Old 01-29-2007, 03:52 PM   #1 (permalink)
What's a registered user?
Žob's Avatar
Made a bracket to fix the roof bulge
Not as extravagant as the one on the Exige or Sport Elise, but it is functional. I took some bar stock aluminum, and bent it into an L. I drilled a small hole for a bolt and nut for the roof side. I took the roof off, and drilled a small hole in it so the bolt would catch and and sit in there. I then drilled a slightly bigger hole on the other side. I removed one of the factory screws that holds the rear roll bar cushion in place, and used a longer screw in my bracket to hold it down. I wrapped the whole piece in black automotive carpet. Simple and functional!
Žob is offline   Reply With Quote
Old 01-29-2007, 04:15 PM   #2 (permalink)
What he say below?
Adam is offline   Reply With Quote
Old 01-29-2007, 05:14 PM   #3 (permalink)
ToYoTa dRiVeR
Imolas54's Avatar
what he said above!
Imolas54 is online now   Reply With Quote
Old 01-29-2007, 05:35 PM   #4 (permalink)
Žob's Avatar
Ok, they are out of focus and badly lit. But you get the idea.
Old 01-29-2007, 05:42 PM   #5 (permalink)
Looks good Rob, so now no whistling air noise at speed on the highway?
Old 01-29-2007, 05:43 PM   #6 (permalink)
Žob's Avatar
I haven't tested, but I assume so. I only had to pull it down a little bit to make that noise go away. This bracket pulled it down as far as the roof would flex.
Old 01-29-2007, 05:46 PM   #7 (permalink)
My next mod,the whistling noise drives me fing mad.
Old 05-27-2007, 07:27 AM   #8 (permalink)
imoz's Avatar
Do you have any pics of how the bracket mounts to the hardtop? I need a solution like this for my Exige. I'm wondering if there is any way to make something like this that clips on without any bolts, but maybe with an adjustment in the bar for tension. Anyway, I think its pretty cool to see these DIY fixes
Thanks,
Joe
2006 Solar Yellow Exige
Touring Pack, Track Pack, Starshield
imoz is offline   Reply With Quote
Old 06-30-2007, 10:20 AM   #9 (permalink)
Meow!!
darkSol's Avatar
+1 need mounting pictures!
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is online now   Reply With Quote
Old 06-30-2007, 10:28 AM   #10 (permalink)
really light stuff
Thomasio's Avatar
What "roof bulge" ?
07 SY Exige S
To Order RLS Product Links
Old 06-30-2007, 11:50 AM   #11 (permalink)
BANNED
SweetDaddyD's Avatar
Images: 2
Hey, I didn't know I had a roof bulge! Don't be pointing out problems I didn't even know I have now! (actually hard top won't be on for months so hopefully I forget to even look by then)
SweetDaddyD is offline   Reply With Quote
Old 06-30-2007, 06:47 PM   #12 (permalink)
Žob's Avatar
All I did was drill a small hole horizontally in the top. In the bracket I used a small machine screw and nut as the catch through the bracket. I use the screw to stick in the hole, and then when you pull the bracket down it pulls the roof down.
Old 06-30-2007, 07:22 PM   #13 (permalink)
Racing/Car Photographer
Yokozuna's Avatar
This looks great! I have an '07 Exige and it has the new center brace. I didn't know about the problem with the hard tops until I saw a post here. If I didn't have the factory fix I would be trying out yours! Nice work!
Name:  exige roof center.jpg
Ben
2002 Miata SE Titanium Gray, 6-speed, Bose 6-CD, Limited Slip (1 of 1491) 2007 CO Exige S, Track Pack, Touring Pack, Limited Slip, Traction Control, Star Shield - Useless Mirror Removed, Multivex Side Mirrors, Lotus Belt Pads, Sector111 Carbon Fiber Front Spoiler, Red Folding Front Tow Hook and Carpet Buttons, Chase Cam Mounts, JVC Everio 60GB HD Camcorder with Sunpak 37mm Wide Angle Lens and SanDisk 8GB MicroSD, 27% 3M Window Tint.
Yokozuna is offline   Reply With Quote
Old 07-01-2007, 01:07 AM   #14 (permalink)
I'm bored...yawn...
shay2nak's Avatar
Is this what is missing from the CF Cup roof just released by Composites? There's a thread up about it. Looks like it's a separate piece we can add to the CF top if need be.
Why did Lotus add this bracket? Sorry if it was posted before.
'07 Lotus Exige S310
'08 Acura TSX 6-speed
support WTC 2!
Old 08-15-2007, 12:44 AM   #15 (permalink)
Has a skinny fetish
uclacyc's Avatar
Images: 25
I think that this is covered by the Lotus warranty. I went to the dealership and told them that I couldn't get the read edge of the top to be flush, which causes a whistling noise, and they said that there's a fix to drill two holes.
For cross reference, see the thread on Hard Top Owners... Need Help NOW! Identify this part please....
uclacyc is offline   Reply With Quote
Old 11-26-2007, 10:16 AM   #16 (permalink)
imoz's Avatar
Has anyone ordered this bracket? I see it is listed on LotusGarage.com as:
27a Clamp Kit, rear retention
SKU: A120V0347S
Do they stock these things? I don't want to order one and wind up waiting 3 months for it...
Old 11-26-2007, 08:33 PM   #17 (permalink)
I'm bored...yawn...
shay2nak's Avatar
FYI, for ya'll. the new Exige S 240 does not have this bracket for the cup roof.
support WTC 2!
Old 06-26-2008, 01:03 PM   #18 (permalink)
Bane's Avatar
Images: 4
Any pictures of the mounting location underneath the trim?
$599 PPE header (INFO)
un-Official LotusTalk Stealth Bulb provider *6* sets in stock!
