Old 04-28-2009, 03:56 PM   #21 (permalink)
TWRD & Blip advertising
knucklehead's Avatar
Originally Posted by xziteme View Post
Jacob,
Are there any plans for an Elise version? I could use a little more air flow.
Yes there are. Andy Chan is figuring out how to use brackets and the stock plastic Elise grill to mount them. The piece is the same and fits perfect. I know you need a set and as soon as he figures it all out I'll be calling you.
Jacob
Join Lotuscar.ning.com for LA Lotus social events
05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels
knucklehead is offline   Reply With Quote
Old 04-28-2009, 03:58 PM   #22 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
Originally Posted by Bgwilly31 View Post
whats everybodys beef with the factory side scoop mesh>?
Ive heard of people removing it a few times now. . .
It's much finer mesh than the radiator or hatch mesh... the thinking (and I think some people have actually datalogged this) is that the engine runs cooler under high load when there's no mesh on the side scoops.
Old 04-28-2009, 04:22 PM   #23 (permalink)
I've heard from owners who have deleted the mesh from their scoops and they've seen a reduction of 10-15 degrees. I think it looks better with the mesh, but to me it wouldn't be worth it.
Jacob
Old 04-28-2009, 05:06 PM   #24 (permalink)
Jack's Avatar
Jacob has it correct but it's less than 10-15, at least on my Cup car -- we saw about 5-7 degree reduction.
Jack
'07 Exige Cup 255
'08 2-Eleven
Old 04-28-2009, 05:07 PM   #25 (permalink)
Jack's Avatar
Originally Posted by apk919 View Post
You may have seen a sneak peek of the scoops here: EXIGE PHOTOS
I acquired this set through Jacob (Knucklehead); they have at least 50% more frontal area than the stock Exige side scoops, and of course they extend outward into cleaner air as well. I'm planning on using the extra intake area to test a set of supplemental intercooler air ducts (no I haven't started any work on that yet...).
More photos:
Andy,
Looking good and they can double as air brakes.
Jack
'07 Exige Cup 255
'08 2-Eleven
Old 04-28-2009, 05:11 PM   #26 (permalink)
apk919's Avatar
Images: 20
Originally Posted by Jack View Post
Andy,
Thanks! Believe it or not, they do not stick out as far as the rear wheel arch. I'm hoping I can trade off a little drag for lower intercooler and engine temperatures (and perhaps avoid the spark retard that comes with heat soak).
Old 04-28-2009, 05:14 PM   #27 (permalink)
xziteme's Avatar
xziteme is offline   Reply With Quote
Old 04-28-2009, 06:25 PM   #28 (permalink)
Jack's Avatar
Sounds good to me ... if it works, I'll be right behind you.
Jack
'07 Exige Cup 255
'08 2-Eleven
Old 04-28-2009, 06:40 PM   #29 (permalink)
Form and Function
plastique999's Avatar
I have no mesh on mine...as mentioned more air flow....
Andy, leave the mesh off...looks very clean IMO
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
plastique999 is online now   Reply With Quote
Old 04-28-2009, 07:04 PM   #30 (permalink)
apk919's Avatar
Images: 20
Hmm... I might have to test for airflow with and without a (coarser) mesh. I'll know more once I start testing the inlet ductwork. I'll probably post in this thread: 2007 Exige S Intercooler Air Flow Study
Old 04-28-2009, 09:16 PM   #31 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
Mine also runs about 5-10* cooler, but i don't have a rear panel anymore either. My last drive in the canyons I was seeing 181 when usually I'd see 187/189 on a mild day. Now next step with these as andy said is to try and lower IAT.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 04-29-2009, 10:10 PM   #32 (permalink)
06 elise
MNlotus's Avatar
i like it, but i think that support bracket is very ugly
2006 Lotus Elise-way too many mods to list (k24 swap planned. 300+whp)
http://www.youtube.com/watch?v=tjIcCsvhWvY
2003 Caterham Super Seven DeDion
http://www.youtube.com/watch?v=Z1ysO...e=channel_page
MNlotus is offline   Reply With Quote
Old 04-30-2009, 04:08 AM   #33 (permalink)
apk919's Avatar
Images: 20
You mean the black one? That's the stock support bracket for the OEM Exige side scoops. I'm not thrilled with it either (I wouldn't have designed it to block airflow), but if I remove it then there's no going back to stock. On the other hand, if these become available: No drill mounts for Exige scoops onto Elise, I'll probably lose that bracket.
