Old 07-23-2007, 10:46 AM   #101 (permalink)
Assman's Avatar
I want to buy one, probably 2 (brother just bought an elise - the copycat) Let me know when they are available and for how much.
Assman is offline   Reply With Quote
Old 09-29-2007, 10:33 PM   #102 (permalink)
choi0706's Avatar
Originally Posted by rob13572468 View Post
right now the unit is going through beta testing of the current iteration. the rpm trip code needs to be rewritten; right now i adjust all of the trip points by changing the values in the source code and recompiling. the final product will have an rs232 interface and a small pc programming uploader. you'll use a laptop with a serial port to change the values as much and as often as needed.
the casing for the unit is actually the biggest issue right now... i found a company that can source the OBDII connectors so thats taken care of but finding a suitable casing for the LED display is proving difficult. ideally the finished product will look something along the lines of those varad LED scanners that you see in some cars. this will allow the display portion to mount just about anywhere since the dimensions will be very small. now i just need to find a company that sells them in 0-50 quantities....
an interesting side note to this project is that the bus module that i developed for this is actually working quite well as a cluster driver as well... this means that its not to terribly difficult to build a module that takes discrete inputs from an aftermarket ecu and will drive the stock cluster. the end result would be that anyone interested in hydra system could finaally have a complete plug and play system without needing to keep the half-working stock ecu. im not familiar with how many people are actually interested in the hydra but once again if there is enough interest it can be developed...
any updates on both box and can emulator?
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is online now   Reply With Quote
Old 09-29-2007, 10:40 PM   #103 (permalink)
Rotary Refugee #2
Rob T's Avatar
I have to admit that I do miss the shift "beep" that my RX-7 and RX-8 had.
Rob T is offline   Reply With Quote
Old 09-29-2007, 11:00 PM   #104 (permalink)
Chris Mackey's Avatar
Originally Posted by 0o7 View Post
Sounds like a mix of Kit and my exgirlfriend. "Shift into 3rd Micheal and put the toilet seat down. I swear if my a$$ gets wet at 3am 1 more time I'll leave you! Now heal toe into 2nd and easy on the shifter you know how I get this time of the ..." blah blah.
This is genius.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
Chris Mackey is offline   Reply With Quote
