Old 04-18-2009, 07:05 AM   #141 (permalink)
Meow!!
darkSol's Avatar
Any update on the LEDMOD.com place?
Are there new faces available? - didn't see anything Elise stuff for sale...
After driving around for a bit with my iPhone face up on top of my steering column and seeing how nice it illuminated the cluster I'm thinking about doing what the gent on page 1 did with the blue LED's... but use very small 10mm cool white LED string to line the perimeter of the cluster... and tie into the brightness controller on the board of course.
Here's a picture of one iPhone lighting up from one side while another takes the picture
Just a thought...
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is offline   Reply With Quote
Old 04-20-2009, 03:10 PM   #142 (permalink)
Phantom Elise
polojcp's Avatar
wow~~
How did you get that in there?
I want that!
Thanks!
Some pics just today...
Negative boost is just showing vaccum at idle...
I've got several different screens to toggle through that show things like TPS, AFR, etc... Kind of fun and very informative... Great contrast in the light and at night too...
All this is very easy to reduce back to stock form if need be. But why would ya
First two pics are in the sunlight and the last is at night.
Best,
Phil
07 Elise Phantom Black
polojcp is online now   Reply With Quote
Old 04-20-2009, 03:56 PM   #143 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Takes a little work and some creativity, but nothigh extreme. Just take your dash apart and go to town. Several people have installed dashes similar to the one I use and I think everyone invented their own strategy to mount it...
Good luck,
Phil
Old 05-07-2009, 12:36 PM   #144 (permalink)
norazz
speedo failure
Originally Posted by clopi2000 View Post
It is very easy. You take the complete cluster out of the car (10 minutes and 10 screws to remove). The protective plastic face is slightly glued with a rubber adhesive. You have to insert a sharp knife on the edge, and gently pull it away. You then carefully pull the needles out, the 2 small plastic bushings, et voilą !
Can you pls help? I own an Elise Mk111S K-Eng. and lately the speedo needle froze at 0. Also, the tripster and mileage counter stopped functioning. Could all this be because reset button was pushed when car was in motion? I did try the following: 1) Open driver's door. 2) Press and hold reset button. 3) Turn on ignition.
All that did not solve anything.
Your help will be appreciated.
Norman
P.S. I can be contacted on: npanpa@maltanet.net
norazz is offline   Reply With Quote
Old 05-14-2009, 01:03 PM   #145 (permalink)
Meow!!
darkSol's Avatar
Just realized that I never posted an electroluminescent panel picture from 2+ years ago...
Just took this pic in the garage (doors closed)...
Much brighter than stock - like an electric banana color
d.a..v...i....d
