#241 (permalink) |
Buz, last weekend I took a road trip up to Dallas in 104 degree heat, but I didn't have quite as good luck as you did. My car, with the repositioned AC sensor, froze up every 50 miles. I'm going to try the Wattwood Air Vent Enlargement Mod http://www.elisetalk.com/forums/show...8&postcount=87 before this weekend's road trip. I also suspect that some of the backroads I drove may have repositioned my AC sensor too.
John
1991 Miata "slightly" modified 2004 MINI Cooper S JCW 2005 CO LSS Elise 1948 MGTC 1957 Thunderbird |
#242 (permalink) |
Ex-Brit
Saw this old thread and thought I would check the position of the temperature probe after experiencing no cold air after about 30 minutes. I was actually happy to see the probe was about 1/2" from the evaporator fins as shown in the photo. I repositioned the probe and am now waiting for the opportunity to take an extended drive to test it. Within this thread I have noticed that by doing this procedure, some have had success and other not, I don't understand why it is not consistant. Another interesting point is that in a home A/C system there should be a differential of about 18' between the room and duct temperature. On my car, it was 55' duct and 80' air temperature, a 25' differential, I don't know if this is normal for a vehicle.
A/C Improvement Modifications http://www.lotustalk.com/forums/f3/e...ent-mod-59938/ 1) Insulate the cockpit from Solar (3M Crystalline Tint) & Convected (insulate sills) heat. 2) Replace evaporator thermostat with an upgraded electronic version to prevent freeze up. 3) Increase airflow into cockpit by removing both driver & passenger side footwell intake panels & blocking 2 outside air intakes in nose. |
#243 (permalink) |
It's a Lotus
Qais topped it off with freon last time I was in for a check up and the a/c worked alot better.
2005 Saffron Yellow Elise, Sports & Touring Packages, Hard Top, Stage II Exhaust, '07 Probax leather seats. Los Angeles Lotus Service by Qais at 310-200-0022. "We know they're magical and worth every minute we spend on them. The whole Lotus owners' world is like a secret handshake among people who understand that." (R&T) |
#244 (permalink) |
Certified Fun Stopper
Just noticed this thread. The A/C in my 2005 Elise was average. The A/C in my 2006 Exige is much, much better. Does anyone know if Lotus changed anything about the A/C after model year 2005? Does anyone else who has owned multiple Lotus noticed a difference?
'06 Exige; Polar Blue; Track/Touring/Stage II/LSD-TC '05 Elise; Arctic Silver/Ruby Red (R.I.P) |
#245 (permalink) | |
Thread unraveler
Read about my recent journey across the US here: Travelblog 06 Lotus Elise :: Chrome Orange :: Base :: Black Pack :: TC :: SS 00 VW Golf GLS TDI |
#246 (permalink) | |
Ex-Brit
#247 (permalink) | |
Thread unraveler
#248 (permalink) |
I can run very fast
Mine works well, but not as well as my other cars.
my favorite Elise sites: http://www.elisemods.com http://www.sandsmuseum.com/cars/elise/index.html |
#249 (permalink) | |
Dude, There's My Car
Air conditioner torture test
At first when he got the car, it didnt work to good, so he had the probe relocated about 2 years ago after I told him it made mine work better. Then about a month ago it went out completely and they put coloring in to check for leaks. It seems like they changed fitting on the A/c lines and the newer cars have updated ones. Our cars are 05 models, so I dont know when it was changed. The fitting was leaking. Since it goes through the siderails of the car it was a pain to fix. It took them 10 days to get everything redone, and it included a new compressor and a bunch of other stuff. I havent seen his repair order to get the new part number for the fittings or the parts that were fixed. He called me the other day and said that the a/c went out again after having all the work done. Hopefully it is just a freon leak. |
#251 (permalink) |
Keep it simple and real
TonyM, it is likely the a/c relay. Lotus replaced mine under warranty.
