Old 05-04-2008, 07:25 AM   #1 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Rear Clam Removal
I posted some "in a nutshell" instructions for rear clam removal on moremonkey.com and thought I would do a quick cut and paste for someone performing a serach over here that needs a quick how-to...
It's pretty simple, just requires some time...
Remove seats, and rear speaker panel. Remove the under side roll bar cover after speaker panel removed. Remove the two bolts (10mm head) above either seat location that attach the roll bar to the outside rollbar cover.
Next, there is a bolt on either side of the car that is above the side scoops and accessed from inside the cabin. Remove them. (10 mm head)
Next, remove the 4 nuts securing boot lid hinges from inside the cabin, found on the fire wall below the rear window, 10mm nuts.
Next, With the boot lid hinge nuts removed from inside the car, you'll be able to fish the boot lid out of the car and set it aside.
Next, remove both rear tires and liners. Remove both (10mm head) bolts on either side of the car that attached rear clam to the rocker panel (4 total). The two bolts are found to the rear of the side scoops and access through the wheel opening (that's directly in front of each rear tire).
Next, remove the battery and boot carpet. Remove all 4 bolts found in the boot that secure to the subframe. One is under the battery.
Next, pull the battery cables through the boot wall so that the cables are in the engine bay.
Next, Disconnect tail light plug inside the boot and pull it into the engine bay as well.
Next, remove the rear panel and disconnect the each fixing on either side of the diffuser that attaches to the diffuser. It's likely easiest to just remove the diffuser, and leave the rear panel in place. With the rear panel in place, the clam is a bit awkward, but you have the option here. ** Note, if you leave the rear panel in place, besure to disconnect the assocaite heat shielding**...
Finally, trace the 3rd brake light wire from the light several inches and you'll find the quick connect plug. Disconnect the plug- Leave the light in place.
Grab a buddy and **lift the clam straight up**, then come back with the clam once it has cleared the roll bar... then you're done... should take 2 hours if you're pretty handy...
Best,
Phil
Old 05-04-2008, 08:04 AM   #2 (permalink)
BANNED
On the Exige remember to disconnect your remote trunk release...
mpsalm is offline   Reply With Quote
Old 05-04-2008, 08:13 AM   #3 (permalink)
Randy Chase's Avatar
Images: 761
Previous thread
Is there a post on removing the rear Clam?
Originally Posted by Randy Chase View Post
Let me see if I can add to Tim's/Lotus' manual post. Or maybe clarify. Or simplify. Or just muddy things up. Feel free to reply and clarify. I am working from memory. This reflects an ELISE only.
In a nutshell, this is a very easy job and should be considered as an option any time you do work on the engine. It is a bit of work done up front, that makes the other work a lot easier. With the clam off, access to everything is easy. Most of this may look more difficult, but standing in the car, doing one step at a time, it will be more apparent how easy this is. My sequence may be a little different, I like doing the in-cabin work BEFORE I jack the car up.
The main work on getting the clam off is that you have to remove the plastic bulkhead behind the seats, which means removing the seats. And it is a bit fiddly getting the cables in the grommets for the clam.
You can do this job by yourself, including the final lifting of the clam. But it is easier with someone else... just not required. Make sure you have a place set aside for the clam once it is off. Best to have some supports so that the clam is not resting on the fiberglass on concrete. At least use some padding/towels under it.
There are some tools that will make your life easier for this job. Mainly extensions for the 3/8" socket drive to get the seat bolts out... and also a long extension and socket for the nut that holds the rear window shroud sides (access from the wheel wells).
1. Take off the roof. Hardtop or soft top. Take it off. If you can't do this, then stop right here and let someone else do this job. In fact, consider if this is really the right car for you. ;p
2. Remove the two seat's fasteners. This is an EASY task. Really. You will see each seat has 4 fasteners. Some are allen head, some are hex bolts. Remember which goes where. A VERY long extension (or two) will make reaching these very easy. The driver side is easier because you can slide the seat forward and back. Probably the hardest bolt is the inside passenger rear one.
Note that the driver's side has two stops that exist to limit rear seat travel. The double stop is on the outside, the single stop next to the center console.
