Old 07-10-2009, 04:58 PM   #1 (permalink)
Ex and future Lotus owner
Cardinal's Avatar
Images: 8
Need help - Bug & Tar remover
Hi, I need some advice on bug n tar remover for my car. I have a can of Gunk brand bug and tar remover. It looks just like this:
Has anyone tried this before? Is it safe to use? There are some warnings on the back, and I really don't feel like experimenting on the Elise. I also have some Turtle Wax brand bug n tar remover in a black Windex-style bottle, but it's total crap. It barely works better than water from the garden hose.
Does anyone know of a particular brand that actually works well without doing paint damage? I'd appreciate it. Thanks.
the1sen: why move forward with design when you can recreate a monstrosity from the past?
Cardinal is offline   Reply With Quote
Old 07-10-2009, 06:03 PM   #2 (permalink)
NOT ßANNED!
Demonized's Avatar
If there are excessive bugs on my car, I claybar.
Demonized is online now   Reply With Quote
Old 07-10-2009, 06:45 PM   #3 (permalink)
mhouston23's Avatar
Images: 3
I've used that stuff on my non-Lotus cars, but would NEVER bring it near the Elise. It's basically just lighter fluid in a spray can.
Wash the car, then clay bar, then a good coat of wax. After that, bug residue will slide right off.
2008 Persian Blue Elise SC - HT, Sport, Touring
2008 Honda Fit Sport (Daily Driver)
2003 Honda S2000 (Sold)
1999 Honda Prelude SH (Traded)
mhouston23 is offline   Reply With Quote
Old 07-11-2009, 02:55 AM   #4 (permalink)
shadowhusky's Avatar
I have been using the bug and tar remover from Turtle Wax for over a year on mine and it works great. I use in on the starshied and non starshield areas and I have no complaints. I am using it mainy for bugs however. It is probably just as easy to just use hot water and a towel, I have done that also. ...again , just for bugs, I havent had the need to get any tar off the car yet
2005 Elise, Aubergine, Touring Pack, Sport Pack, Hardtop, Quicksilver Exhaust, Cup Air Box, Tilting Clam, Mesh Grills all around - ( fabricated, not purchased ) 55w 6000k HID's, Painted Engine Covers, Center Console, A/C Surround, Polished Shifter Arm, Ball,and E-Brake Handle, Multivex Mirrors.
2008 Jeep Liberty, Jeep Green Metallic
2002 VW Jetta TDI, Metallic Blue, Daily Driver, 155,000 miles and going strong
shadowhusky is offline   Reply With Quote
Old 07-11-2009, 06:02 AM   #5 (permalink)
G-200 Driver
kestrel74's Avatar
Turtle Wax.
kestrel74 is online now   Reply With Quote
Old 07-11-2009, 09:49 AM   #6 (permalink)
Baby oil works and it's gentle to the finish.
Dead Duck is offline   Reply With Quote
Old 07-11-2009, 10:07 AM   #7 (permalink)
perfututum futūtor
RoadDad's Avatar
Rain-X Bug &Tar Pre-wash Gel
Me... I don't need to.
Bite me." -Randy
Old 09-10-2009, 08:13 PM   #8 (permalink)
iwantanelise's Avatar
Turtle Wax Bug and Tar Remover brings back old memories...but there are better things out there. My favorite? Poorboy's BUG SQUASH. But before I go into that...
WHOOOAAAAAAAA
If there are excessive buggies on your vehicle you should NOT go STRAIGHT to the clay bar or wax (I am not sure if this was meant). Excessive buggies require lots of lubrication to prevent the harden bugs from scratching the paint.
BEFORE YOU GRAB THE CLAYBAR
If you use a clay bar on a bug, some of its hard fragments will get stuck into the claybar, and then once you move the clay bar around the surface for additional passes those fragments stuck in the clay bar will scratch your paint.
WAXING
Waxing a surface to remove bugs sounds terrible, sorry. Wax is not designed to do this, it's designed to protect the paint. Just like the clay bar situation, your wax applicator will get contaminated with hardened bug guts and once that contaminated applicator gets on the paint...SCRATCHES!!!!
The CP Car Detailing Recommendation:
1. I know it's a pain but for the ultimate in prevention you should really wash the area, and do it gently with some lubricated car wash soap to get most of the bug residue off the surface. DO NO SCRUB
2. Once rinsed off, determine if you are satisfied. If not, spray some Poorboy's BUG SQUASH (I like a dilution of 1:3 with water), let dwell for a about 3 mins, then re-agitate gently and RINSE.
3. If NOT satisfied at this point, go ahead and try the clay bar with your car wash soap as lubrication.
4. Once rinsed, go ahead and wax the area you just worked on.
5. Enjoy your bug-free finish
NOTE: Since I am not sure if the posters who mentioned waxing or clay barring meant to jump straight to those methods (a context issue), I went ahead and explained my entire process. No mean to offend, just worried that some may get the wrong idea and ruin their finish.
For the most extreme bugs, I would soak a towel in water and let it sit overnight on the areas that are filled with bugs. In the morning the bugs will be softened and easier to remove.
The best prevention to make bugs easier to remove, and hence, more gentle to your paint is having a fresh coat of wax on your paint at all times. Also, try to remove bugs from the front end as soon as you can, to prevent hardening and future scratching upon removal.
CP Car Detailing...http://cpcardetailing.com/lotusdetailing
Please feel free to CHECK OUT MY NEW WEBSITE and let me know what you think!! Please feel free to ask me questions on how to keep your Lotus looking gorgeous or for detailing rates!
iwantanelise is offline   Reply With Quote
Old 09-11-2009, 06:56 AM   #9 (permalink)
glb
Unattractive Nuisance
glb's Avatar
kerosene.
Old 09-11-2009, 07:43 AM   #10 (permalink)
BBeauty
RWLott's Avatar
kerosine
Originally Posted by glb View Post
kerosene.
ditto for the tar.
I use glass cleaner/paper towell for the bugs.
RWLott is online now   Reply With Quote
