Gotham 265 Flash & ECU for '07 Exige S - LotusTalk - The Lotus Cars Community
post #1 of 9 (permalink) Old 03-20-2010, 02:22 PM Thread Starter
Doghouse's Avatar
SOLD - Gotham 265 Flash & ECU for '07 Exige S
With the retirement of my Lotus from the track, I pulled the Gotham 265 flashed ECU and replaced it with a stock ECU.
Now I'm looking to sell my Gotham 265 tuned ECU for a '07 Exige S. (see pictures)
A few important things to note:
1) The ECU does not have a FED sticker on it, but it does (will) run a FED car just fine. It's just a sticker difference.
2) I was unable to get the ECU to complete the emissions check. May have been an oxygen sensor issue or ???? Bottom line, absent the OBD-II emissions check completed out you can not pass emissions inspection. So you can either swap ECU's just prior to doing your inspection, or use the car off-road (track only) or ...
3) Using this ECU may void the warranty (if any is remaining) on your motor. All depends on how honest you want to be when talking to the dealer person.
If you have not done an ECU swap, swapping the ECU is a 20 min. activity that requires very minimal mechanical skills. Basically, disconnect the battery, remove the driver side intercooler pipe, unhook two multi-pin electrical connectors, and remove four nuts. Reverse the order to install.
This is by far the easiest way to add an additional 45HP to your '07 Exige S.
The reflash of the ECU to the Gotham 265 tune costs $1200 plus shipping. I have the supporting paperwork. The ECU itself costs another $1400 (if you can find a dealer who has one and does not require an exchange or core charge). Go to Lotus Garage and check it out.
So $2600 worth of hardware and tune, I'll accept first offer of $1800. Price is firm.
Send PM.
From the Doghouse
2007 Exige S - Arctic Silver w/ Black racing stripes (Long live the garage queen!)
'99 'track rat' Miata - Jade green with black stripes. (Drive it till it drops, it's a Miata!)
Doghouse is offline
post #2 of 9 (permalink) Old 03-20-2010, 03:52 PM
Mulholland>SCC
agirls's Avatar
Can you post some bigger pictures?
I'm just being a smartass
Toys-
05 Ducati S4R
02 Suzuki SV650
09 Kawasaki KLX250
agirls is offline
post #3 of 9 (permalink) Old 03-20-2010, 06:51 PM Thread Starter
Doghouse's Avatar
These are TEXAS sized pictures...
From the Doghouse
Doghouse is offline
post #4 of 9 (permalink) Old 03-21-2010, 07:08 AM
drken's Avatar
Will this work on a 2008 240S?
drken is offline
post #5 of 9 (permalink) Old 03-21-2010, 07:32 AM
No. S240 and S220 have different ECUs.
keinayo is offline
post #6 of 9 (permalink) Old 03-21-2010, 12:32 PM Thread Starter
Doghouse's Avatar
Don't know, perhaps CharlieX or some of the other ECU gurus can answer.
I can state that this ECU worked just fine on my '07 Exige S-220 (except for the O2 sensor / emissions issue). I swapped back to stock simply because I wanted a car I could get past the yearly TX state inspection without any issues.
From the Doghouse
Doghouse is offline
post #7 of 9 (permalink) Old 03-21-2010, 02:42 PM
What is this o2 issue you speak of? Also has Charlie disabled the postcat o2 sensor so that if I were running a decat the ce light won't come on?
07 Exige S - PhB., TP, TP, LSD, Gotham, 2Bular Revised Header, 2Bular De-Cat, 2Bular 8x24 Burnt GT3, Cup Car Intake, 6k HID's, Schroth 4pt ASM Harnesses, Milled Steering Arms, Bronze Volk TE37, Carbon Craftsquare Mirrors, Reverie 5 Element Diffuser, Reverie Exige Race Front Spoiler, APR Canards, IMRP Side Skirts, Blackwatch Studs w/ Project Kics K40 Lugs, DBA 5000 Rotors, Goodridge lines, Sparco Wheel w/ Works Bell Quick Release.
Sh4rkattk is offline
post #8 of 9 (permalink) Old 03-21-2010, 03:36 PM Thread Starter
Doghouse's Avatar
The tune currently in the ECU is for a stock '07 Exige S. If you run a decat, or headers, or smaller pulley, or something radically non-stock, CharlieX will have to tweak things for you and you need to work that out with him.
The issue I was having was that the O2 sensors on the emissions check would not clear. I ended up replacing both of the O2 sensors at about the same time I got the new stock ECU. Everything cleared out and the issue went away so what the problem was. I'm just happy to be driving the car again.
The o2 sensors issue may have been related to an aftermarket exhaust in which the main tube broke internally and all the glass pack stuffing plugged up the system. With restricted exhaust flow out, the sensors may have gotten loaded up / killed off. Again,
After fixing the exhaust, and resetting the CEL the O2 sensors would not clear. The car ran with no problems until I spun a bearing while on track. At that point I retired the car from track duty but have kept it as a Friday driver.
I'm trying to be upfront about what I know and what I don't know. All of the above is chronicled in painful detail in the Engine Forums over the past 12-16 months. Run a search or flip through and look for my posts.
Bottom line, the tune and the ECU will run a stock '07 Exige S just fine.
I am selling the ECU and tune because now that I have the car in drivable condition and it will pass emissions, I don't want to f- with it. I have a turbo Miata to fling about the track with wild abandon and I can walk away from that car with it burning to the ground and be out way less $$$ than my Lotus.
If you are local to Houston, TX and want to try before you buy, send me a PM as we can make arrangements to make it happen.
From the Doghouse
Doghouse is offline
post #9 of 9 (permalink) Old 03-22-2010, 08:04 PM
hhmm.. really interested but id ideally like to sell my stock ecu to offset the cost, and avoid the hassle of swapping for an emissions check.
anyone have experience passing obd2 check after their gotham tune?
jjm4life is offline
  LotusTalk - The Lotus Cars Community > Marketplace > Parts Market > Parts For Sale
Human Verification
