Old 07-08-2007, 09:32 AM   #1 (permalink)
JMA
Love that Lotus
JMA's Avatar
Lights Popping Out
Last night I hit a pothole on the wonderful Golden State Freeway near Gorman (on the way back from Skyvue's Stargazing). Wham! and the left directional light popped out. Second time this happened. Anyone else have this happen? Any way to keep these things in their place? First time was in a parking lot when I lightly bumped the concrete tire stop at 2 mph. That clam must be very flexible.
Jack-'06 Elise BRG
JMA is offline   Reply With Quote
Old 07-08-2007, 09:39 AM   #2 (permalink)
GaryD's Avatar
http://www.elisetalk.com/forums/showthread.php?t=42382
GaryD is offline   Reply With Quote
Old 07-08-2007, 09:42 AM   #3 (permalink)
-30-
ace10's Avatar
Images: 35
a piece (or two) of painters tape will keep the assembly in-place at the track or autoX. probably not so good on the street.
i think there are a bunch of threads with this same complaint and maybe even a solution or two.
2007 Exige S, Storm Ti. Sport, Track and TC.Plus: Multivex Mirrors, S111 Deltabrace, Sparco 6Pt harnesses (w/Ti Dave's Antisub belt mount), I/O Port video mount, Snorkel delete, Shims out, Rearview Mirror delete, 2Bular 7X18, Pagid RS42's, Saiku Michi catch can and, of course, blingy carpet buttons.
08 M-B ML320 cdi, 08 Toyota Tundra SR5 5.7, 06 M-B E320 cdi, 02 Lexus LX470, 97 Bobcat 751C
The Red Pill Ignore Me *Be sure too save your IL before browsing away
ace10 is offline   Reply With Quote
Old 07-08-2007, 11:31 AM   #4 (permalink)
Baysailor's Avatar
I found that on both my clams (original one and a new one I purchased after damaging the first) that my indicator housing didn't "click-in" completely. The little tabs didn't fully catch. I took my dremel and fine tuned the fit by grinding the area on the clam that "catches" the tab. I was able to get a great fit, very positive latch and never have had a problem since. It was a very noticable improvement in the latching. You definitely want to work slowly with this and think about the fitment as you go. Too much and you make your problem worse.
In the event you do go too far with it, you can always build back up any surfaces with some two part epoxy and some additives to thicken it.
2006 Lotus Elise - Solar Yellow, HT, LSS, LSD/TC, Touring, StarShield, S111 RTDbrace, S111 microMirror, S111 Carpet Buttons, Painted A/C Surround, CF Center Console, Nitron S/A, Tempest BAB26-12 AGM Battery, Fujita Intake, Top Speed Pro 1 Exhaust, 4Tress Harness Bar, 6000k 35w HID kit, Moroso Oil Pan, Plinthless front clam, Team Dynamics Pro Race 1.2 Wheels w/ RE01-R's for street use, Heater Core By-Pass, Shifter Reinforcement, LETSLA v2 Shift Kit
Baysailor is offline   Reply With Quote
Old 07-08-2007, 03:25 PM   #5 (permalink)
My passenger side popped out recently while I was on a smooth interstate @ 80 (legal).
I've got a new one but haven't put it in. The old one failed at the front clip. Some of the clip remained so while I had to wait on it's replacement I used plastic coated wire to fasten it to the grill of my Exige. To anchor it I drilled a hole in the part of the tab that remained. It will never come out now and it is easy to remove. The new one can wait on the shelf.
ken
All torque, no traction...Exige S.
Real sports cars don't have A/C!
Ken Wright is offline   Reply With Quote
Old 07-08-2007, 03:31 PM   #6 (permalink)
Probably Lurking
Keeper's Avatar
Yes, the turn signals popping out is a known problem and there is a fix. I'm surprised I don't have the link. I'll post it if I find it before someone else does.
. . . It's a warranty item . . .
. . . possible fix by grinding away some of the clam?!
http://www.elisetalk.com/forums/show...3&postcount=16
. . . Service bulletin info and fix pics:
http://www.elisetalk.com/forums/show...9&postcount=26
. . . OK, that's all I could find searching thread titles for "signal"
I'll add this thread to the uberpost with the next major update.
Keeper is offline   Reply With Quote
Old 07-08-2007, 03:48 PM   #7 (permalink)
Super 7 Owner In Training
EburgE's Avatar
Mine popped out once. Dealer fixed it without hassle.
'05 Lotus Elise
'07 Caterham Seven www.hals7.com
EburgE is offline   Reply With Quote
Old 07-09-2007, 08:53 PM   #8 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
I can't even get mine out on purpose to change the bulb.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 07-11-2007, 07:39 AM   #9 (permalink)
Exige enthusiast...
sandsmuseum's Avatar
Images: 33
miniature bungee cords work better...
