Old 09-15-2009, 05:45 PM   #1 (permalink)
Turn signal headlight eyelet detached and flew out of place on highway...
Was driving along on the highway this morning and I suddendly saw my turn signal headlight fly up - it was dangling from the wire, dancing back and forth scratching my front clam as it did.
I did a sudden 3-lane change to get over to get to the shoulder as soon as possible.
See pics to see what I found - it completely detached....
Anyone know what went wrong?
And more importantly - does anyone have any clever suggestions on how to get it back in there so it STAYS(!) there permanently?
NorCal is offline   Reply With Quote
Old 09-15-2009, 05:55 PM   #2 (permalink)
GR8 SCAPE
waydui's Avatar
Unfortunately, it's one of those things!
Well, maybe not all, but the retaining tabs are notorious for not holding the lights in place.
I always tape mine down when running AutoX or other extracurricular activities.
I filed excess flashing from the tabs as well as cleaned up the fiberglass areas on the car so that the tabs could seat properly. If the tab doesn't have a solid "click" sound when you install it, I would take it out and file some more to get the required clearance for the tabs to grab properly.
Also some tabs break off or crack, so make sure yours are intact.
Regards,
Wayne
_______________________
Old 09-15-2009, 06:00 PM   #3 (permalink)
I just checked and the white plastic tabs on the headlight are in fact intact. The fiberglass they seat into also looks fine.
Anyone have a clever way of getting them to stay in there "permanently"?
Old 09-15-2009, 06:17 PM   #4 (permalink)
GR8 SCAPE
waydui's Avatar
OK, here are a few links to threads where they made some mods to fix the problem.
You can choose which one works best for you.
Links: First warranty claim = BS
Lights Popping Out
Lotus Elise Maintenance, Indicator Lens Installation
Good luck.
Regards,
Wayne
Old 09-15-2009, 06:20 PM   #5 (permalink)
not to insult you, but maybe you could take a pic of the other end of the turn signal that we can't see...
I've replaced turn signals 3 times...always because a tab breaks...and sometime it breaks pretty cleanly--so much so that it looks like it was made that way. there's only one time that it popped out and wasn't broken.
while waiting for a new assembly to be shipped to me, I've either removed the lens and light bulb or wired the lens in place through the small hole in the front of the car (the one that you put a screwdriver in if you are removing the lens to change the bulb)
2005 Elise, Ardent Red, Sport & Touring, Stage 2 Exhaust, Reverie CF Intake
2003 Audi RS6 (chipped! 520hp/500lb/ft)
2004 C320
2000 Wrangler
thewb2001 is offline   Reply With Quote
Old 09-15-2009, 06:54 PM   #6 (permalink)
06 elise
MNlotus's Avatar
happened to me too....
2006 Lotus Elise-way too many mods to list (k24 swap planned. 300+whp)
http://www.youtube.com/watch?v=tjIcCsvhWvY
2003 Caterham Super Seven DeDion
http://www.youtube.com/watch?v=Z1ysO...e=channel_page
MNlotus is offline   Reply With Quote
Old 09-15-2009, 07:07 PM   #7 (permalink)
AKA XHILR8N!
BRTHTAKR's Avatar
Images: 6
Has happened to me too. This is the stuff that separates us from soft sports car people who drive P cars and ricers.
Simplicity is the ultimate sophistication. Leonardo Da Vinci
2005 Elise LRG, Trim Shop interior, full cage, Cup wheels, other stuff.
2007 Toyota Tundra (about 10 cup holders)
2004 BMW X3 (4 small cup holders)
1980 Rover SD1
BRTHTAKR is offline   Reply With Quote
Old 09-15-2009, 07:39 PM   #8 (permalink)
CVeRiTy's Avatar
Ironically, these are a PITA to get off when you actually want to in order to change the bulbs.
