Old 04-15-2007, 07:31 PM   #61 (permalink)
TheOtherEric's Avatar
Originally Posted by esthi
I used the 3/8" regular density Air2Gel, and then put a 1" layer of regular foam (from JoAnn Fabrics) over the Air2Gel. The seats are much, much better. I can still feel every pavement variation, but my tailbone is much happier.
Note: I also purchased some 1/8" HD Air2Gel, but did not use it. Overall, both types of Air2Gel were much firmer than I expected.
I have to disagree with my wife a bit here. I think the Air2Gel is definitely too firm. It's basically identical to the kitchen comfort/cushion mats that we bought at Wal-Mart for $8 each, except the Air2Gel (regular density 3/8") is a wee bit softer. If it were about 30% softer I think it would be great material.
1995 993 C2, speed yellow. PSS9, TRG sways, RSRs, HIDs, Big Red brakes, seats/6-pts, Speedline Alesio wheels, Ruf aux oil cooler, RS parts, DL-1 data logger.
2005 Elise, saffron yellow. 6-pts, etc.
TheOtherEric is offline   Reply With Quote
Old 04-16-2007, 11:02 AM   #62 (permalink)
Nuclear Powered
KryptonGreen's Avatar
+1 I had to fall back on a 3/4" high density foam (kneeling pad) for the seat bottom.
A day without Elise is a day without Love.
KryptonGreen is offline   Reply With Quote
Old 09-13-2007, 02:50 PM   #63 (permalink)
Domino's Avatar
Resue Old Foam
Can anyone that has done this mod tell me if the original foam that was under the seat pad is reused? Or do you just toss it and use the new stuff? The 2 pieces I'm wondering about are shown in the attached picture.
Domino is offline   Reply With Quote
Old 09-13-2007, 02:59 PM   #64 (permalink)
I friggin' love coloring!
Brian 111's Avatar
I did not have those pieces of foam on my '05. I'm guessing that you have Probax seats.
BTW, before rebuilding mine with Kemmler's foam, I tried Tempur foam and that foam used in kneeling pads. The Tempur compresses and molds to you, but doesn't have energy absorbing propertied. Tha kneeling pad foam worked much better, but it broke down and became soft after a few months. Your results may vary.
Brian 111 is offline   Reply With Quote
Old 09-13-2007, 10:41 PM   #65 (permalink)
Domino's Avatar
Hi Brian -
I'm pretty sure they're not Probax as it's an early 2005 model and the seats have the bladders. From your first post in this thread you mentioned:
"The bottom cushion had foam that was easy to rip up when separated from the seat, so I used a utility knife to slice it away from the seat shell, almost like scraping a sticker off of the inside of a windshield. I covered the foam with duct tape to keep it from disintegrating (just separating it from the seat made a huge mess) and to give me a stable surface to reattach it to the seat base with tape or glue."
I thought that the blue foam shown in my picture was the one you were talking about but I wasn't sure if you ended up reusing it or not since it sounded like it fell apart on you. The foam on mine came out fairly intact.
Old 09-14-2007, 06:20 AM   #66 (permalink)
Brian 111's Avatar
Domino-
My car was built 5/05, and those pieces of foam were bonded firmly to the seat leather, which was wrapped around the foam. I didn't recognize it, but when I took a peek at my car the foam in your picture looked familiar.
If I were you, I'd reuse it, unless you want to totally re-contour the front half of the seat bottom.
So, what is the leather supported by on your car?
Old 09-14-2007, 06:33 AM   #67 (permalink)
Probably Lurking
Keeper's Avatar
I used duct tape to resecure that piece of foam to the leather insert. IIRC, the duct also made it easy to use that area for carpet tape if I needed it.
Keeper is offline   Reply With Quote
Old 09-14-2007, 06:39 AM   #68 (permalink)
Brian 111's Avatar
That's exactly what I did, but mine was already attached to the leather, which wrapped around the foam 2" on either side.
Old 09-14-2007, 11:18 AM   #69 (permalink)
Domino's Avatar
Hi Brian -
I think I'll re-use as I don't want to re-contour it. The leather seat insert is supported by that blue foam in the picture, but it wasn't firmly bonded. The seat insert came right off of the blue foam when I pulled on it. It stuck pretty well to the seat shell and in the picture you can see the residue there. The thin piece of white foam (also shown in the picture) was under the blue foam but on top of the metal bar.
What wasn't obvious from your original pictures and description was that the 2 pieces of foam that I show were stuck to the bottom of your leather seat pad. Thanks for clarifying.
BTW... I'm installing seat heaters while I'm at it.
Old 09-14-2007, 11:30 AM   #70 (permalink)
The Mad Scientist
darkSol's Avatar
I found that the blue foam peeled, separated and was generally a pain in the arse. I used blue painter tape to hold it all together when I reassembled the seat. I have the base cloth seats though.
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
Supercharged 2005 Graphite Grey Lotus Elise: 230whp, 1843lbs. 12.41 @ 110.0 mph.
300whp @ 1799lbs. or bust!
darkSol is offline   Reply With Quote
Old 09-14-2007, 07:00 PM   #71 (permalink)
No, it's not a Ford Lotus
Johnny B's Avatar
I ordered the 1/8 Air2Gel HD and the 3/8 AirGel regular. Looking forward to doing this mod.
Johnny B is offline   Reply With Quote
Old 03-28-2008, 08:03 AM   #72 (permalink)
Virginia Beach Car Guy
VBCARGUY's Avatar
Just ordered the gell also. I can't find a decent seat that will work for tall people. Tom at shock tec was extremly helpfull. I will post pics when I install it.
Triumph Tr4a Race Car 1967 SOLD
1954 CJ 3b Willys
2002 Yukon Denali Daily Driver
2006 Exige. The only man in america to have a exige s then go back to a NA exige
1967 911S 1900lbs 220hp
VBCARGUY is offline   Reply With Quote
Old 03-28-2008, 08:37 AM   #73 (permalink)
falcon's Avatar
Does anyone know if this foam is like the stuff in Corbin mororcycle seats
falcon is offline   Reply With Quote
Old 03-30-2008, 09:32 PM   #74 (permalink)
#334
Chococar's Avatar
Have you tried searching for "tall person's seat"?
Thanks,
Joe
Old 10-06-2008, 11:44 AM   #75 (permalink)
3 years and counting
peck555's Avatar
Just a bump in the road.
Laser blue,biscuit, micro mirror, "Blue knob" ,HID lights,modded rear lights,rear badge,blue starter button, replaced speakers,perma grin,
Club111 The Sith lord of the LB's loyal henchman
peck555 is offline   Reply With Quote
HTML code is On
