Go Back   LotusTalk - The Lotus Cars Community > Marketplace > Parts Market (non-commercial)
View Poll Results: First batch Color
Red 45 25.71%
Orange 13 7.43%
Yellow 19 10.86%
Green 7 4.00%
Blue 11 6.29%
Clear 6 3.43%
Black 74 42.29%
Voters: 175. You may not vote on this poll
Old 11-23-2008, 01:17 AM   #281 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
finally mounts are installed and the car totally vibrates at idle. Mirrors shaking, IC and pipes vibrating, my engine lid makes noise right above my head from rubbing against the clam. WOuld having stiffer shocks & springs make the vibrations worse?? Somehow I've got to adjust the engine lid as it sits lower than the clam, not flush at all. Shifting seems better. I get a nice massage at red lights. at least i don"t hear the motor rocking anymore.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 11-23-2008, 06:17 PM   #282 (permalink)
without a Lotus
FLuXeXigeS's Avatar
^yea i need to do that soon, i have a dent on my I/C from hitting the trunk shocks on hard accel/decel at the autoX
-Coi- currently having Lotus withdrawals
Facebook | Twitter | Pics | Vids
eBay Store
FLuXeXigeS is offline   Reply With Quote
Old 11-23-2008, 06:21 PM   #283 (permalink)
Form and Function
plastique999's Avatar
huh, that's weird ara...I know people report slight increased vibration at idle...but I did not experience any of that at all. In fact, my car was running smoother at idle, and my shifts were definitely smoother and "clicked" into place (I do have shift reenforcer as well and bollock)
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 11-24-2008, 12:34 AM   #284 (permalink)
Exige Prestige
Trendy Exige's Avatar
Its probably because Ara has that 2bular blowpipe exhaust. That thing grunts even at idle. With that said, the engine mount and the mounted exhaust will cause the vibration of the clam to shift more aggressively.
'07 Exige S (Storm Titanium) - Gotham 265, Arqray Titanium Double-Tip Exhaust w/ Arqray Sport Cat & Euro Grills, TWR Dry Carbon Cup Roof, LEA Dry Carbon Adjustable Wing, Prototype Composite Dry Carbon Front Spoiler, Reverie Dry Carbon Side Skirts & Dry Carbon Side Scoops, 17's Team Dynamics 1.2G Matte Black Wheels, Painted Bulkhead Panel, Painted Consoles, 6k HID w/ Raybrig JDM blinkers, Cup Car Airbox, RLS IC Pipes, Saikou Michi Catch Can, Rear Camera, Venture Shield Entire Front Clam etc.
Trendy Exige is offline   Reply With Quote
Old 11-24-2008, 07:09 PM   #285 (permalink)
lt0302's Avatar
Thumbs up Finally installed
Slightly more vibration at idle, but the cars feels a lot stiffer especially during shifts. I only have the shift reinforcer but these mounts made a huge difference in shifting, more precise........I like them!
05 Lotus Elise R/K Supercharger, Stage II, Moroso Oil Pan, RTD Brace, High Volume All Aluminum Radiator, Stainless Steel Break Lines, Oil Catch Can, ACT Clutch, HID, Carbon Fiber Spliter, Reverie Side Scoops, CF side skirts, FF gauge pod, BWR gauge pod, Cup Air Box, S111 front & rear tow hooks, upgraded tail lights-LED, Driving lights, LETSLA, ...
lt0302 is offline   Reply With Quote
Old 02-01-2009, 02:48 AM   #286 (permalink)
mlk_f1's Avatar
Images: 11
Bump
http://www.trackHQ.com
mlk_f1 is offline   Reply With Quote
Old 02-02-2009, 12:14 AM   #287 (permalink)
shay2nak's Avatar
my damn engine lid is squeaking behind my ear! It's actually sunken a little. Not sure how to raise it. Maybe an extra washer on each hinge?
Old 02-03-2009, 05:19 PM   #288 (permalink)
mlk_f1's Avatar
Images: 11
For those of you that are experiencing unbearable vibration, can you make sure your front lower mounts are installed correctly! There are two small rubber taps on each side of the OEM rubber mount. The polyurethane insert have this tap indented into it. You have to line them up. I found some ppl installed this piece at a 180 degree offset, which is wrong. You can still install it that way but the insert will not be fully seated correctly and will cause more vibration that normal.
