Old 11-09-2006, 10:04 AM   #61 (permalink)
Dean NZ's Avatar
TimMullen - you are right !
I learned something today thanks, after checking with the local Lotus guys the Toyota instrument pack has as Tim says, digtal feed so ya can't get the tacho signal from this. The fused igntion power and earth can come from this but you would have to run a single wire back to the ECU and pick up one of the ECU spark plug wires that fires the coil.
I'll hunt down a wire diagram and mark up the best place to take this from.
Tim you able to email me the relevant pages ?
The designer of the unit put the following picture togther to help with other systems. Jim's unit might be a good way of getting that signal back to the cockpit for other uses - datalogging units & shift-I of course.
Sorry for the confusion in the first post guys.
To make it go faster you will have to add lightness.
...make the suspension adjustable and they will adjust it wrong -- look what they can do to a Weber carburetor in just a few moments of stupidity with a screwdriver.
Colin Chapman
Dean NZ is offline   Reply With Quote
Old 11-09-2006, 10:08 AM   #62 (permalink)
Dean NZ's Avatar
ooops forgot - you can download the shift-I units different shapes in 1:1 scale from the website so you can see if it will fit.
Go to the installtion page to download the two different shapes - curved & straight.
Cheers Dean
Colin Chapman
Old 11-09-2006, 04:27 PM   #63 (permalink)
Jim-Clayton, thanks for the MSD suggestion. May I ask where you sourced the switched 12 volts to the pickup?
MikeW is offline   Reply With Quote
Old 11-09-2006, 04:39 PM   #64 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
edit: Places to buy
I purchased mine new on Ebay for 35 plus shipping... There are several ebay stores that offer them. Along with Jegs, Summit, MSD, etc... You can even use google... I found out that it's a very easy part to find...
Best,
Phil
Edited: I'll read the question before I post next time
Old 11-09-2006, 05:02 PM   #65 (permalink)
jim-clayton's Avatar
I tapped into the stereo wires. I added a remote barrier strip that included
multiple taps for ground, constant 12v+ and switched 12V+ (fused circuits)
I connect my radar det. , video, gps, all that junk.
Old 11-09-2006, 06:06 PM   #66 (permalink)
Thanks Jim
you've got lots of sensory input with all that stuff!
Old 11-09-2006, 09:57 PM   #67 (permalink)
Dean NZ's Avatar
Download and print for 1:1 sizes of the Ecliptech Shift-I
Cheers Dean
http://www.ecliptech.com.au/media/sh..._i_cutouts.pdf
Colin Chapman
Old 11-09-2006, 10:59 PM   #68 (permalink)
Note: the document appears to be for A4 paper, not US letter-sized. So make sure to follow the instructions to print with no scaling and confirm the measurements afterward.
dododge is offline   Reply With Quote
Old 11-13-2006, 03:47 PM   #69 (permalink)
swisstexelise
swisstexelise's Avatar
I would get used to the sound of the motor. A really good driver would know when to shift by the sound and timing.
lotus elise -
yellow sport package/ touring / 05/ hard top/ soft top
gut rear spoiler,front cf spolier with splitter, rear cf diff, cf center console, harness bar, b&m shifter, 4tress harness bar sector111,4 point harness, fire extinguisher, carpet buttons, CRD mount, bemani supercharger, bemani exhaust, bbs rims, vonhep naked look, in process of tuning !!! /2005
swisstexelise is offline   Reply With Quote
Old 11-14-2006, 07:00 AM   #70 (permalink)
I must be a bad driver.
I drag raced for years with no tach. Running on a road course is a little more "busy".
I like to short shift to save wear and tear.
Old 11-14-2006, 09:57 PM   #71 (permalink)
Dean NZ's Avatar
That's a pretty broad statemnet isn't it ?
Is that why all of the:
F1 drivers , V8 super cars, Kart & Rally car drivers and most of the Nascar are fitting with LED shifts lights...........mmmm can't be really good drivers then ?
You should try driving an engine that has the same sound in rev's through the upper part of the range and has a very linear power delivery and see how you get on racing on a track when it's "busy"..........I thought I never hit the limiter until I datalogged a race and found I was regularly bouncing off it....not good for the engine at all......
