First glance it looks great, trying to figure out what goes where and how still. It looks like that the external gate screws in with three polished screws over the leather boot on it's base. The E brake handle is easier, the shift knobi is only the top half not the whole sphere of the shift knob.
![]() Babak Club111 Central Plains Coordinator '05 Elise - Touring, HT, StarShield '99 Ducati 996 Bip '05 Freelander SE |
Meow!!
OK Bobby, we need:
- to know where you purchased it (Behlmanns?) - how much it cost - how long it took - some good BEFORE installation pictures... More details dood!
David,
--Got it from Behlmann's --Cost around 190ish --It is the first one they ordered so it took longer, ordered it when I went for my 1200 mile service last month. But now they're going to stock them. --Will do photos, don't plan on installing it until after my boards in mid april.
Ridge Man
I remember the tech guy at Valenti saying that he would have to glue
the lower edging of the boot to the internal (not visible) base of the unit. Also, make sure you go through all the gears with the plate temporarily set in place.....including reverse. This will guaranty the allowance for proper spacing during (gear shift) throws. |
#8 (permalink) | |
YMMV I would hate to see someone break off the threaded part of the shaft. It is only about 7mm. Greg
Aubergine/Black, Touring, Sport, and Hardtop |
#9 (permalink) | |
type oil filter wrench. Don
'' I always tell my students to follow their bliss- where the deep sense of being is from, and where your body and soul want to go''. Joseph Campell |
#10 (permalink) |
So I'm reviving this thread back from the dead. I bought the interior kit and was wondering if any of you had pics or install tips or instructions. Mainly concerned about the gate.
#11 (permalink) |
A couple things:
--I glued the retaining bolt/plugs under the console, this helped quite a bit. --The boot will not fit under the gate. I ended up taking off the hard plastic rim for the boot and glued it. --The single bolt on the bottom part is for looks only so don't worry about it. If I were going to do this again I would do this: --Pull out the boot, and strip the round plastic thing off the boot --Leave the console in place --Mark your holes and drill them out. I used progressively larger bits to not stress the plastic --Glue the bolts under the holes --Glue the boot to the bottom of the shift plate --Screw it in place.
#12 (permalink) | |
#14 (permalink) | |
Ridge Man
has difficulty remaining tightly secured. Another problem is that when shifting to 5th or 6th, wearing out of the leather begins. Lotus has changed the boot leather for me once but the second one they installed is also having a problem. I believe the design of the shift plate is a poor one and was told by Manhattan Motors that it tends to move to the right when shifts into 5th and 6th are attempted. They told me that Lotus is working on a replacement design but I haven't heard anything for a few weeks now. |
#16 (permalink) |
Ridge, there is a solution. I had my shifter centered by adjusting the cable (had the dealer do it) this helped with the issue greatly. Now the leather is not crushed against the Also, taking out the slack in the leather seems to help. The dealership had theirs blued to the bottom of the hole in the console, I'm thinking of gluing it to the bottom of the shift indicator plate thus reducing the slack more. At this point it's just free floating in the hole and is actually kind of OK. One more thing. I turned the boot sideways so that the long axis is left/right thus the excess is not pushed against the teeth of the plate.
#17 (permalink) | |
Ridge Man
was an adjustment recently done to where the actual shift rod sits. I do notice however that when I throw into 5th of 6th, the plate actually moves slightly to the right. I was thinking that Lotus would file down the right-side edging of the opening, allowing our 'heavily leaning to the right' shift motion (in 5th & 6th) to not come in contact with the metal plate, but don't relly know what fix they are pondering? Makes no sense that the third screw, at the base of our tri-pod screw-down set up, has nothing to attach to. |