Set the stops and bolts in a baggie.
Note that when you re-install the seats, be VERY careful to not cross thread the fasteners. It is easy to do. If you do end up needing a tap, I have one.
3. Pull the seats out of the car. If you still happen to have the driver's side seatbelt connector connected, disconnect it. At this point they will be tethered by the seatbelt. Once the seat is out of the cabin, set it on the ground and using a 17mm wrench, remove the seat belt attachment bolt. Note the arrangement of the bolt, spring, spacer on the seat.
4. Now is a good time to do ANY work inside the cockpit, including cleaning under the seats, disposing of the french fries and anything that was under the passenger seat.
5. Remove the trim panel plastic under the rear window shroud. You can see some plastic fasteners. Remove those. Carefully.... VERY carefully pull the plastic liner under the rollbar away. It is very easy to crack this so take care. A small flat screwdriver covered in tape is always a helpful tool for working on interior plastics. Under the trim panel, you will see two metal brackets as pictured in BR.2. Remove the two M6 screws and washers. Save in a baggie.
6. Remove the rear bulkhead (the part that was behind the seats). Leave everything that is on the bulkhead (net, interior light, speakers) still fastened to the bulkhead, just pull the bulkhead away and disconnect all the connectors. You will have to pull it away from the plastic bits and carpet stuff. Set the bulkhead aside.
7. If your car has the sound deadening foam in it, remove this, carefully pulling it out from the corners so as to not tear it. This is a bit heavy. Set it aside.
8. From inside the car, remove the B post fixing (see BR.7 pic) from inside the cabin. This one is really easy. Do both sides.
9. From inside the car, remove the two bolts on each lid hinge. Note locations of rubber/washers.
10. Remove the lid and hinges from outside the car. Set aside.
11. Inside the engine bay, unhook the washer bottle and let it dangle.
12. Inside the boot, detach the battery cables. If you are anal like me, wrap the positive end in tape. Untighten the battery attachment bracket and remove the battery. Set aside.
13. Pull up the carpet/foam at the bottom of the boot. Note the two bolts on each side, one near the rear of the boot, one near the front. Remove the bolts and baggie them.
14. Disconnect the cables to the rear tail lights.
-Intermission- At this point, you have probably spent about 60-90 minutes on the car if you took your time. Your interior is gutted, the rear window shroud is almost ready to come off. Now we move to the next step.
15. Break loose the lug nuts or lugbolts on the rear wheels. Jack up the rear of the car using Jim Clayton's cool tool. If you don't have that, then jack up each side. Place jackstands under the proper points. If you are doing other work that requires bottom access, it would have been a good time to remove the diffuser and bottom panels.
16. Remove the rear tires. Remove the rear tire well liners. These are easy, just a philips screwdriver to remove the plastic fasteners. Pull out.
17. Up inside the wheel wells, almost easier to feel than to see, is the M6 nut holding the rear window shroud to the clam. Using a long socket (the stud is long) and a long extension, remove this nut. You may want to consider going in from the engine compartment. Or not. This one is a bit tricky.
18. At this point, nothing is holding on the rear window shroud except the weatherstripping. The proper method for removing is to peel the stripping back off the cover. I then used some bluetape to support it to the rollbar. But some have reported carefully cutting the weatherstripping so it comes off with the cover. I can see how a good diagonal slit would still work well once it was put together. Your call. I had some adhesive to put mine back, but I found that it was still sticky after one removal so I did not need it. In any case, pull off the cover from the clam, carefully applying equal pressure to break it free (it can tend to stick at first). Set it aside.
19. Using an allen wrench, remove the fuel filler ring. Do not remove the gas cap.
20. If you still have a snorkel, remove it and toss it.
21. Remove the two bolts that attach the clam to the sill panel (in front of the rear wheels) and air intake grills. You can remove the grills.
22. If you have not removed the diffuser, remove the bolts connecting the rear panel/grill to the diffuser unless you want to remove the rear panel/grill from the clam. If you do want to remove the rear panel/grill from the clam, remove the bolts inside the rear of the boot. These are a bit of a pain to re-install by yourself, suggest two people for this.
