Installed APR wing and splitter
I spent the weekend installing an APR wing and splitter. The wing went quickly and was easy to do. Everything fit perfectly, APR did a great job with the kit.
The splitter was a bit more difficult...I had a spoiler on the car already so it had to come off and be joined to the splitter. That went pretty well and after a bit of sanding I got the mating faces consistent and bonded the two parts together so they install as one unit. I used a adhesive known as Plexus to bond the parts as its very strong and needs little surface prep to bond. I was all set to bolt it up when I decided to remove the Starshield so it did not become captive with the unit bolted in place. My Starshield has yellowed so it was due to be replaced anyway. It was cold so I used a heat gun to warm the Starshield just a bit. Unfortunatly it pulled paint with it in several places. It appears the paint did not bond to the primer in these areas as it came up in small sheets with the back of the paint film smooth and glossy. Just a word of caution to anyone planning on removing the film...Be carefull!!! Waiting on the side skirts from APR to complete the Aero portion of the transformation from Wifes car to track car....Very pleased with the quality of the APR parts!!! |
| Sponsored Links | |||
Advertisement | |||
Difflow Diffusers
![]() Join Date: Apr 2008
post pics
Difflow High Performance Diffusers 07' Exige (Polar Blue) - Track Pack/Touring Pack/Stairshield, Stage II Exhaust, Difflow Flat Diffuser |
Plus 1. Also I was told that when ever you remove starshield some paint will come off. That's why I have not removed mine yet
05 Lime Green- To many mods ![]() Pictures of my Car http://www.lotustalk.com/forums/f92/...-inside-89050/ |
STARLIGHT
Pics Pics Pics!
SOLD - 2005 Starlight Black Biscuit Interior // Hard Top // BWR Super Charger // Von Hep Exhaust // Von Hep Rear Delete // Full HS Removed // Cup Box // Manley Mounts // Rota Wheels W/ Toyo R1R's // ForceFed Carbon Fiber Splitter // Carbon Fiber Engine lid cover // Custom side grills // LidBone // JL Audio VR525-CXi Front and Rear // Micro Mirror // Painted interior bits // Bling Buttons // Darth Holder // STRIPESCurrent -- 2007 Audi RS4 // DD -- 2010 Toytoa Tacoma DC-LB |
#7 (permalink) |
I'll shoot a few tonight and post in the AM........Sorry to hear others have suffered the paint peel as well. I was told that patience and slowly pulling it back against itself would yield good results...I was really surprised at the total lack of bond between the paint film and the primer in the areas that pulled away.
I work with fiberglass and coatings all the time and this is clearly a lack of proper surface preperation or contamination prior to the paint being applied. Spent a lot of time cleaning off the adhesive residue that remained in several areas...Now I have to think about applying it again or leaving it off and take my nicks at the track???? Just had my nerw suspension parts shipped from Sector 111 so phase two of the convert a car will begin soon. Looking forward to getting the car out on the track with the new goodies in February. Any suggestions as to set up for the ride height, camber and toe??? Looking for a starting point before I start playing with stuff.... |
#10 (permalink) |
Pics!!!
, Thinking of doing the same setup for my car.
2006 Lotus Elise - Track car in the making - Mods: Lotus Sport ECU, Stage Two Exhaust, Hawk HT-10 2006 Lotus Exige - Mods: Lotus Sport ECU, Stage Two Exhaust, RTV Brace, V2 Arms, Harness Bar, Hawk HT-10 pads - Sold |
#11 (permalink) | |
I spoke with Johnny Lee. He seemed to know the Lotus cars and what fits... |
#13 (permalink) |
I had a Reviere Spoiler on the front which is still there. I bonded the APR Splitter to the spoiler so it would flow into the lines of the car. I did not think the splitter would have fit well without it. I bolted the bonded unit to the underside of the clam and into the frame using the same attachment points Lotus uses on the undertray. It worked out quite well and it does not appear that I will need the support rods that come with the splitter. A few photos...
#15 (permalink) | |
#17 (permalink) | |
Now I just need to get the paint touched up!!! |
#18 (permalink) |
Noways iz sittin outsides
looks great! Is the splitter level to the ground? I've heard adding a splitter to the exige's stock chin spoiler has a bit of an uptilt.
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 Lotus Exige S310 WTC 2 |
#20 (permalink) |
Looks awesome - I have a custom splitter not yet installed. I'm concerned about rubbing. How further out is your splitter extended from the front spoiler and do you have any rubbing/ground clearance issue? Great looking mods!
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
