AM   #5 (permalink)
fly on the wall
elise24fps's Avatar
Again?
For 2 years, I ran with pic 1; Scanned copy of plate, reduced 15%, printed on glossy professional photo paper, trimmed, laminated, double sided tape.
Then last summer was hassled twice in one month, but no tickets just warnings. So made bracket in pic 2; Aluminum upside down T, bent in two places, but it cracked so added reinforcement, long bolt, washer, spacer, foam rubber between plate and body. The laminated copy is still behind the real plate.
Ian
06 Elise BRiGit / 08 Brawn Accord V6 / 06 PT Tom Cruiser Ragtop... today
73 Europa TCS / 67 Europa S1 / 68 Europa S2 / 64 Seven S2 / 70 Citroen DS21 / 67 Mini Cooper S / 59 Imperial... yesterday
elise24fps is offline   Reply With Quote
Old 07-01-2009, 01:31 PM   #6 (permalink)
jpkeyzer's Avatar
Awesome bracket!
elise24fps - I really like what you did here!
PM sent.
jpkeyzer is offline   Reply With Quote
Old 07-01-2009, 04:44 PM   #7 (permalink)
Elise Driver
kmt63's Avatar
Images: 2
i mounted mine in the center of the windshield.i tapped the edges with gaffers tape.used 2 suction cups for the top 2 holes.the plate slides down between the dash and windshield so it does not block my view.i just could not find a way to mount it to the front of the car that i liked.
rls west~nci motor sports fabrication
kmt63 is offline   Reply With Quote
