Old 10-19-2008, 08:39 PM   #61 (permalink)
Mesh grill guy
Kiowapilot's Avatar
I changed up the design a little. Read the first post for updated info.
2005 Elise "magnetic Blue" Bone stock..... Not for long.
"Fun in the sun..... Lotus Elise." "fun in the sand.....OH-58D Kiowa Warrior."
If the line for most people is right here, I will be hanging out over there--->
Kiowapilot is offline   Reply With Quote
Old 10-24-2008, 01:03 PM   #62 (permalink)
Meow!!
darkSol's Avatar
I received the rear engine mesh "kit" from Kiowapilot (Chris) yesterday.
I installed it earlier today... it took just about 3 hours, most of that was cleaning/preparing the stock lid for installation.
I'll post instructions/impressions later tonight but until then here are a couple teaser pictures:
EDIT: I'll post sometime later this weekend - kiddies are dragging me to a pumpkin patch! Ahhh.
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is offline   Reply With Quote
Old 10-24-2008, 02:14 PM   #63 (permalink)
GG #668
biscoradio's Avatar
Images: 2
Looks good on gg. I eagerly await your instructions / impressions...
biscoradio is offline   Reply With Quote
Old 10-24-2008, 06:24 PM   #64 (permalink)
Mesh grill guy
Kiowapilot's Avatar
Man those look great. I wish I had a set. lol. Glad you like them DarkSol.
Old 10-26-2008, 08:14 AM   #65 (permalink)
Meow!!
darkSol's Avatar
Ok, here are my promised installation notes:
Total installation time, including removing/reinstalling the engine cover was just about 3 hours:
1) 10 minutes to remove the cover
2) 10 minutes to remove (and break into pieces) the stock slats. I have no idea how you would remove the brittle things otherwise. Replacement cost for all four pieces is about $160 (source: LotusGarage).
3) 40 minutes to use a hair dryer / peel back / remove all the stock sticky double sided tape
4) 60 minutes to use Goo Gone and a Scotch green J-cloth to remove all the residue (worst job by far!) My fingers still hurt from this step...
5) 10 minutes to clean up the cover with soap and water / microfiber towel dry
6) 30 minutes to install the mesh grills. I tried all the fastening methods. My findings:
- aluminum rivets will work but are absolutely permanent
- plastic rivets sometimes didn't work sometimes with my rivet gun (couldn't get it to "pull" after repeated racheting).
- xmas fasteners were the best - and were used on all the holes except for the four farthest rear ones
- the stock engine rearmount lid holes were drilled too close to the base (bottom) and the xmas fasteners could not be mounted flush so I used the plastic rivets instead. Now that I think about it I guess a "slice" could be cut from the fastener with side cutters.
7) 20 minutes to reinstall/realign the cover (I hate those damn washers!)
One of the issues I discovered WHICH IS NOT KIOWA's problem whatsoever is that there were a great deal of scratches and small gouges underneath the stock plastic slats - touchup paint WILL be required.
I really like the look but with all the little scratches (and I SUCK at touchup paint) I'm actually considering to have a body shop fill all the 20 holes and repainting the whole cover - and then double sided tape / flexasil the mesh underneath. I don't mind the look of the xmas tree fasteners, plastic rivets and rear plugs but IF I was going to paint the cover anyway...
Here's some pictures!
d.a..v...i....d
Old 10-26-2008, 08:15 AM   #66 (permalink)
Meow!!
darkSol's Avatar
More pictures...
d.a..v...i....d
Old 11-04-2008, 12:30 AM   #67 (permalink)
Love is More
Whiskey's Avatar
Its November!
Any chance to work on the lower front three mesh grills?
Will
WTB: Elise Hardtop with Hardware - Storm Ti. (Color Code B121) Please send PM
Elise: My process of adding exige side scoops (+ Front Mesh)
| 2005 Lotus Elise : Sport Pack : Biscuit Touring Pack : Storm Ti | BWR Supercharger | Exige Side ducts and front mesh | LETSLA Short Shifter (ordered) |
Whiskey is offline   Reply With Quote
Old 11-04-2008, 01:12 AM   #68 (permalink)
Originally Posted by darkSol View Post
More pictures...
David, did you make or buy the mesh for the rear panel (in front of the exhaust)?
2005 Saffron Yellow Elise, Sport/Touring, VF Stg2, 2bular hdr/sport cat, Larini 8", Saikou CC, shifter mods, FF engine damper, ACT/Toda, AFR/oil temp gauges, RTV toelink, Moroso oil pan, AlumDiffuser, ABS splitter, FF spoiler, widened undertray, 5-pt harness, Odyssey battery, Multivex, BWR key
2002 Silver M3, SMG, Ground Control suspension, AP Racing BBK, RAC RS110s --sold--
biodan is offline   Reply With Quote
Old 11-04-2008, 06:11 AM   #69 (permalink)
Meow!!
darkSol's Avatar
As PM'd... check here:
Challenger Grill
d.a..v...i....d
Old 11-04-2008, 10:56 AM   #70 (permalink)
madden's Avatar
any updates on the progress of the front grills?
madden is offline   Reply With Quote
Old 11-04-2008, 11:49 AM   #71 (permalink)
Calls it Mr. Bigglesworth
thomasde's Avatar
Question
More pictures...