Old 04-30-2009, 05:51 AM   #34 (permalink)
lotusforsale's Avatar
Images: 8
Make any in fiberglass? Would paint body color anyway (not a fan of the CF look, my cup roof is body color CF), and the few grams difference in weight aren't going to help my car go faster, the limiting factor is the driver.
lotusforsale is offline   Reply With Quote
Old 04-30-2009, 07:00 AM   #35 (permalink)
Sports Cars
Vampyre's Avatar
I like them better then the stock ones... Seems to be most do..
2006 Chili Red / Touring / LSD / TC / Forged Wheels / Hard & Soft Top / Lifestyle Paint / Desnorkeled / Odyssey Battery / Sector 111 Extinguisher Bracket / Sector 111 LidBone / CF Splitter / CF Bits / Lotus Stage 2 / Pure X
C3 Corvette 383 TPI Stroker 6.3 liters of Torque / 1976 MG Midget, fun run about / 2005 Mits Evo 8 ACD/SSL / Dodge Van for hauling stuff / http://www.photobucket.com/mygarage
Vampyre is offline   Reply With Quote
Old 04-30-2009, 08:43 AM   #36 (permalink)
Elise Driver
kmt63's Avatar
Images: 2
the no drill mount is designed to work on the elise.the exige has the upper fiberglass flange that comes out and the top two holes mount to this.all though my front lower mount could be used.it would just be used for the front lower mount.i could come up with a nice solution for the two upper mounting holes too.only problem i have with that is i dont have an exige to make the mounts from.maybe there is an owner near portland/vancouver area looking for the wider scoops.that wouldnt mind being the test mule?
kmt63 is online now   Reply With Quote
Old 05-31-2009, 10:37 PM   #37 (permalink)
xziteme's Avatar
Jacob,
PM me so I can get a set of these. (I just preordered the no drill mounting kit)
Old 06-05-2009, 08:32 AM   #38 (permalink)
'Justa' Exige 190
skottoman's Avatar
I noticed a small (2-3 degree) temp drop when I made new mesh for some CF side scoops. I would assume you could use this building technique for even larger mesh if you wanted to keep mesh, but improve flow.
Cheers,
Skottoman
How to: Exige Scoop Grills
2006 AR N/A Exige-Touring pack-Starshield-TopspeedPro1 exhaust-DeSnorked-Green filter-RTD ToeBrace-Shims Removed-CF Diffuser-CF Splitter-CF Wing-CF Scoops w/custom grills-Black Exige sticker-PC680 battery-S111 battery holddown-Rear Lotus badge-Carpet buttons-Painted shift knob-Painted Console-EBrake Gaiter-SilverStealth bulbs-Front S111 towhook-Polk speakers-Toyo R888s-Lamin-x turn signal tint
2008 BMW X3 with some mods
2006 Cayman 'S'
skottoman is offline   Reply With Quote
Old 06-09-2009, 08:38 PM   #39 (permalink)
shay2nak's Avatar
any updates with respect to running a hose to the intercooler?
Old 06-09-2009, 08:43 PM   #40 (permalink)
apk919's Avatar
Images: 20
Not yet... I still need to find something I can adapt (i.e. cut, mangle, deform, etc) to fit the ducting to the IC shroud, but I've got a few ideas. Headed back to Cali tomorrow, so I'm hoping to get back on it.
EDIT: Thinking of trimming a vacuum cleaner nozzle to fit the side of the shroud... something like this:
