Elise Driver
TWRD wide scoops onto Elise via nci
i just finished installing a set of twrd scoops for a customer of the nci no drill mounts for the elise.they are a little more than an inch wider.the fit is pretty good.i will post some pics of stock verse twrd and the machined stand offs for the brackets.im also working on the exige lower mount that takes the stock one out of the airstream.its the same as the elise just used for the front lower mount.this one will be setup for the wider scoop so it does not need the stand off.
rls west~nci motor sports fabrication Last edited by kmt63 : 06-27-2009 at 02:56 PM. |
damn this signature stuff
Is it me or are the scoops crying out for mesh to hide the gubbins inside?
08 Elise SC, Ardent Red. Factory spots. V1 remote display. Matt G's V1 mount. Sector 111 Bootie. Black badges from BWR and SweetDaddyD. Bane's Stealth bulbs. LETSLA. |
#7 (permalink) | |
User Restricted By ΑDMIΝ
Also, what are the thread specs of the standoffs? I believe the OEM mounting hardware is 5mm diameter and 0.8mm thread pitch...
#8 (permalink) |
really light stuff
![]() Join Date: Jul 2003
You can get the scoops from TWRD and the adapter kit from RLS / NCI.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel |
#10 (permalink) |
really light stuff
Oops, missed that. Kevin is doing an Exige-specific wide scoop kit too.
#12 (permalink) |
Elise Driver
yea its 5milx.80 pitch.as for the stand offs for the exige i will need someone to measure an exige with the wide scoops held up to the car with a caliper.was it you that got the first set of the wide scoops?im also doing the lower bracket for the exige.so you can take off the factory one to get it out of the airstream.i did a set for thomas for the stock exige scoops.im waiting to see how they work out then i can make the wide set.
rls west~nci motor sports fabrication |
#13 (permalink) |
Elise Driver
yea your right about that.i did check and there is one spot that is a bit tight.between the bracket and the body.but it will fit.the scoop opening in front is a tad over 3 5/8 inch.stock 2 5/8 inch
#14 (permalink) |
Elise Driver
i can do the exige kit two ways.the cheaper version would be 6 stand offs.then the better setup would be the 4 upper stand offs that thread into the upper mounts.then the lower bracket would be like the elise kit.only used for the lower mount.you take off the stock exige bracket.so then you have a clear opening for ducting air where you want it.
#15 (permalink) | ||
#17 (permalink) |
Elise Driver
apk919.that is a nice setup you have.is that ducted to the ic?the measurements that i need are with the scoop held to the car so the fit is good.take the tail of the caliper and insert it into the hole down to the cars mounting point.the scoop thickness is around .070 thick so when i take that off your measurement i have the stand off distance.so record the measurement to each hole.also if they would mount to those nut clips.then measure the thickness of that clip.so i can take that off too.thanks for your help on this.
#18 (permalink) | |
What if I measure the height of my standoff brackets? Is that effectively the measurement you're looking for? I'll measure the thickness of the clips as well.
#19 (permalink) |
Elise Driver
yea you could do that too.if the scoops fit well like you have it there.it looks like the tail that meets the body near the bottom.looks a bit out from where a stock set would set.i have been setting the scoops with that just touching the indent in the body.if you can take the time to give me some accurate measurements i will send you a set of stand offs for free.you pay shipping if that works for you?
#20 (permalink) | |
I'll take measurements later today... I'll even tweak the adjustment of the lower bracket for a closer fit... I had been holding off until the ducting tests were completed.
