Help! How to remove harness bar in Exige S?
Hi folks
I'm installing my Kenwood sub/amp onto the rear panel today. I need to remove the rear panel to do so. Thus, I need to remove the harness bar. The vBulletin forums never allow one to search for 3-letter words, so I cannot search for harness "bar". My searches have come up with nothing about this. How do you remove the harness bar? I know I read somewhere that you unbolt both ends, slide it to one side (without hitting the clam) and then slide it out of the panel. Then the panel just comes right out after a few screws(hopefully). The only bolt I find for the factory harness bar seems to be INSIDE the bar...each end of the bar has a "T". The bolt seems to be inside the "T", like this: (warning crude drawing approaching) (rear) -------------------| <---bolt in here, head is exposed at rear How am I supposed to get to this bolt? I can't get a tool in there, unless I'm missing something. Is this the right bolt? Can I remove the speaker "shroud" to gain better access? This plastic "shroud" seems to be riveted in and not removable. Thanks in advance. I'm mid-install and can't continue until I get this info. I'll keep tinkering but would have to have to put the seats back in and start over another day.
-Smoky '07 Exige S, Chrome Orange, Track/Touring, LSD, Starshield, S111 Ultra Discs f/r |
#2 (permalink) | |
Ok, I found this from CodyMac:
Starting to wonder if this is worth the surmounting effort. I mean, I like this little Kenwood KSC sub/amp.. it's perfect for our cars. But I don't know if it's good enough to be going through all this. Hopefully someone here has an easier solution, or has found something to work better for themseves. Thanks!
Well, no big deal that no one responded. I gave up. It occured to me that I'm not working on a Firebird..it's a Lotus, and it's stupid to try to do so much modification just to install this little subwoofer that in all likelihood will probably die in a year or two and need replaced (no doubt, with a different install/bolt/wiring layout, even if it is the same product from the same company...like Alpine does).
I managed to get it behind my seat pretty well, realizing (once the seats were out) that the seat has an inset center portion. Installing this sub/amp vertically allows it to sit within this space. I have a piece of foam between the seat and the sub amp, to prevent damage and movement. It's all tight now.