Colin Chapman
Old 11-20-2006, 12:57 AM   #72 (permalink)
mark_r's Avatar
Greetings from Scotland. I had been thinking about fitting the Shift-I to my Exige and stumbled on this thread. Just wondering if any of you have succesfully installed one yet - I'd be particularly interested to see where/how you connected the wire in the engine bay to pick up the RPM signal.
Mark
mark_r is offline   Reply With Quote
Old 11-23-2006, 09:24 PM   #73 (permalink)
Dean NZ's Avatar
Mark - assume from the picture your Toyota powered ?
If so you will have to pick up a signal from the engine bay as per the wiring suggestions above, power and earth should be sourced from the stack unit.
I'm trying to find a wiring diagram for the toyota powerd cars so I can put some instruction together.
Anyone got a PDf or similar of the S2 toyota powerd service manaula with the wiring instructions ??
Colin Chapman
Old 11-23-2006, 10:43 PM   #74 (permalink)
jlotusd's Avatar
the simple solution is to buy a gtech pro ss or rr
jlotusd is offline   Reply With Quote
Old 11-25-2006, 11:26 AM   #75 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Installed!
I took the day off yesterday and installed the shift-I light. VERY COOL!
I used the MSD tach signal pick-up mentioned in this thread. I purchased the straight based shift light setup with the green, yellow, and red lights. This little gadget has a ton of interesting options and is surprisingly easy to use.
I have to say that installation is a bit difficult since our cars aren't the most friendly in the world for routing wires without chinese fingers and a quadruple jointed spine
One has to pull the signal wiring from a plug coil all the way to the dash where the light is installed. Plus, I had to pull the radio and tap into the switched hot wire to turn the system on with the key. I ended up running the wires from the switched radio power inside the dash behind the speedo, which kept the install clean.
I pulled the tach signal wire through the shifter cable access hole, up the spine and then up through a hole under the dash where the steering column goes through the bulk head. All the wires met up behind the light switches. I then fed the three very thin wires through the dash and laid them at the base of the windshield to the point where I mounted the shift light.
I velcroed the light (you can't see the velcro) in the indention for the defrost vent in the center of the dash near the base of the windshield. I found this to be a great spot since the light is always in my peripheral while watching the road. It also looks -almost- factory in that location and the arch of the light follows the arches of the dash quite well from both in and outside of the car.
At almost $200 for the whole project, I think it is well worth it
Best,
Phil
Old 11-25-2006, 12:47 PM   #76 (permalink)
bluejae's Avatar
pictures?
KG Exige Delivered 5-9-2006
POLL:check for scratches "in" your headlights
Excessive tire wear? It may be your alignment
My Example
Hiro's Example
codymac's Example
to be installed: stebel horn, fumoto valve
current mods: arqray twin muffler, itg intake, 3M film full wrap and full rockers by X-Perts, rear lotus letters removed, locking gas cap, CF Mirror Covers, CF Side Scoops, black lotus nose/wheel badges
future mods:wheels, forced induction
bluejae is offline   Reply With Quote
Old 11-25-2006, 12:49 PM   #77 (permalink)
bluejae's Avatar
i have this lying around the house brand new
http://www.autometer.com/cat_accesso...l.aspx?vid=134
would this work in the exige?
My Example
Hiro's Example
codymac's Example
Old 11-25-2006, 04:26 PM   #78 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Yes...with a bit more work. I believe you need a rpm switch with those... So you would need the mentioned MSD sensor and then a switch and associated rpm plugs to trigger the light. That's how most of the non-adjustable lights like your work anyway...
The Shift-I light has all the nec. software and hardware internally except the tach signal pick-up. It's fully adjustable and I would presume a better route to go than a traditional light. IMO...
Best,
Phil
Old 11-25-2006, 04:28 PM   #79 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
pictures?
Ah c'mon- can't you use your imagination
I'll see if I can pry the digi cam from the wife long enough to snap some shots and get them posted.
Phil
Old 11-26-2006, 11:15 AM   #80 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Here's a couple Bad pics
I know the lighting isn't great, but this will give the basic idea of where I mounted it. I figure everyone knows how to get wires routed so, just the final product here...
BTW- the weight of this upgrade is virtually zero
Best,
Phil
