2007 Exige S
IQ3 Dash Installed...
Finished the install of my RacePak IQ3 Dash today. Sensors hooked up to it are:
GPS Speed Lat G Accel G Vertical G Lap Timer (Best Lap) Fuel Level Gear Oil Pressure Oil Temp Water Temp Intake Water Temp OEM Post IC Air Temp EGT (Cylinder #4) Boost A/F Ratio (Wideband) Odometer As you can see in pic, need to find out why my Oil Pressure is not reading correct - 168 psi is a little high Think I may have assigned two sensors to the same channel.Now I can finally put the roof back on the car... Rob.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
Dan D
oooh, can't see close-ups!
07 Exige S 265: GG, Track Pack, V1, RV Camera, S111 CF roof and splitter, 4.5-lb Voltphreaks battery, 10-lb Von Hep Exhaust, Green filter, 265 crank hp +/-, Volk TE 37 Wheels, RTDbrace, Scroth 6-point ASM harnesses, Innovative Motor Mounts, Saiku Michi Catch Cans. To come: IC fans, headers, and sport cat. 1955 lbs total weight (est w/tank half full) 05 Elise: Storm Titanium, Sport, Touring, Stage II (SOLD) (May '05 - Sept '06) |
Form and Function
sweet set up! let us know how it works on the track.
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
2007 Exige S
click on "play slideshow" - if your browser is up-to-date it should play pics full screen unless you're blocking the slideshow control.
Next track event will be infineon in Dec Link to RacePak's Web Site
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 11-02-2008 at 08:24 AM. |
Form and Function
robains, I noticed in addition to the IQ3 dash you have the display unit in your radio...is this required? or can you do the data logging on the IQ3 dash alone and then download to a computer?
#7 (permalink) |
2007 Exige S
Fuel level comes from OEM wire into RacePak universal unit and then I calibrate based on voltage vs. real level -- got it pretty darn close. I don't tap into the OEM CanBus at all (level comes direct from wire coming out of the fuel pump cubby area). IQ3 actually has a CanBus and I can tap into OEM analog or digital signals (CanBus).
Radio/Nav was up just because I was listening to music while setting up the dash configuration via my laptop. You can't see in the pic, but there is a RS232 cable in the dash tray that plugs into my laptop and from there I can load the RackPak software and configure the dash. Can also be done using the 2 buttons I added on the side near fuel/trip mile reset, but using the software via laptop is A LOT easier. If you notice a small slot between the RPM shift lights, this is a Secure digital Memory card that is used to log all sensors and lap times etc. -- I currently have a 512MB SD card, but you can use upto 2GB card. RacePak software will also do all the analysis stuff (track maps, segments, etc. etc. etc.). It also has a nice export to TrackVision data for video overlays (I'll demo that later on).
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 11-02-2008 at 11:23 AM. |
