Help! How to remove harness bar in Exige S?
Hi folks
I'm installing my Kenwood sub/amp onto the rear panel today. I need to remove the rear panel to do so. Thus, I need to remove the harness bar. The vBulletin forums never allow one to search for 3-letter words, so I cannot search for harness "bar". My searches have come up with nothing about this. How do you remove the harness bar? I know I read somewhere that you unbolt both ends, slide it to one side (without hitting the clam) and then slide it out of the panel. Then the panel just comes right out after a few screws(hopefully). The only bolt I find for the factory harness bar seems to be INSIDE the bar...each end of the bar has a "T". The bolt seems to be inside the "T", like this: (warning crude drawing approaching) (rear) -------------------| <---bolt in here, head is exposed at rear How am I supposed to get to this bolt? I can't get a tool in there, unless I'm missing something. Is this the right bolt? Can I remove the speaker "shroud" to gain better access? This plastic "shroud" seems to be riveted in and not removable. Thanks in advance. I'm mid-install and can't continue until I get this info. I'll keep tinkering but would have to have to put the seats back in and start over another day.
-Smoky '07 Exige S, Chrome Orange, Track/Touring, LSD, Starshield, 2Bular 8x24, ACT XTSS Clutch, Fidanza Flywheel, S111 RTD brace, S111 Ultra Discs, rls Intercooler, Goodrich S/S brake lines, Innovative engine mounts, Valentine 1 |
#2 (permalink) | |
Ok, I found this from CodyMac:
Starting to wonder if this is worth the surmounting effort. I mean, I like this little Kenwood KSC sub/amp.. it's perfect for our cars. But I don't know if it's good enough to be going through all this. Hopefully someone here has an easier solution, or has found something to work better for themseves. Thanks!
Well, no big deal that no one responded. I gave up. It occured to me that I'm not working on a Firebird..it's a Lotus, and it's stupid to try to do so much modification just to install this little subwoofer that in all likelihood will probably die in a year or two and need replaced (no doubt, with a different install/bolt/wiring layout, even if it is the same product from the same company...like Alpine does).
I managed to get it behind my seat pretty well, realizing (once the seats were out) that the seat has an inset center portion. Installing this sub/amp vertically allows it to sit within this space. I have a piece of foam between the seat and the sub amp, to prevent damage and movement. It's all tight now.
Exige Prestige
Any updates on this? I too wish to remove my rear plastic panel but the OEM harness bar seems be in the way. I have looked at all the threads I can find about it but I wish there was more illustration about how remove and reinstall the harness bar back into its original location.
'07 Exige S (Storm Titanium) - Gotham 265, Arqray Titanium Double-Tip Exhaust w/ Arqray Sport Cat & Euro Grills, TWR Dry Carbon Cup Roof, LEA Dry Carbon Adjustable Wing, Prototype Composite Dry Carbon Front Spoiler, Reverie Dry Carbon Side Skirts & Dry Carbon Side Scoops, 17's Team Dynamics 1.2G Matte Black Wheels, Painted Bulkhead Panel, Painted Consoles, 6k HID w/ Raybrig JDM blinkers, Cup Car Airbox, RLS IC Pipes, Saikou Michi Catch Can, Rear Camera, Venture Shield Entire Front Clam etc. |
perfututum futūtor
Trendy,
The hardest part is getting to the bolts that fasten the harness bar. Cody's instructions are really the only way to remove the bar aside from removing the rear clam. If you have a copy of the Elise/Exige parts list you will be able to see the way the bar is fastened to the roll bar. If you don't, PM me your email address and sometime tomorrow or Sat I'll email you the picture with detailed instructions on how I get mine in/out.
I still say Lotus must have some sort Keebler-elf designed, magically delicious u-shaped wrench they use to get to those bolts.
#7 (permalink) | |
short angry bloke
To search for a short term, place a plus sign in from of the term and an asterisk after: +bar*
torque (tôrk) n. - an excuse for the lack of momentum. - let's bring back CanAm & Group B! - have you hugged your Exige today? I'm currently working on my performance driving merit badge. There's always somebody faster, sometimes it's me. |
#8 (permalink) |
Blue Wheel Pimp
if any of you no longer want the factory harness bar I'll swap with you. I have a Sector V Force bar, much easier to install and remove. I'm running without a rear panel now so thats not a problem.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development |
#10 (permalink) |
06 S280
I've removed mine three times now. Sector 111 old bar, made just like the factory one.
I put a deep 3/8's 13mm with a swivel on the nut then put the wrench on that. All through the speaker holes. It's not that difficult to remove, now putting back on and getting the holes alligned is a different story. |
#11 (permalink) |
Thx for the search tips guys. I've been using these forums forever now and I still didn't know about that. I did not know wildcards worked. Thats cool.