This has happened several times to me. I had the light replaced under warranty twice before I decided to do the fix myself.
My first fix is shown here:
http://www.sandsmuseum.com/cars/elis...catorlens.html
Later I just drilled a small hole in the left over tab and hooked one of the small bungee cords into the hole. Then feed the other end into the hole and hook any place handy. Now the lens can be pulled out when needed, just by lifting the front of the lens...
Lotus liked my fix so much they decided to implement something similar in the new front end. They upgraded my design to use an O ring instead of a bungee cord. (I fibbed about Lotus liking my design, but not about Lotus upgrading the design to use an O ring. Can anyone verify this on a new rear bumpered car?)
Edited to add new Lotus design comment
www.sandsmuseum.com
antique coin op repair
mod for the Library on EliseTalk
sandsmuseum is offline   Reply With Quote
Old 07-11-2007, 07:47 AM   #10 (permalink)
Porsche-Pro
perryeyges's Avatar
JMA, it's funny that your avatar shows a car in the corkscrew. I have heard of more than one 996 Porsche that has had a headlight pop out under the torsional flex exerted on the chassis in the corkscrew. When a 996 headlamp assembly pops out it will cost you up to $1,600 to replace the scraped up unit. OUCH!
perryeyges is offline   Reply With Quote
Old 07-11-2007, 08:26 AM   #11 (permalink)
No more cone damage!
Surferjer's Avatar
Mine popped out on a cone direct hit at 60 MPH. I was able to simply pop it back in and haven't had an issue since then. Here's a pic. My daughter is saying "Ummmm, Dad?" nd I'm replying "Shutup Jess, I know!" I completed the run and fixed the light in time for the next run.
1993 MR2 autox car
Old 07-11-2007, 08:47 AM   #12 (permalink)
It's a Lotus
LARRY's Avatar
A small amount of automotive glue/goop is holding mine back in until I next see the dealer.
A little on each side of the turn signal holder, and hold it on there for a few minutes.
Works. Stays put.
2005 Saffron Yellow Elise. Stage II Exhaust. 2007 ProBax seats.
LARRY is offline   Reply With Quote
Old 07-11-2007, 10:39 AM   #13 (permalink)
shay2nak's Avatar
all they got to do is put a screw up there where the access hole is. Unscrew and remove...how easy is that?
Old 07-12-2007, 11:06 AM   #14 (permalink)
JMA
Love that Lotus
JMA's Avatar
Luckily, my Lotus 51 (Formula Ford) didn't have lights at Monterey, or they probably would have popped out. I almost did--what an event, the 1995 Monterey Historics tribute to Lotus. Hope they do it again.
Jack-'06 Elise BRG
Old 08-03-2007, 10:58 PM   #15 (permalink)
AttAkker's Avatar
A truly solid clean - Fix
Both have mine have popped out in just 2 months. I messed with a few ideas, but finally came up with this fix. Here it is
AttAkker
2004 Noble M12 GTO3R, 2006 Maserati Gransport, 1990 Ferrari 348 TS, 2006 Porsche Cayenne Turbo S
AttAkker is offline   Reply With Quote
Old 08-04-2007, 06:31 AM   #16 (permalink)
Baysailor's Avatar
I like the use of the springs, nice idea!
Old 08-04-2007, 06:46 AM   #17 (permalink)
perfututum futūtor
RoadDad's Avatar
how about a very small bunge cord instead of the spring to save weight?
my '07 elise has a small retaining bunge cord traveling cross ways that the clip hooks under before clipping under the clam. Don't know if this is a fix by Lotus or if the earlier models also have this. It holds very tightly and makes it even a bit harder to get the turn signal out.
Me... I don't need to.
Bite me." -Randy
Old 08-04-2007, 03:09 PM   #18 (permalink)
AttAkker's Avatar
The spring weighs practically nothing and it's cleaner than just a bungee IMHO. Also they tend to stretch over time wheras the spring should have long life. Whatever works best for everyone'd taste. I was just offering up what I came up with.
AttAkker
Old 08-05-2007, 10:12 AM   #19 (permalink)
JMA
Love that Lotus
JMA's Avatar
Thanks for all the advice. I took the car back to the dealer and he replaced just the surrounds. Only have about 50 miles on it since then (been out of town), but time will tell. The springs/bungee cords sound good, so may try that if they come out again. Now I carry some black electrical tape and scissors, just in case. Starting to build up a supply of repair items like I do with my 1954 MG TF. Lots of roadside restorations there, too. Thanks again.
Jack-'06 Elise BRG