Looks good. One question: You used goof-off. Does goof-off affect the paint at all?
Daily driver: Arctic Silver 2005 Lotus Elise.
Weekend toy: Arctic Silver 2005 Lotus Elise.
Road tripper: Arctic Silver 2005 Lotus Elise.
thomasde is offline   Reply With Quote
Old 11-05-2008, 04:55 AM   #72 (permalink)
Mesh grill guy
Kiowapilot's Avatar
I used it on mine. It did not seem to hurt it.
Old 11-05-2008, 06:17 AM   #73 (permalink)
pMarty's Avatar
DarkSol
"2) 10 minutes to remove (and break into pieces) the stock slats. I have no idea how you would remove the brittle things otherwise. Replacement cost for all four pieces is about $160 (source: LotusGarage)."
if you are able to get dental floss through the crack try running it back and forth with a sawing motion, as you pull it along the tape line. this has worked on some two sided tapes for me in the past. you'll be left with half the tape still attached, but the parts wont be broken.
2006 BMW 330xi
2005 Lotus Elise
1998 Jeep XJ "Rubicon"
1983 VW Westfalia
1974 Toyota FJ40
pMarty is offline   Reply With Quote
Old 11-05-2008, 07:03 AM   #74 (permalink)
Yahoo! Got my Rotus!
dma550's Avatar
Watch the ventilation with the goof off. I had to remove glue mess from a gluedown floor with it and I am sure I reduced my IQ by about 10 points doing it.
David Avery
05 Lotus Elise ~ Arctic Silver ~ BWR SC ~ Gray RACs ~ Larini SE
08 BMW 135i Stock
visit Spyderclub.com
dma550 is offline   Reply With Quote
Old 11-05-2008, 05:21 PM   #75 (permalink)
Mesh grill guy
Kiowapilot's Avatar
I am getting very few sales from the engine grills so I am not developing as fast as I would have liked to. Money has been a little tight lately so I have not made much progress. When I get some money I should be able to get these developed really fast. Maybe later this month or early next month I will make more progress. I have pretty much figured out the design now all I have to do is get the money together to build the first set for my car. Once that is done I will be ready to "produce" them in larger quantities as the orders come in. I figure it will take about 2 days to build up a full set and then a few days to get them powdercoated from the time of order.
How about this. For a limited time I will lower the price on the engine grills to try to generate atleast a little development money. So for the guys who are waiting for the full set to come out this will save you some money. Sorry DarkSol.
Until November 20th I will sell the engine grill sets for $130 Shipped powdercoated or $120 shipped Bare Aluminum. Turn around time from the time of order is approximately 2 weeks as these are made to order and not a stocked item.
If anyone is interested PM me with your options. Powdercoated or bare aluminum and fastener type.
Old 11-06-2008, 06:31 AM   #76 (permalink)
Simplify and Add Lightnes
rugger1345's Avatar
Engine grills ordered!
I will try and install as quickly as possible but with long hours at work doing budgeting for oil/gas wells drilled next year, rugby, gym, and whatnot, it might take a few days between the time I get the grills and when I can get them installed with pics up. I will probably remove the old grill as soon as I get shipping confirmation just to get that out of the way.
I ordered mine black powder coated with aluminum pop rivets, fyi.
If we desire respect for the law, we must first make the law respectable. -Louis D. Brandeis
DID YOU HEAR THAT, COP IN BIG LAKE, TEXAS?
rugger1345 is offline   Reply With Quote
Old 11-06-2008, 11:16 AM   #77 (permalink)
Mesh grill guy
Kiowapilot's Avatar
Sounds good. They will be shipped soon. Thanks for the order.
Old 11-07-2008, 09:09 AM   #78 (permalink)
2007 Phantom Black Elise
Phil S's Avatar
Do "all" engine hoods have holes drilled on the sides. Took a look last night (in the dark) but did not see any attach holes in the side of the grill area. Mine is an 07. I want to attach without tape but don't want to drill any new holes.
Phil S is offline   Reply With Quote
Old 11-07-2008, 10:45 AM   #79 (permalink)
Faze's Avatar
Yes, the "holes" are actually screw holes that result from removing the OEM slats.
2006 Lotus Elise - Starlight on black, black badges, HT, touring/sport/premium packages - HID, Katana SC, Clam-tilt
2009 Honda Ridgeline RTL
2006 Kawasaki KLX-250S
2008 KTM 450 EXC-R
Faze is offline   Reply With Quote
Old 11-07-2008, 01:23 PM   #80 (permalink)
Mesh grill guy
Kiowapilot's Avatar
The holes are there. I have no idea why they exist because they are not used at all except for the 4 back holes which have plastic rivets. If you look at your lid from underneath you will see the holes.