See pix below:
Old 02-03-2009, 09:41 PM   #289 (permalink)
really light stuff
Thomasio's Avatar
Ara - get one or two aluminum shims (per side) and place them in between the engine lid and the hinge. My S had the exact same fit from the factory.
Do one hinge at a time - just loosen it, the shims slip in. Make sure to mark the original location of the hinge with masking tape on two sides that are perpendicular to each other so that you can tighten the hinge in the exact same location after you have inserted the one or two shims per side. Talk to your dealer to get a few shims.
07 SY Exige S
Old 02-03-2009, 09:58 PM   #290 (permalink)
pete k's Avatar
I was afraid of the vibration on Manly's mounts, so I ground the edges off of the inserts to allow a little rubber flex before the polyurethane contacted the steel. On my bench grinder I took off about 1/8 of an inch to allow a little movement. I did this all the way around, and I have minimal vibration, almost not noticeable. As I did not install them without the modification I cannot tell how much of an improvement. I am very pleased with these.
pete k is offline   Reply With Quote
Old 02-03-2009, 10:21 PM   #291 (permalink)
shay2nak's Avatar
thank you Manly and Thomas for the updates.
I can only get the shims from the dealer?
Old 04-10-2009, 10:40 AM   #292 (permalink)
shay2nak's Avatar
Checked the front mounts and were installed correctly, must be the new mounts + the exhaust causing added vibration.
Old 04-10-2009, 04:35 PM   #293 (permalink)
^^ I wish!
esthi's Avatar
I installed these mounts last week. There is somewhat increased vibration at idle, but not enough to make any (new) noises. I do notice a little more shudder starting out from a total stop. But, at the track last weekend, the mounts were a HUGE improvement, particularly in corners that required downshifts. I no longer had to wait for that half second for the engine to stop moving around to get securely into gear. The whole brake/downshift/back on throttle process was seamless, and I loved how solid the transmission (and whole car) felt! I was raving about the mounts to the other Lotus owners at the event. This is one of the best mods I have done to the car, and definitely a great bang-for-your-buck.
'05 SY Elise LSS/Touring/HT/Quicksilver, '03 Audi A4 1.8Tqm Avant, '95 Porsche 993 C2
esthi is offline   Reply With Quote
Old 04-17-2009, 10:15 PM   #294 (permalink)
sleepe's Avatar
got mine in...
This is how the car should have been delivered.
Love the vibes...really suits the cars personanity
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
sleepe is online now   Reply With Quote
Old 04-21-2009, 06:02 PM   #295 (permalink)
NOT ßANNED!
Demonized's Avatar
paypal'd the monies, excited for mounts.. and fewer broken exhaust hangers :X
Old 05-04-2009, 08:49 AM   #296 (permalink)
NOT ßANNED!
Demonized's Avatar
Mounts are in, car only shakes a little more at ~1200 rpm, so when taking off, and coming to a stop.
3rd is a hundred times easier to find at 7000+ RPM.
Love the mount inserts.
Old 05-04-2009, 12:57 PM   #297 (permalink)
Lotus-Position's Avatar
Got mine in last week and drove with them this weekend for the first time on the street. Did the shifter brace mod at the same time. Really like how these modes firmed up the shifting and throttle feel!
Lotus-Position is offline   Reply With Quote
Old 05-05-2009, 12:41 AM   #298 (permalink)
Mountain Road Nut
ChrisH's Avatar
I just wanted to give a caution to anyone working on or changing the engine mounts. The Lotus Service Manual does not specify the bolt torques. Many people are using the torques that were listed in the installation instructions for Manly's inserts.
However, I think some of Manly's recommended torque settings are much too high (as evidenced by some damaged bolts when I did my installation). Over torqued bolts have a higher chance of breaking under load. See the following thread for alternative torque values and the rationale for them:
Engine Mount Bolt Torques
By-the-way, I installed Manly's inserts about two months ago and really like them.
Old 06-22-2009, 09:43 AM   #299 (permalink)
Professional Fat Kid
NHG35GUY's Avatar
I have my manly mounts installed. The car does vibrate a bit, to me its not a big deal and is not noticeable at cruising or highway speeds. I also have a Janspeed Stage II and Piper Cams installed and the vibration is more than tollerable.
The acceleration and reduced engine movement are worth the extra vibration at idle.
NHG35GUY is offline   Reply With Quote
Old 07-28-2009, 01:53 PM   #300 (permalink)
Images: 6
Thanks for the mounts! Like night and day, what a difference!
Earlyout63 is offline   Reply With Quote
