Old 12-25-2006, 12:39 PM   #21 (permalink)
3 years and counting
peck555's Avatar
Originally Posted by darkSol
I received my Air2Gel form last evening.
I did the most rudimentary "stuff a folded piece on the existing seat" test and plunked my butt on top... It felt MUCH better... great stuff!
Looks like a Christmas/New Year's project to me
Edit: Actually I'm completely insane. I'm sitting on both pieces at work now in my "already pretty comfy" desk chair.
Piece1: 3/8" thick = 18.75 x 34.625 = 4.51 sf = 3.345 lbs.
Piece2: 1/8" thick = 26.25 x 32.625 = 5.95 sf = 1.425 lbs.
Total of 4.77 lbs. for both sheets.
I'm estimating a 3.0 lb. weight increase by performing this mod - but ohhh the feeling...
I need to do this myself...note to self...order the damn gel
Laser blue,biscuit, micro mirror, "Blue knob" ,HID lights,modded rear lights,rear badge,blue starter button, replaced speakers,perma grin,
Club111 The Sith lord of the LB's loyal henchman
peck555 is offline   Reply With Quote
Old 01-04-2007, 10:37 PM   #22 (permalink)
The Mad Scientist
darkSol's Avatar
Update: I cut and weighed the Air2Gel pieces and came up with 3.05 lbs for both seats.
It took about an hour to peel both seats open, flip their bladders down, position the Air2Gel pieces, glue them and seal them back up again.
I also found that spray painting the edges of the pieces black (before installing!) helped hide the Air2Gel tan color after completion. It's only visible if you pull up on the sides and are looking for it
They feel AMAZING.
I also reinstalled my center console/hvac cover - which I paint matched Graphite Grey... and mounted a flipdown cup holder to the right hand side. Looks awesome!
Pictures Saturday morning... I'm washing the floormats right now and think I'll try to do the sewing thing with the Lotus Sport patches before snapping pix...
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
Supercharged 2005 Graphite Grey Lotus Elise: 230whp, 1843lbs. 12.41 @ 110.0 mph.
300whp @ 1799lbs. or bust!
darkSol is offline   Reply With Quote
Old 01-04-2007, 11:19 PM   #23 (permalink)
Probably Lurking
Keeper's Avatar
That's 1.6% heavier than your initial estimate. I'm cancelling my order.
Keeper is offline   Reply With Quote
Old 01-06-2007, 08:26 PM   #24 (permalink)
peck555's Avatar
Originally Posted by Keeper
That 1.6% heavier than your initial estimate. I'm cancelling my order.
Old 01-06-2007, 09:15 PM   #25 (permalink)
Probably Lurking
Keeper's Avatar
I think I'll try to shed 0.03% of my body weight instead.
What are people using for adhesive?
Old 01-06-2007, 09:17 PM   #26 (permalink)
very dude
BrianK's Avatar
Not that it much matters, but I got some air2gel for the dune buggy... They convinced me to get the higher impact stuff which turned out to be a mistake. Not very comfortable at all - it's like sitting on cardboard.
So - I recomend the normal air2gel for all applications that involve your butt.
Time flies like an arrow. Fruit flies like a banana.
BrianK is offline   Reply With Quote
Old 01-22-2007, 12:16 PM   #27 (permalink)
Bump for adhesive, I'm getting ready to attack this project myself.
RegGuy is offline   Reply With Quote
Old 01-22-2007, 12:41 PM   #28 (permalink)
I friggin' love coloring!
Brian 111's Avatar
originally posted by Brian 111:
A few other details:
I used contact cement for the final assembly of my foam, the reattachment of the lumbar support and the leather. The upholstery was reattached with double-stick carpet tape. It will allow easy removal of the leather in case I want to tweak the seats later.
Pull the leather towards the center of the seat when reattaching it after moving the bladder. It will prevent wrinkles on the side bolsters.
I found that UPS type packing tape worked best to position the foam in place when experimenting. It comes off easily without damaging the foam, unlike duct tape, and holds well, unlike masking tape.
I used contact cement from a bottle with the brush attached to the cap because I could put it exactly where I wanted it. If you want to mask the seat and use a spray, 3M Super 77 will work well. I used it on a 914 restoration on large panels.
Brian 111 is offline   Reply With Quote
Old 01-22-2007, 12:51 PM   #29 (permalink)
OK, so maybe Keeper and I should read. Thanks for the repost of the info.
Old 01-22-2007, 01:45 PM   #30 (permalink)
Probably Lurking
Keeper's Avatar
LOL. I saw that, but was really looking for something specific that one could just ask for at the hardware store. Carpet tape, I have. Is all contact cement the same?
