Go Back   LotusTalk - The Lotus Cars Community > Marketplace > Parts Market (non-commercial)
Old 10-10-2008, 04:20 PM   #1 (permalink)
15/16 SSR Competition Type C Rims and Toyo R888 Tires
In the spirit of selling, I am also offering my 15/16 SSR comp type C rims and brand new Toyo R888 tires. The two rear rims (16x7) are brand new in the box. The front ones (15x6.5) are used but in great shape. The rear rims weigh 11 lb each, and the front rims weigh 8.5 lb each.
I also have matching 4 brand new Toyo R888 tires. Never mounted. The rears are 225-45-16 and fronts are 205-50-15.
I am asking $725 shipped for the rims and $625 shipped for the tires.
keinayo is online now   Reply With Quote
Old 10-10-2008, 06:20 PM   #2 (permalink)
cokey's Avatar
ahh i love these rims.. bump for some great rims..
BMW steel grey 04' neon srt4 ???hp(will be a lot) ???ft lbs pulled the motor myself n rebuilt it.. got my baby back and its running strong. here for the love of the Elise, Exige and gaining the knowledge before I can get my own...
my car.. http://www.lotustalk.com/forums/f152...ny-pics-62883/
cokey is offline   Reply With Quote
Old 10-11-2008, 05:34 PM   #3 (permalink)
bump! Make offers
Old 10-12-2008, 09:41 AM   #4 (permalink)
driven's Avatar
higher mileage tires
I don't know where to go with this question. Is there a higher mileage tire available for the Elise without sacrificing all performance? I have had my car for 4 years now. I have only tracked it once and have gone through 5 sets of rear tires and one set on thr front in 30000 miles. I am on a budget now and need to stretch the life of the tires. I don't drop the clutch or ever get wheel spin. Thanks.
driven is offline   Reply With Quote
Old 10-12-2008, 08:11 PM   #5 (permalink)
Not a poseur anymore!
I always wanted those on my previous car.
May I ask what the offsets are?
07 Phantom Black Exige S - Touring Pack/Track Pack/TC/SS/BWR door sill protectors/Locking gas cap mod/Sticker City headlight film
300hpMR2 is online now   Reply With Quote
Old 10-13-2008, 04:59 AM   #6 (permalink)
Offset is 38 mm.
Old 10-13-2008, 06:53 AM   #7 (permalink)
I am using those wheel for track on my car.
The rear wheel fit easily, but a spacer of 3/8 is welcome, but for that, the bolt need to be longer.
For the front, it is a little bit more complicated. To install the wheel, the spacer will need to be quite thick, I guess around 3/4.
I am running with 3/8 spacer, but I machined the wheel inside to not have an extra wide front, with the risk of the tire touching the fender. My front caliper are at approximatively 1/16 max from the wheel.
Now, I have a set of modified one enlarge at 8.25 instead than 7. 8.25 is too wide, 8 should be the limit with 16 inches wheel. At 8.25, you really need heavy spring like Nitron Pro to limit the wheel travel in order to avoid contact between wheel rib with the lower wishbone. This is true for 8.25 wheel, but not a trouble at all with stock 7 inches wide.
The longer bolt can be purchased at
Chrome Lugbolts for BMW, M12 x 35mm - 60mm: Bekkers BMW & Mercedes Parts
Elise 2006, white, Katana
Europa 1969, green, H22A, 194 whp, 1550#
CONFIGTECH.ca / Solidworks
elise/europa is offline   Reply With Quote
Old 10-15-2008, 07:21 PM   #8 (permalink)
elise/europa, i'm a little confused by your post... i see these rims are et38 and stock LSS are et31 on the fronts... same width for both for the fronts, so i can see you need maybe 7mm spacer which is about 1/4" inch, but you mention needing 3/4" spacer? Can you give a little more explanation?
On rear rims offset is same for LSS and these wheels... but the width is .5" narrower for these rims... as i understand it your problem here is only because you have widened the rims so the stock rims.
DO these rims use the Lotus wheel bolts or different bolts? Are bolts included if they aren't the same as LSS bolts? also, is the "SSR" and "Competition" stickers that can be removed or are the under the paint?
ewalberg is offline   Reply With Quote
Old 10-15-2008, 07:26 PM   #9 (permalink)
OK, what I am going to do this weekend is put the tires on the rims, and install on my car. Then I catch two birds in one hand - have pictures on the car, and test fitment. I will then report back.
Old 10-19-2008, 06:06 AM   #10 (permalink)
Update
OK, the tires are on the rims, nice and blanaced.
First, I checked and the offset if actually 42 mm and not 38 mm as I thought.
I test fitted the wheels this morning, and here are the results:
Consistent with what was said above, the rears fit nicely, but you can add a thin spacer if you want.
The front do need spacers, not sure if 3/8 or 3/4.
They look cool and ready to go. Very light!
I will post more pics tomorrow.
Old 10-19-2008, 08:27 AM   #11 (permalink)
One other cool fact - the rear wheels plus tires save you 15 pounds each over stock ( I checked) and the front save 12 pounds each. That is a total of 44 pounds! Can't beat that.
Old 10-19-2008, 09:02 AM   #12 (permalink)
cant wait to see
05 GG elise, Red interior, HID's, LED's for every bulb, Von Hep exhaust, Panel Eliminator, custom intake, Micro mirror
06 300C with all the fixings
A7594217 is offline   Reply With Quote
Old 10-19-2008, 06:40 PM   #13 (permalink)
I was off line for few days.
The reason for the required spacer at the front is not caused by the offset, but by the deep of the spoke. Since the front brake are using opposed type caliper, it take a lot of room to clear it.
Like I said, not certain about the required spacer requirement, but for sure, more than 3/8 since I am using 3/8 on my car with modified (machined) rim. I have access to a lathe to machine the wheel myself. But for stock wheel, the spacer will be between 1/2 to 3/4. And of course, longer bolt will be required, and you don't have the choice, you need to buy it.
But the wheel look good, the choice of tire is great, and the wheel price are cheap.
Old 10-19-2008, 06:48 PM   #14 (permalink)
+1
Old 10-19-2008, 06:54 PM   #15 (permalink)
Here is a link to where you can get the longer studs:
Turner Motorsport: Table: Wheel Spacer Bolts (H&R and TMS)
Thanks Doug (AZReason)!
Old 10-25-2008, 04:42 AM   #16 (permalink)
Bump! willing to separate rims and tires (after spending $100 on putting tires on and balance). Make an offer. All you need is a pair of spacers in the front and longer lugnuts.
Old 11-02-2008, 03:25 PM   #17 (permalink)
Where are you located?
Old 11-03-2008, 07:33 AM   #18 (permalink)
trappertrevor's Avatar
where
[where are you located
trappertrevor is offline   Reply With Quote
Old 11-03-2008, 08:22 AM   #19 (permalink)
I am in NYC/NJ. I have a tentative buyer, so will inform if it falls through
HTML code is On
