Old 07-08-2009, 07:47 AM   #41 (permalink)
Elise Driver
kmt63's Avatar
Images: 2
this set of grills are for sale.gloss black powder coat.60.00$+shipping.
rls west~nci motor sports fabrication
kmt63 is offline   Reply With Quote
Old 07-08-2009, 08:17 PM   #42 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
kmt63's Standoffs
Kevin sent me a set of his standoffs, and I've checked their fit with the TWRD scoops.
First... the holes I drilled in the TWRD side scoops were intended to be used with a set of aluminum brackets that I fabricated myself. That means I could control standoff distance, and both vertical and horizontal placement. I did this because I wanted maximum flexibility in fitting the scoops.
If I were using standoffs instead, I would have mounted the standoffs first, and then used their positions to determine the proper location of the holes to be drilled in the scoops.
That said, the standoffs should be a great solution. I've posted some pictures of the fitment process.
Pics:
1) Standoffs mounted in the stock Exige scoop mounting holes
2) Same as above, different angle
3) Scoop mounted with standoffs... as explained above, the lower hole in the side scoop was not aligned closely enough with the lower standoff to make use of it. But you can see that the height of the standoffs give the TWRD scoops a close fit to the OEM scoops.
Old 07-08-2009, 08:25 PM   #43 (permalink)
Elise Driver
kmt63's Avatar
Images: 2
thanks for posting andy.the fit from the side of the car looks good.
Old 07-08-2009, 08:30 PM   #44 (permalink)
apk919's Avatar
Images: 20
Yes, I think this will work well for Exige owners looking to fit the TWRD scoops.
Old 07-12-2009, 08:11 PM   #45 (permalink)
xziteme's Avatar
Freshly installed...
xziteme is offline   Reply With Quote
Old 07-13-2009, 09:06 AM   #46 (permalink)
xziteme's Avatar
A few more pics...
Old 07-20-2009, 03:45 PM   #47 (permalink)
Looks great. Where are you ordering these from?
MeLease Offers
bcee is offline   Reply With Quote
Old 07-20-2009, 05:44 PM   #48 (permalink)
Elise Driver
kmt63's Avatar
Images: 2
pm user name knucklehead here on the forum.if you are installing onto an elise you will need the nci bracket kit from really light stuff.if going onto an exige you will need the stand off kit also from really light stuff.i can also provide the grills for the wider scoops too.
Old 07-20-2009, 09:00 PM   #49 (permalink)
TWRD & Blip advertising
knucklehead's Avatar
OMG I love the x-ray view of the bracket through the scoops. Thanks Phil they look great.
Jacob
Join Lotuscar.ning.com for LA Lotus social events
05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels
knucklehead is offline   Reply With Quote
Old 09-02-2009, 07:23 AM   #50 (permalink)
Elise Driver
kmt63's Avatar
Images: 2
bump
