Go Back   LotusTalk - The Lotus Cars Community > Motorsports > Solo timed events
Old 09-11-2009, 06:43 AM   #1 (permalink)
lancer360's Avatar
How to run a decreasing radius corner
We had a great 24hr autocross over labor day weekend. Event ran from noon on Saturday to noon on Sunday. I must have put 40+ runs on the car. Course overall was fairly simple, but so wide open you had many different lines. Near the finish there was a significant decreasing radius corner after a short straight. After the decreasing radius corner there was a mild kink and then the finish line. Many cars were taking the entrance pretty wide to try and turn the corner into a more constant radius corner. I chose instead to keep as tight as I could to the inside and go in a little hot. Then I would modulate the throttle to get a bit of lift oversteer to scrub off speed and to help keep the car tight to the inside. I was curious on how others handle a decreasing radius corner.
'05 Lotus Elise Saffron Yellow, Touring, Sport, Stainless Brake Lines, Moroso Oil Pan, RTD Brace
KBS Mark 7 Formula 500 with a heart transplant in progress '09 600cc GSX-R Due to hit the track in August '09
lancer360 is offline   Reply With Quote
Old 09-11-2009, 06:53 AM   #2 (permalink)
TedDBere's Avatar
A past National Champion once told me to break a decreasing radius into two turns. First turn is a fast sweeper, second turn requires a gentle brake at turn in to hit the apex for corner exit and accelleration.
TED
TedDBere is offline   Reply With Quote
Old 09-11-2009, 07:51 AM   #3 (permalink)
Images: 1
Kind of reminds of the Sebring last turn...where a high speed turn gets tighter with a smaller radius..
cemaykan is offline   Reply With Quote