23. Snake the battery and rear tail light harness wires out the grommets.
24. Life clam off car. Set carefully where protected.
25. Note location and condition of chassis frame spacers where the clam was resting on. These are held on with tape and the tape can get old. I suggest marking with a sharpie how many shims there are at each of the 4 points and using good duct tape, retaping them. I used aluminum heatshield tape on my car. Worked well.
Done! This is about 2 hours of work all told. After your first time, it is 90 minutes at most.
[b]* V E R I T A S * A E Q U I T A S *[/b]
We have been feeling the buzz since 2002
2009 Rossion Q1. [color=orange]Monaco Orange. [/color]Wing. Black leather/Alcantara with orange stitching. The street car.
In build: 2009 Toniq R (300whp? 1100 pounds?). [color=orange]Chrome Orange. [/color]
Lexus GX-470 tow vehicle.
[color=blue]“Busy at times off the forum and *scary* actually off the Internets. So I may not see your pm or emails for a while"[/color]
Old 05-04-2008, 08:14 AM   #4 (permalink)
Images: 761
<img src="http://www.lotustalk.com/forums/attachments/f101/72952d1202329226-there-post-removing-rear-clam-rearwindowshroud.jpg">
Old 05-04-2008, 08:14 AM   #5 (permalink)
Images: 761
<img src="http://www.lotustalk.com/forums/attachments/f101/72953d1202329226-there-post-removing-rear-clam-rearclamremoval1.jpg">
Old 05-04-2008, 08:19 AM   #6 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Thanks Randy- I missed that one... I was trying to have a real clear title for searchers. I think we've got it pretty well covered now if it wasn't before...
Perhaps a sticky???
Best,
Phil
Old 05-04-2008, 10:15 AM   #7 (permalink)
how bout a sticky for this and for the front clam. i need mine off and i dont know the first thing about it
evilelise is offline   Reply With Quote
Old 05-18-2008, 01:18 PM   #8 (permalink)
The Captain's Avatar
sport pack harness bar
I really appreciate the help provided by this thread. For the life of me I cannot figure out how to get the full width trim panel off with the harness bar installed. Any suggestions would be appreciated.
'06 AW Elise, Track Pak, starshield, micro mirror, Schroth 5 pt. harnesses, SSR competition wheels, ECU upgrade, boomerang towhook, von hep exhaust, fugita intake, gold foil heat shield, S111 seat brace
mine -'06 Elise', '06 350Z
her's '07 Lexus RX350
two wheels:
Ellsworth Enlightenment, Rocky Mountain RMX, Santa Cruz Heckler, Bontrager Super Lite, Orbea Road bike
The Captain is offline   Reply With Quote
Old 05-21-2008, 11:56 AM   #9 (permalink)
TimMullen's Avatar
Images: 19
I would expect that you had to remove the harness bar first. Isn't the harness bar attached on each side to the rool bar with bolts?
94 Miata R Package - Black
Old 05-21-2008, 12:12 PM   #10 (permalink)
It is. I managed to get the clam off without removing it.
two wheels:
Old 10-07-2008, 10:20 AM   #11 (permalink)
Is there any trick to aligning the rear clam when it is reinstalled? That is, is it fairly easy to line the clam up so the panel gaps are even?
Phoenix SRT is offline   Reply With Quote
Old 10-07-2008, 10:22 AM   #12 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
No tricks really. it lines itself up quite well, which is part of the reason why my hinge system works...
Best,
Phil
Old 03-03-2009, 05:31 AM   #13 (permalink)
LT Rebel in Hiding.
LotusStig22's Avatar
If someone didn't say already, how long would this take approximately?
"My plan is to dress as a leprechaun and stand at the side of the road with an engine crane and a crowbar.
The cops will waste valuable time breathalyzing the driver after he tells them a leprechaun stole his engine and I'll be able to make an escape"
~Cthulhu
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
LotusStig22 is offline   Reply With Quote
Old 03-03-2009, 07:59 AM   #14 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
give or take- two hours...
Good luck,
Phil