(I'm trying to idiot-proof this mod in post 17.)
Old 01-22-2007, 01:50 PM   #31 (permalink)
Brian 111's Avatar
I think everything labeled as Contact Cement is the same. Hardware store, Home Depot, Staples... it's always worked the same for me.
Old 01-22-2007, 02:07 PM   #32 (permalink)
Contact cement is much the same, there are two kinds, the latex and solvent based. The latex based can loosen if it gets wet, I'd tend toward the solvent based. It'll need a bit of time to not smell, but it'll be stronger over all.
Now if you haven't worked with contact cement, it means what it says, it bonds on contact. You get no second chance. If the piece bond crooked, they will stay crooked.
Use flat pieces of wood to separate until they are lined up and gently remove the wood separators and let the pieces come into contact. Press and you are done.
Contact cement is applied to both surfaces, a thin coat will do and when it is clear and dry you are good to go.
Old 03-01-2007, 03:14 PM   #33 (permalink)
Probably Lurking
Keeper's Avatar
Apparently, there's some variation in what people are going with. From my understanding of my call with Kemmler:
According to Kemmler, Owners are generally using the 1/8" tan HD padding (double abraded for easy gluing on both sides)
Then one of the three:
  1. 3/8" Tan HD (recommended by Kemmler and demonstrated by Brian and the most common route for owners according to Kemmler)
  2. 3/8" White (softer, not recommended by itself by Kemmler)
  3. 3/8" Tan HD + 3/8" White (Kemmler suggested several have gone this route)
Any feedback from those who have performed this mod and tried the different setups?
Old 03-02-2007, 12:19 AM   #34 (permalink)
The Mad Scientist
darkSol's Avatar
I did option #1 - Tan 1/8" and Tan 3/8"
It's awesome!
d.a..v...i....d
Old 03-02-2007, 11:49 AM   #35 (permalink)
#334
Chococar's Avatar
I used duct tape & it is holding up great.
Old 03-03-2007, 06:56 AM   #36 (permalink)
Nick's Avatar
On adhesives
Found this website recently - here is the part on Adhesives
http://www.mcmaster.com/
About Adhesives
Definitions
Shear Strength— The force required to break items apart as they slide over one another.
Tensile Strength— Pulling force required to break items apart.
Types
Metal-Filled Epoxies (pages 3288-3289)— Uses: Bonding, sealing, plugging, patching, repair, and rebuilding worn and eroded metal back to original dimensions. Also called liquid metals, these are similar to regular epoxies with the addition of powdered metal fillers. They bond iron, aluminum, brass, ceramic, glass, and some plastics. Reach full strength relatively slowly, but can be machined afterwards. Nonrusting and resistant to most chemicals, water, and temperature.
Epoxies (pages 3290-3295)— Uses: Bonding, filling spaces between surfaces, laminating, and encasing items in adhesive (potting). One-part and two-part adhesives provide high-strength bonds to metal, rubber, fiberglass (FRP), urethane, wood, glass, ceramics, concrete, and some plastics. Time required to reach full strength can range from a few minutes to several hours. Good resistance to high temperatures, solvents, and impact. They're useful for filling spaces between surfaces when parts don't fit well.
Two-part epoxies require mixing, which begins the strengthening process and results in limited time to apply after mixing.
Acrylics (pages 3291-3292)— Uses: Bonding. These two-part and two-step adhesives begin to harden within minutes (sometimes seconds when used with an activator) and provide high-strength bonds; especially good for plastic to metal, rubber to metal, and plastic to plastic. Acrylics are more tolerant of moisture and oily, dirty, and unprepared surfaces than super glues. They're also good for filling spaces between surfaces, but not as good as epoxies. Two-part acrylics require mixing. Two-step acrylics don't need mixing, but are used with a primer/activator (usually a liquid) that's sprayed or brushed onto the surface being bonded.
Urethanes (pages 3291-3295)— Uses: Bonding. Urethanes form more flexible bonds than epoxies and acrylics, and are often used on films, foils, and elastomers. They bond well to metal, rubber, PVC, polycarbonate, and especially wood. Time required to begin to harden ranges from a few minutes to 48 hours.