CVeRiTy is offline   Reply With Quote
Old 09-15-2009, 08:43 PM   #9 (permalink)
cdn_alien's Avatar
Mine broke the first week of ownership. Broken clip. I put a few small dabs of crazyglue to hold it down temporarily until I could get it back to the dealer. They asked "Is it holding?", I said yes, and he said "Oh good, leave it!". Three years later, it's still holding! I'm just glad the bulb hasn't burned out
Current: '06 Chili Red Elise, '06 Infiniti M35
Sold: '03 Nissan 350Z , '00 BMW 325Ci, '99 Miata, '90 Miata
cdn_alien is offline   Reply With Quote
Old 09-15-2009, 08:49 PM   #10 (permalink)
Grrrrrr Baby
Dmbrown34's Avatar
insert a screw driver from the front and push the tab forward and it pops out. Usually isnt to hard.
While the light is out its a good idea to check to see if your coolent is leaking. They have been known to leak a little by the driver side. If its leaking you just have to tighten up the clamp.
2005 Lotus Elise LSS
2003 Corvette 50th Anniversary Convertible
Dmbrown34 is offline   Reply With Quote
Old 09-15-2009, 09:11 PM   #11 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
Been there done that! mine scared the **** out of me just cruising down the highway! I lost the rubber gasket around the lens while it was flipping around on the clam!!!
I usually track like this now!
It actually popped out on the way to this track day - If you look close you can see that there is no gasket on the drivers side turn lamp under the tape!
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's!
ZTEC is offline   Reply With Quote
Old 09-16-2009, 08:40 AM   #12 (permalink)
glb
Unattractive Nuisance
glb's Avatar
a tiny bit of clear silicone seal works, unseen.
Old 09-16-2009, 11:49 PM   #13 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
is it? I don't see the hook at the end of the plastic tab.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 09-28-2009, 07:32 AM   #14 (permalink)
SouL's Avatar
This happened to me last night.
Thankfully I was near work and I could drive over to pick up some tape to hold the light down on the way home.
A broken tab caused the failure.
shay: The tab is actually on the other end of the turn signal. The point facing the road, not in the picture.
SouL is offline   Reply With Quote
Old 09-28-2009, 08:57 AM   #15 (permalink)
#101
AgentTripleX's Avatar
I will say this has happened to me at least a dozen times. One of the times it scratched my starshield and I had that replaced fortunately by my insurance. The last time it happened I was out of warranty and it cost me over $200 to replace. One time the dealer broke it during bulb replacement as well and still charged me for the replacement casing since they warned me that breakage was a possibility. It's a poor design by Lotus unfortunately.
http://www.facebook.com/SPRVXN
www.twitter.com/autoVXNS
http://sprvxn.tumblr.com/
"We always deceive ourselves twice about the people we love - first to their advantage, then to their disadvantage." Albert Camus
"The refusal to choose is a form of choice; disbelief is a form of belief." Frank Barron
AgentTripleX is offline   Reply With Quote
Old 09-28-2009, 09:11 AM   #16 (permalink)
'010
Minnis's Avatar
Images: 1
fill them in and LED it
Minnis is offline   Reply With Quote
Old 09-28-2009, 09:48 AM   #17 (permalink)
2007 Exige S
robains's Avatar
This is how I fixed the problem. Survived a track day and some wicked vibration from rubber build up on my Hoosiers.
Rob
Old 09-28-2009, 10:39 AM   #18 (permalink)
Cthulhu's Avatar
My driver's side turn signal would always pop out. I thought that I got it to click in, finally fixing it, a few times. If you pull out that piece of rubber cord to just the right length it usually holds.
When my car got totalled the driver's sider signal stayed in. But the passenger side one, which had never come loose before, popped out, as if to mock me.
2009 135i - Montego blue/Coral red.
2007 Lotus Exige S (deceased) - Storm Titanium.
RIP SCCVC11127HL80723
May the roar of your supercharger forever shatter the serenity of the heavens <3
Cthulhu is offline   Reply With Quote
Old 09-29-2009, 12:36 AM   #19 (permalink)
Form and Function
plastique999's Avatar
+1
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 11-19-2009, 11:56 AM   #20 (permalink)
AW07LE's Avatar
Images: 5
Originally Posted by plastique999 View Post
+1
Where can you get LED front turn signal bulbs? I can't find them anywhere. I bought 3 sets and it was all the wrong bulb (got bulb #s from people's posts here). Anyone know the correct bulb number? I prefer the color to be white or yellow (I'm not a fan of the amber).
AW07LE is offline   Reply With Quote
