GR8 SCAPE
Winter Project #1 - Engine Lid Grill Mesh
Time for another winter mod, replacing the black plastic slat grills on the engine lid cover with an aluminum mesh, à la Exige.
Tools and Supplies Summary: 1. Mesh from www.Customcargrills.com. I chose the Stacking Oval XXL Mesh. One sheet was enough to do the whole lid, with some left over. Maybe enough to do the side intakes, but not another lid. 2. Krylon Camouflage Ultra-Flat Black paint. Nice Matte finish, about 4-6 coats per piece of mesh. 3. Double-sided foam tape to hold mesh to underside of lid. 4. Rubber Mastic Tape to secure grill to lid. I made a "sandwich" of double-sided foam tape, mesh grill and mastic tape. Very solid construction and waterproof. 5. Hole Plugs, nylon locking to conceal/hide slat mounting holes on lid. I spray-painted the plugs black to blend in to the lid. I made a template for each opening, cut out the wire mesh with Dremel, painted mesh, applied tape as needed, attached mesh, fitted plugs to lid holes (20 holes in all!!). Pictures show installation process and final look. If nothing else, I saved some weight!! ![]() Regards, Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. Last edited by waydui : 03-02-2008 at 02:05 PM. |
GR8 SCAPE
Winter Project #1 - More Pics
More Pics from Mesh Grill Mod
Regards, Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
perfututum futūtor
Nicely done, Wayne. The only thing I personally would have done differently is screw it up
perfututum futūtor
With the stock Elise slats the rain water runs into the engine bay only at an angle, never straight in
#7 (permalink) | |
GR8 SCAPE
First, I don't drive the car in the rain (or snow either), it's a fair-weather toy. ![]() Second, when I wash the car, I put a towel over the engine bay so it absorbs the water. Anal, I know... ![]() I still have the original grills/slats, so I can change back quickly if needed. Regards, Wayne
#8 (permalink) | |||
anglophile in exile
![]() Quote:
- I should have also put in a ![]() The engine gets wet when it rains in either case ![]() |
#9 (permalink) |
I <3 chicken, I <3 liver
you guys don't at least wash the engine down a little?
#10 (permalink) |
Certified Fun Stopper
It goes straight in on the Exige and I've never heard of this causing a problem.
'06 Exige; Polar Blue; Track/Touring/Stage II/LSD-TC '05 Elise; Arctic Silver/Ruby Red (R.I.P) |
#11 (permalink) | |
Haxord but mine
![]() Looks great though, love the mastic tape, it really finishes up would could be a very rough edge. Thats almost what the Exige looks like, except I think they used some kind of an epoxy to finish the edges.
-David 2006 Storm Ti Exige + VF Stage 2 Vision Function Supercharger Install Thread Stereo Harness Info | Exige with no wing?? |
#12 (permalink) |
TWRD & Blip advertising
![]() Join Date: Jul 2004
The Exige doesn't block any water/rain. I have had one incidents where the car wouldn't start after a heavy rain. It probably was a coincidence, I think it was more of a battery issue since a jump solved the problem. The odd thing is that it never happened again. The car had just been driven from LA to SF two days before, so the problem was not from inactivity.
Great job on the mod!
Jacob Join Lotuscar.ning.com for LA Lotus social events 05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels |
#13 (permalink) |
Wayne
Very nice job! Do you have made pic's without the without towel on top of your engine? I'm very curious how it looks!
Enrico '06 Laser Blue/Magnolia Lotus Elise * BOE TVS SC * EFI * Lots of other things '07 Graphite Grey/Tan BMW 335i w/JB3 tune, Helix IC and BMS DCI |
#15 (permalink) |
GR8 SCAPE
I finally put the engine lid back on the car after installing new engine lid grills.
BTW, a helper really comes in handy when re-installing the lid. Be sure to align the lid with the lock mechanism before securing the bolts (Don't ask me how I know! )Here are some pics of the engine lid on the car. Regards, Wayne
#16 (permalink) |
GR8 SCAPE
A few more shots...
Regards, Wayne
#19 (permalink) |
Either that, or would you lend out the templates? I have the FF header and would love not only the look that the mesh provides but the straight shot heat evacuation path. Only thing is that I have vinyl stripes on the car (and, hence, the lid). I wonder if that would mess up the program. Great job!
Frank Amoroso Whatever Press Vehicle(s) I'm driving this week www.twitter.com/famoroso Ever take a risk? A real risk? The kind of risk that makes you feel alive? It's... spectacular, isn't it? |
