FS: adaptor rings for 5-1/4" front speaker install
CNC machined black acrylic. Proper thickness for flush install of 5-1/4" speakers.
Fours speaker mounting holes drilled and tapped for included hardware. Standard 5-1/4" bolt pattern. Fits JL Audio for sure. See ring dimensions below. Remove original speaker. Remove metal ring imbedded in the dash, yank with needle nose pliers. Enlarge hole (just foam material) to fit new speaker. Test fit speaker for depth clearance. Bolt your speaker to the ring. Drop ring and speaker into dash with silicon or goop adhesive. Pay attention to bolt orientation, you want clearance to removes bolts when needed. $30.00 per pair. Shipped. Paypal is jimclayton@mac.com
2005 Elise Storm Titanium Last edited by jim-clayton : 04-21-2008 at 11:04 AM. |
Car Guy
These rings make installing 5.25" speakers in your dash SUPER easy, best sound improvement you can make for your Elise/Exige
Bill '07 BMW M Coupe, '05 Lotus Elise (Traded) www.billswebspace.com/lotus www.syntheticfirst.com |
I just did this mod. You wouldn't believe how much better the car sounds. Unreal.
I had the stock rear blaupunkts in the front and it still makes a huge difference. The rings make for a real clean install once you remove a little material in there. Didn't take long at all - just used a razor blade, pair of pliers, and a recipro blade (didn't use the saw, just the blade). Once you get the metal ring out of there, the rest comes out easily. BTW, I put some fiberfill under there and it made a noticeable difference. My Elise is really rocking now. Thanks for the rings - a value at twice the price!
05 GG Elise: Exige clam, LSS, Stage 2, ACT HD, DBA5000, CF scoops/splitter/mirrors/panels Others: Lexus ES300 Coach, Volvo V70R 300hp/250k Missed: 01 Wrangler Sport, 04 Wrangler Sport, 71 CJ5 (225V6) Need a personal injury attorney in Kansas City? http://www.kcatty.com Need a Johnson County DUI lawyer? http://www.JohnsonCountyDUI.com Need a Johnson County speeding/traffic ticket attorney? http://www.JoCoTraffic.com |
Elise...Best Daily Driver
I just paypaled you Jim, Thanks Much, Rob
2005 Elise, Starlight Black/Red, stage II exhaust, driving lamps, LED Tail lamp set, hybrid longtail/ and hardtop, Exige rear wing, radio delete, air bag delete, Custom Leather & Alcantra binacle, UK steering wheel, HVAC controller relocated, UK ECU, Carbon mirrors side mirrors, Zoom carbon rear view mirror, and custom wheels that favor the M250, no understeer and a variety of the simple mods. |
#6 (permalink) | |
You don't mess around. Quick install! I'm glad they worked out for you.
2005 Elise Storm Titanium |
#8 (permalink) | |
install, go past the 4" install. http://www.billswebspace.com/lotus
#9 (permalink) |
Track Junkie In-Training
Jim, I'm also interested in purchasing a set.
I currently have the 4" JL Audio TR's up front & am thinking about upgrading to the 5 1/4" JL VR's. Which JL Audio's did you install & what size speakers do you have behind the seats?
2005 HRM Elise Mods: BWR SC Kit, Nitrons, NGK BKR7EIX-11s, Stage II, SS lines, Pagids, Oil Catch Can, HIDs, Aux D Lights, W Strps (Red Outline), AL Shift Kit, BLK Suede Brk Cvr, Pwdr Coat BLK Diff/Whls/GC, MB CC/AC, Red Brk Calprs/Engine Cvr, LTS Rear Badge, CG-Locks, Alpine 9886 HU, JL VR 5.25" x 4. "You're Never Too Young To Plan For Your Mid-Life Crisis." |
#10 (permalink) | |
I ran 5-1/4 front and rear. VR's are fine for this. I ran a 5 channel amp with the JL sub up front. The rear speakers were turned way down to obtain the best sound.
#12 (permalink) |
I installed 5-1/4" JL Audios in the front today using Jim's rings. They worked perfectly. The rings are a high quality product. Highly recommended.
2006 Polar Blue Exige 2008 Black Toyota Highlander Hybrid 2001 Silver Honda Civic Ex ----------- 2006 Chrome Orange Elise - Sold 2000 Porsche Boxster - Sold |
#13 (permalink) |
3 years and counting
Laser blue,biscuit, micro mirror, "Blue knob" ,HID lights,modded rear lights,rear badge,blue starter button, replaced speakers,perma grin, Club111 ![]() ![]() The Sith lord of the LB's loyal henchman
#14 (permalink) |
Tried to install some 5.25" Focal 130CA coaxials today, but the grill assembly is just slightly too large a diameter. I could put the speakers without grille, but the holes in Jim's rings are just 1mm or so too close to the center of this speaker. They don't line up quite right. I'll have to try some of the JL's. Has anyone tried this with the JL XR525's? I've had XR 3-way components in a previous car and liked the sound, but just wanted to try the Focal's as they were on clearance @ Zalytron.com ... but no dice ...
Maybe we should make a speaker "list" that would work with these rings that Jim has made up for us ... Jim has the VR's installed (onboard crossover/cap). The XR has an offboard (more advanced) crossover, but that complexity may not be called for in this car ...
2005 GG Lotus Elise
#15 (permalink) |
The XR525-CXi is discontinued, but I found similar dimensions on JL's site for this speaker as for the VR525-CXi. The XR is available online still, found with a google search generally <$200. Not a bad deal. I'll probably order these and stuff the outboard crossovers into the dash. The crossovers supply first order lowpass to the midwoofers and second order highpass to the tweeters. The builtin cap on the VR would only first order highpass the tweeter and the midwoofer would get full frequency. Again, though, this could be totally moot in a car this noisy, especially mine with the aftermarket Arqray exhaust.
2005 GG Lotus Elise
#16 (permalink) | |
FYI - I heard a noticeable difference when I stuffed some fiberfill from an old pillow in there.
#17 (permalink) |
I just installed the VR525-CXi 5-1/4" from JL. They fit the adapter rings and the dash without a problem.
#18 (permalink) |
PM Sent
#19 (permalink) |
How do they sound? Did you go with the 5.25" VR's all around? I'm about to do the same & swap out the JL TR's.
#20 (permalink) | |
Definitely there is a sound improvement; I consider that it was worth the cost/effort. I didn't swap the head unit though, and I can now tell that it is severely lacking. So, that is next on the list. An ampliflier would be a better solution, but I don't want to go through that hassle, especially given that I often like to listen to the car. The car could also use a sub. I think I am also going to add some fill material to the front speakers. The back ones sound better than the front ones, I think because of the fill material in the rear and vacuous space for the fronts.