Super Glues (pages 3296-3299)— Uses: Bonding closely mated parts where exposure to weather is minimal. Also referred to as cyanoacrylates, crazy glues, super bonders, and instant adhesives, these one-part adhesives begin to harden very quickly. They adhere to a wide range of substrates including rubber, plastic, and metal. Not recommended for use on glass. Viscosities range from water-thin liquids to gels. Super glues are not good for filling spaces between surfaces and have poor resistance to impact, temperature extremes, moisture, and solvents. A white residue called blooming can sometimes form on the bond.
Anaerobics (pages 3299-3303)— Uses: Locking threads, sealing, gasketing, bearing retention, and bonding/retaining cylindrical assemblies. Also called threadlockers and retaining compounds, anaerobics reach full strength in the absence of air and the presence of metal, such as when confined between the threads of a nut and bolt assembly. Bonds can be permanent or not, as needed. Excellent resistance to solvents, water, weather, and temperatures up to 400° F. They reach full strength rapidly at room temperature and come in various viscosities. When combined with other materials, they can be used as a sealant for pipe joints and threads. They have limited use for filling spaces between surfaces.
Silicones (pages 3304-3305)— Uses: Low-strength bonding, sealing, filling spaces between surfaces, encasing items in adhesive (potting), and gasketing. Most are one-component room-temperature vulcanizing (RTV) liquid rubbers that keep their rubber properties under almost any conditions. They reach full strength in 24-72 hours through exposure to moisture in the air. Excellent resistance to temperature extremes (-60° to +450° F), as well as chemicals, UV radiation, ozone, and weather. Silicones make great gap fillers and sealants for low-stress applications. They adhere to rigid and flexible substrates including metal, glass, fiberglass (FRP), cement, canvas, rubber, plastic, ceramics, and wood. Since they don't run, they're good for vertical and overhead applications.
Construction Adhesives (pages 3307-3308)— Uses: Installing paneling, drywall, foam, and flooring. Also called panel adhesives. Made of a viscous formulation of natural or synthetic rubber in a solvent or water carrier. They begin to harden quickly, are excellent for filling spaces between surfaces, and remain flexible when dry.
Contact Cements (pages 3309-3310)— Uses: Laminating and bonding. Made of synthetic rubber (usually neoprene) dispersed in a solvent or water, these cements form permanent bonds. Apply to the two surfaces you want to join and let air dry. Then, bring the surfaces together—they'll stick instantly.
Hot Melts (pages 3311-3312)— Uses: Bonding, sealing, filling spaces between surfaces, caulking, packaging, and parts holding for nailing and other final assembly. These thermoplastics melt when heated and solidify as they cool. Ideal for rigid-to-flexible, low-strength bonds that begin to harden quickly. They're excellent for filling spaces between surfaces. Good adhesion to most substrates, especially porous surfaces such as wood, paper, and leather. Hot melts have low solvent resistance, limited temperature resistance, and require dispensing equipment such as glue guns.
Other adhesives and related products: For aerosol adhesives, see page 3310; for caulks, see page 3306; for caulk guns, see page 3313; for adhesive dispensing tools and accessories, see pages 3314-3316.
Nick is offline   Reply With Quote
Old 03-03-2007, 08:31 AM   #37 (permalink)
Brian 111's Avatar
It's awesome!
+1
The tape I used appears to have been installed yesterday, but the work was done about a year ago.
Old 03-08-2007, 01:12 PM   #38 (permalink)
coulthard fan's Avatar
Seat Rebuild with Kemmler Air2Gel Foam
  • (1) 1/2 roll of 3/8" Shocktec Air2Gel HD (Tan)
  • (1) 1/2 roll of 1/8" Shocktec Air2Gel HD (Tan)
OK, I'm confused. I thought Brian got the non-HD 1/8" Shocktec Air2Gel (White)???
Scott
Red 2005 Elise - www.tax-whistleblower.com
coulthard fan is offline   Reply With Quote
Old 03-08-2007, 01:20 PM   #39 (permalink)
with future lotus driver
Conan's Avatar
Images: 24
regarding the leather: Just pull it off and glue it back on?
"Driving involves 3 basic abilities: Accelerating, braking and turning. More power will only help acceleration. Lower weight helps all three."
2006 BRG Lotus Elise, 1986 Porsche 944spec race car, 2001 Chevy Silverado 6L 2500 HD (tow vehicle), 2007 Honda Odyssey (the wife's)
Conan is offline   Reply With Quote
Old 03-08-2007, 04:36 PM   #40 (permalink)
Brian 111's Avatar
Scott, you are correct. I was looking at the sizes only, not the HD/color in Keeper's post.
Not HD; tan 3/8, white 1/8 as in my pictures. My butt found the standard foam (just right) to be superior to the HD (too hard).
HTML code is On
