Old 10-08-2009, 03:25 PM   #1 (permalink)
06 elise
MNlotus's Avatar
How do I get wax off of this?
when i got my car back from FVMC this spring i got a powdercoated gas cover. they waxed my car before i got it but got wax on the gas cover. after many washes its still there. any ideas? i wanna put this sticker on it to, any ideas of how to get it straight?
2006 Lotus Elise-way too many mods to list (k24 swap planned. 300+whp)
http://www.youtube.com/watch?v=tjIcCsvhWvY
2003 Caterham Super Seven DeDion
http://www.youtube.com/watch?v=Z1ysO...e=channel_page
MNlotus is offline   Reply With Quote
Old 10-08-2009, 03:35 PM   #2 (permalink)
JWA
#33
JWA's Avatar
I'd try Adam's All Purpose Cleaner on it. Should get the wax off without harming the paint.
One warning on that sticker: every one who sees the car will unfailingly ask you what the number mean. My new car had one on it from the previous owner and I had to take it off because it was annoying. Yours being black on black might help.
JWA is offline   Reply With Quote
Old 10-08-2009, 04:04 PM   #3 (permalink)
Seb
<3 QR25DE
Seb's Avatar
Remove it and soak it in vinegar.
Seb is online now   Reply With Quote
Old 10-08-2009, 04:13 PM   #4 (permalink)
Gregbj8's Avatar
I have used this with some success from Griots...
Car Care, Detail Supplies, Garage Organization, Car Accessories - Griot's Garage 800-345-5789
Gregbj8 is offline   Reply With Quote
Old 10-08-2009, 06:34 PM   #5 (permalink)
06 elise
MNlotus's Avatar
alright ill try some of those. any ideas on how to get the sticker on straight
Old 10-08-2009, 07:07 PM   #6 (permalink)
tesprit's Avatar
The best way to get the decal on straight is to make sure the edges of the backing/carrier are square with the lettering. Once you have trimmed it square to the decal, place it with the backing/carrier still in place over the cover and adjust it so it looks straight to you. Take a couple of small pieces of masking tape and use them to temporarily tack the backing/decal in place. Now apply longer pieces of masking tape to the cover just up to but not over the squared edges of the decal backing on at least three sides. You will use these as your alignment guides. Now remove the decal with its backing/carrier still in place from the cover and remove and discard the small pieces of tape still stuck to it. Make sure you are happy with the pieces of masking tape you will be using as your edge guides. Once you are certain everything is lined up the way you want, peel off the paper backing from the decal, spray your soap water (or whatever you are using to allow small adjustments in the placement) on the cover and carefully place the decal/carrier between your pieces of guide tape. Once you have the decal/carrier positioned the way you want, use a roller or squeegee to press the decal lettering into place, then carefully peel back the clear plastic carrier making sure the decal stays in place on the cover. Finish up by removing the tape guide strips.
Old 10-09-2009, 07:08 PM   #7 (permalink)
tmr
ATL
tmr's Avatar
Use Stoner's Trim Shine:
Trim Shine is an easy-to-use, spray-on coating that instantly shines dull or faded plastic, vinyl, and rubber with no wiping or rubbing. Just spray and walk away!
It works great on anything black and will remove the wax.
tmr is offline   Reply With Quote
