LinkBack (1) | Thread Tools | Search this Thread | Display Modes |
#42 (permalink) |
Thanks for the buying advice. I would only use it to polish away the spider-webbing that has been in the finish since new. I've never had anyone criticize the finish; in fact, I get plenty of compliments on the shine thanks to Zaino, but I know it's not perfect (factory finish).
#43 (permalink) |
Rotary Refugee #2
Zaino pretty much doesn't even address "polishing".
Like Todd said, if the paint is already in good shape (no swirls) just claying the car and using Zaino is sufficient. If you have swirls, you must polish. To polish correctly, you should use the Porter Cable random orbit buffer. |
#44 (permalink) | |
call me robbie.
Q: Can I use an orbital polisher to apply/remove Zaino polish? A: Yes, you can use an orbital to apply Zaino Z-2, Z-3, or Z-5. I don't recommend it because you waste too much polish that way. The pad on an eleven inch polisher can absorb almost enough polish to coat your entire vehicle. Each time you use an orbital to apply Zaino polish, you are probably wasting as much polish, if not more than you actually applied to the car. Zaino polish applies easily by hand, especially if you dampen the applicator pad with water and spritz it with Z-6 before applying it. If you use an orbital to remove the residue, you should place a white, 100% cotton towel between the pad and the paint, and keep it turned and refolded often so that you are removing the residue with a clean section of towel all the time. Note: A single orbital pad WILL NOT remove the polish residue from an entire vehicle. You will have smears if you don't use a towel and turn and refold it frequently.
'06 Exige - Aspen White [sold] and living like no one else! |
#45 (permalink) | |
Rotary Refugee #2
The confusion arises from the fact that Zaino calls their SEALANT a "polish", which it is not. Polish (also called compounds or polishing compounds) has differing degrees of abrasives in them. Zaino has NO abrasives. And I agree 100% with the idea that the Zaino SEALANTS should be applied by hand! ![]() |
#46 (permalink) | |
call me robbie.
#48 (permalink) |
Registered Shmoozer
Yeah this is a common issue. People - even professionals - mix up the terms "polish" and "wax", when they're very different animals. And then there's "glaze", another term that seems to be used somewhat interchangeably for "wax".
I've got a question for some of the pros or semi-pros out there: any recommendations to make the Arctic Silver on my Elise "pop" ? There are very few swirl-marks or other problems with the paint, I keep it clean and covered pretty religiously. Right now, I'm still using the products that I started with when I got the car new in '05 - Klasse AIO topped off with a coat or two of P21S pure carnauba paste wax. I haven't yet gotten into the Zaino products...but I wouldn't mind giving it a shot if it sounds like there'd be a noticeable improvement. Thanks in advance for any rec's. Also, one of the very few times that I let someone else wash my Elise (at a dealership after an extensive stay), and they screw it up by letting water droplets stand on the Starshield on the front of the car, on a very hot day Yes, I knew right away what they'd done but by then I just wanted my car back. It's not readily apparent to a "nonfanatic", but I sure see it, esp. at the right angle etc. Anyway, has anyone had any luck polishing this kind of thing out of there clear bra material ?
Covered in Brandy and Lard Last edited by mikester : 08-31-2007 at 01:43 PM. |
#49 (permalink) | |
A compound or polish is really an abbrasive material used to remove small amounts of paint and burnish it to a high gloss... A glaze is an oil or arylic based layer designed to "fill" in imperfections and add gloss A sealant is the LSP (last step product) designed to seal in or protect the finish. A wax is natural/while a sealant is synthetic. Zaino Z5pro and Zaino Z2pro "polishes" are actually sealants. Zaino does make a real polish, called Z-PC fusion, for paint correction. Meguiars calls is step two a "Polish" but it is really a glaze. Meguiars orginally came from the furniture industry, where polish has a different meaning, like wood polish or shoe polish. Oils to make the object look better. Meguiars calls its polishes "cleaners". The confunsion is among the different companies using mixed terminology. |
#50 (permalink) | ||
Rotary Refugee #2
The P21S will probably give a bit of a deeper look and wetness to the paint though. What you could do is try Zaino next time you detail your car. If you decide you still prefer the look of the P21S, you can just apply that over the Zaino (once it cures). This will give you the Carnauba wax look, with the Zaino protection underneath. Quote:
LinkBacks (?)
LinkBack to this Thread: http://www.lotustalk.com/forums/f92/full-zaino-detail-midnight-blue-lotus-polished-zainoed-perfection-44478/
| Posted By | For | Type | Date | |
| Using the Porter Cable 7424 Car Polisher - Autopia.org | This thread | Refback | 04-27-2008 02:45 PM | |
| Display Modes | |
