#202 (permalink) | |
fm78.tv - check it.
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior. |
#203 (permalink) |
Finally
Yes. I just wish there was a ground that was easier to reach than to extend the wire as per Q's install.
Bob in NJ 06 Sport Elise # 23 Stage II/Micromirror/Green wire mod/S111 tow hook/BWR front plate holder/Green filter/desnorkled/HID's-Hi & Low/Stealth Bulbs. |
#204 (permalink) |
fm78.tv - check it.
Yea, Wasn't that big a deal though. I simply soldered on a wire and covered it with some heat shrink tubing. BTW, i didn't need to use the zip tie for the pass through - i simply stuck my hands in and grabbed the wire. You may want to try it first without the extension, but knowing Quinn, if she said you need it, you probably do. As for a better grounding location, I can't think of one easier to access.
#208 (permalink) |
Finally
Any idea which one the 12v wire is on 06's? There is one green/black wire but that does not seem to be it. Before I go ahead and break the multimeter out I thought I would ask here.
Edit: okay figured it out. It's red on the 06.
Bob in NJ 06 Sport Elise # 23 Stage II/Micromirror/Green wire mod/S111 tow hook/BWR front plate holder/Green filter/desnorkled/HID's-Hi & Low/Stealth Bulbs. Last edited by NJdrool : 09-26-2008 at 04:17 PM. |
#209 (permalink) |
G-200 Driver
Mr C, let me begin by saying the bracket is outstanding !! Beautiful workmanship !..........BUT........after knocking mine off no less than 10 times, I decided I needed another mounting solution. I went out and bought some 1/8 " short wall anchors ( for 3/8 in drywall )....I cut the nibs off ( that would normally dig in to the drywall ) and put 4 flat washers against the part that would normally sit on top of the drywall. PERFECT !! creates a very solid mount. Thanks again !!
#210 (permalink) | |
German Reimport
Kestrel74, you knocked your's off 10 times ![]() ![]() ![]() Something seems to be very wrong, and I doubt that you installed it correctly ![]() There would be NO WAY to knock it off without breaking the fiberglass unless you didn't install it right. Imagine that the washer in this picture is the firewall with the Wellnut installed: ![]() And this is what it looks like behind the firewall once you install and tighten the bolt: ![]() ![]() Note how the Wellnut buldges behing the firewall! Make sure you have it all installed correctly and you shouldn't have any issues with the bracket coming loose. Let me know how it works out for you.
If I die, my biggest fear is that my wife sells all my toys for the price I told her I bought them for... |
#211 (permalink) |
G-200 Driver
Don't get me wrong...still a satisfied customer !!......
Yep, I know how wellnuts work.... but, didn't work on mine... I have a steel washer in back of the fiberglass also.... I put the wall anchors in back of the steel washer.....works fine..
#212 (permalink) | |
German Reimport
![]() I thought you either insalled them backwards, or the holes in the firewall on your car are bigger than they are normally... ![]() The steel washer behind the fiberglass also sounds strange... There should only be the big black plastic cover which has the interior light and the speakers in it, and behind that is the fiberglass firewall. I have no clue how one would even get washers behind that fiberglass...
#213 (permalink) |
Put me down for a black one. Money sent.
'06 Elise - Laser Blue, LSS, TP, TC, Starshield. Mods: Stage 2, LETSLA, Manly MM, Exige Seats, Bollocks, De-Snorkeled, Viper's AC Mod, Alpine PDX/JL Stealthbox, 35% Tint, Color Matched Tunnel/AC Surround, Switchblade Fob. To Do List: Mesh, S/C (Someday) A twirling visual overload, explosions of terror and beauty. Colors of fear and pain within clash into unanything. |
#216 (permalink) |
Bracket for sale
I received my bracket a couple weeks ago; it is very beautifully made.
![]() However it turned out I am putting in a harness and will mount my camera on the harness bar instead, so I have no use for this bracket I just purchased (even though it does fit with the bar installed). $40 shipped or best offer. Raw aluminum (not anodized). PM me if interested. Thanks!
2006 Lotus Elise (BWR SC w/ CharlieX tune, Toyo R888, Moroso Oil Pan, Green Filter) 2003 Porsche Cayenne S 2002 Porsche Boxster S (ROW030, RA1, B&M) (sold) |
#217 (permalink) | |
Mark. Send me an email at mhansonphone@am.sony.com with the info... |
#218 (permalink) | |
#219 (permalink) |
G-200 Driver
MrC: How can I ''tweak'' the angle on the bracket ( right now it points down a little too low ) can it be slightly re-bent ?
#220 (permalink) | |
German Reimport
The guy who bent them overbent them by maybe 5 degrees or so. I think it doesn't really matter for the detector itself. But I went and tried to bend one of the scrap brackets I have back to a 90 degree angle and it works just fine. I put the vertical shank of the bracket in a vise so the radius of the bend just starts above the vise, and then pulled up slightly on the horizontal part until I got it to be 90 degrees. Works perfect... After that I tried the same on one of the anodized brackets, and it works there as well without any negative impact.