'06 Exige - Ph. Black/Touring/Track/LSD/TC/SS. Mods: corner balanced - RTD brace - Manly's inserts - decambered - Pagid Blacks - Motul fluid - tow hooks - Schroth belts - extinguisher - AIM timer - Green Filter - Larini - oil temp & pressure gauges - AO48s & Rotas on track - T1Rs & OEM wheels on street - rear camera & monitor - Stebel horn - speakers upgraded, sub & iPod controller - DRL disable switch - aux. fuse panel - sill pockets - leather console - Bootie - roof scoop functions. |
#254 (permalink) |
MBExigeS
My AC has never worked that well and has now completely stopped working. Much like xxxotic has mentioned above, they have placed dye in the car to locate the leak. Seeing that it is an 05, I'm disheartened to hear that it may take up to 10 days to fix!
xxxotic, any further news/details on your friend's AC issues? I haven't taken mine back to the dealer yet, but plan to later this month. |
#255 (permalink) |
Dan D
The AC in my old '05 Elise never worked. The AC in my '07 Exige works fine.
07 Exige S: GG, Track Pack, V1, RV Camera, S111 CF roof and splitter, 4.5-lb Voltphreaks battery, 10-lb Von Hep Exhaust, Green filter, 265 crank hp +/-, Volk TE 37 Wheels, RTDbrace, Scroth 6-point ASM harnesses, W2A IC to come??, 1965 lbs total weight (est) 05 Elise: Storm Titanium, Sport, Touring, Stage II (SOLD) (May '05 - Sept '06) |
#256 (permalink) |
Daily Driver
Mine works fine most of the time... this past weekend I took a trip to Orlando to visit some friends (2-1/2 HR trip) and about 3/4 of the way up the fan cut out??? You could barely feel cold come'n through the vents, though not enough to keep the cabin from get'n blazingly hot. I shut the a/c off for about 15-30 minutes and turned it back on and it worked fine. Same thing happened again on the way back. Anyone know why???
2005 BORDEAUX RED ELISE: Sport Pack, Hard Top, Star Shield, Black Mesh Grill, De-snorkled, K&N Filter. 2005 TORNADO RED TRIUMPH DAYTONA 650 2004 SUPERCHARED TOYOTA TACOMA 4WD - SOLD |
#258 (permalink) |
It was 93 here in Houston today and my AC seemed to work fine...
2007 Exige S - Chili Red 2009 Mini Cooper S - Chili Red Gotham 265, Nitron Sport Pro, Moroso oil pan, RTVBrace, Volk CE28N/R888, Cup Wheels/A048, 2Bular Ultra 4", Rapfix II w/ Sparco P300, S111 CF Splitter, Ultradiscs, Pagid RS42, V-Force Harness Bar, Schroth PROFI II, Fire Extinguisher, Folding Tow Hook, Odyssey PC680, re-ENFORCER, LLumar 30% tint, Traqmate, DashDAQ, Chasecam, Alpine IVA-D100 w/ Backup Camera. |
#259 (permalink) | |
Edi Aut Edaris
#260 (permalink) |
From close to Roswell....
Chassis 30956, a 2006 Elise. Tried it first time on a couple hour drive from Palm Springs (110) to the beach. After about 75 minutes, the compressor froze, I assume, as there was almost no airflow. Oddly, it might have been because it was blowing so cold when I was leaving the desert, I was running a low fan speed. I guess I should have just cut the temp down and kept the fan speed up.
Where does the condensate drain out? It looked like under my passenger door.
2006 Elise, Graphite Grey/Red leather, Sport Elise Suspension, Hardtop 1992 900SS Ducati Race Spec Built by Ferracci 2006 KTM 950 SuperMoto, a work in progress Wife drives a 2007 Cooper S, our BIG car! ![]() Old stuff gone: Ferrari 275GTB/4, '69 1275 Cooper S. '72 500 Fiat, old Jags, etc. Never bought a boring car. |
