Instrument Gauges in the Air Vents...
I currently have a boost gauge in one of the center vents. I was considering putting in a oil pressure gauge in the other center vent. This would be a clean easy to see factory look and setup. I am however concerned as to what the A/C system would be like with the two center vents no longer in operation. My question is, does the air flow from our cars A/C system really need four vents becuase of it's volume of output air? I am thinking that the two remaining vents can easily handle to volume of air and not cause any real resistance or backpressure. I would however expect that the air pressure although not as evently dispersed throught the small cabin, would be much stronger coming out of the two available vents. Thus not really being to much of a penalty. What do you guys think? ...Thanks
PS. Maybe someone can close the two center vents and tell me how the two remaining vents did in terms of flow and cooling. Last edited by Lotus F1 : 07-08-2005 at 04:11 PM. |
insert clever title here
I usually have both passenger vents closed, so I see no problem with blocking two vents with gauges.
Freaks come out at night
I put a boost controller and turbo timer in one of the heat/ac vents on my MR2. Back behind the components, I stuffed a piece of foam in the vent blocking off airflow to that one vent. I've had this setup like this for over 3 years without any problems. HTH.
It's kind of hard to see in this pic...just above the headunit. ![]() |
God Save the Mustache!
turn the ac off and take the top off, problem solved
seriously though i think you should be fine with the 2 blocked. different car but my friend's tt had the guages in the middle 2 and only had the far left and far right open and it was fine. |
#7 (permalink) | |
I wouldn't mind an oil pressure and temp guage. I find the Elise's digital temp guage especially hard to read. |
#8 (permalink) | |
ekological; MWR still has my car. ![]() How important would you guys rate the oil temp gauge when you already have a oil pressure gauge. I would think that when you oil pressure drops you can bet that the temp is rising. I am however wondering if you are about to have a bearing failure what you would see first. I would think a rise in temperature would be first and then a drop in pressure. If just using just a pressure gauge it might be too late. Anyone with good experience concerning engine instrument gauges and there relevent importance? |
#11 (permalink) | |
As a tool for preventing catastrophic failure I have my doubts. Firstly a bearing letting go generally happens so quickly no gauge will save you. Secondly you have to be watching the gauge. Thirdly the gauge needs to be accurate and most standard single wire gauges are not that great. My last engine died as a result of a bearing meltdown - see here. First indication was the noise, second indication was me looking at the oil temp gauge and seeing it off the scale, far to late in both cases. If you are going to fit gauges for other than show purposes it must be able to trigger an alarm at a preset level. I've now gone for a SPA dual oil temp/pressure gauge. Firstly it's very accurate, secondly it stores peak values and thirdly it has an alarm and can be used to trigger an external light/audible buzzer to alert you to a problem. For oil starvation situations this is very useful since you're likely to miss a brief fluctuation in oil pressure that is the first indication of potential trouble to come. So gauges can be useful to warn you that you need to fit an oil cooler or that fluctuations in pressure when cornering mean you need to baffle the sump. But they won't generally prevent the failure itself, if you see what I mean. SPA website Last edited by iwilson : 07-09-2005 at 05:03 PM. |
#12 (permalink) |
I had them remove the silver gauge and had them put in the carbon fiber with yellow markings to better match my yellow Elise. Boost and Oil pressure on top and Performance Meter and A/F meter down below.
#15 (permalink) |
Talkin' Loco
Those lower center guages look really cool - to be honest I liked the top guages when they were white faced more than the carbon ones - only because the white ones matched your current guages...
however my car is krypton so obviously I have no taste.. ![]() |
#16 (permalink) |
I also prefer the white ones, they have a "stock" look to them, while the CF/yellow ones look aftermarket and out of place. Now what exactly is "Performance Meter and A/F meter down below."? I dont believe you mentioned these before.
#18 (permalink) | |
please don't hit my car
#19 (permalink) | |
The Performance Meter is the Autometer D-PIC performance meter. It is the only 2 1/16” gauge on the market that has.. Real–Time G’s 0 to 60mph Acceleration Time Capture Peak Acceleration G Forces 60 to 0mph Braking Distance Capture Peak Deceleration G Forces ¼ Mile ET and Speed Capture Peak Acceleration G Forces Reaction Time Horsepower Mode In this way I can see if any changes i may do to the cars suspension, brakes, tires, wheels, power have any effect on the car. No more butt measurements. A/F Meter is an Air/ fuel ratio monitor. |
| Display Modes | |
