Ohlins Shock Length - SCCA Street - LotusTalk - The Lotus Cars Community
post #1 of 8 (permalink) Old 03-14-2017, 01:45 PM Thread Starter
I am trying to piece together a reasonably affordable aftermarket shock that is street class compliant, but no luck.
Extended length of the OEM shocks are ~14" front/16.5" rear.
The currently available Ohlins sets, LOV1/D-- are ~14.5"f/15"r. The LOV1/F-- are even shorter. Neither of these shock pass the (+/-) 1" allowance.
Going off pictures, the Lotus Sport Ohlins have really long shaft extensions, which would make it difficult to get the spring located correctly.
For those running these shocks and managed to make them compliant, what model are you using?
JRTritsch is offline
post #2 of 8 (permalink) Old 03-20-2017, 12:58 PM
Doesn't the Blackwatch Racing kit make Ohlins compliant?
https://www.blackwatchracing.com/Ohl...ter-p/1035.htm
Alphadawg is offline
post #3 of 8 (permalink) Old 03-20-2017, 05:01 PM Thread Starter
Yes, I and had hoped to purchase them, but they only relocate the spring so it is in the same location relative to the hub. This takes care of #3 of the shock rule (below).
There is another requisite that the length of the extended shock is within 1" of the standard part, #4. None of the currently available Ohlins shocks meet that rule as they are too short in the rear. This isn't unique to Ohlins, most of the aftermarket shocks are shorter than the standard shock by quite a bit. That is fine with stiff springs, lower ride height, if you have a clutch diff, or don't autocross. But losing droop can be potentially problematic for a stock car if you get any wheel lift.
From the rulebook:
3. Adjustable spring perches are allowed, but the spring loadbearing surface
must be in the same location relative to the hub as on the standard
part. Shims may be used to achieve compliance.
4. The fully extended length must be within 1” (25.4 mm) of the dimension
of the standard part.
post #4 of 8 (permalink) Old 03-20-2017, 05:50 PM
forkmeupscotty's Avatar
Try contacting Performance Shock, Inc in Sonoma, CA.
They're authorized Ohlins(and many others) service center, they have made upgrade kit specifically for your damper(and others), and are very familiar with Lotus.
This is for different damper body, but I'm thinking something like this can work. Nitron dampers can have different damper body lengths this way as somewhat related note.
Ohlins TTX36 Motorsport Racing Damper Body End Eyes [TTX 36] : Performance Shock, Inc
2008 Lotus Exige S240 Phantom Black - Starshield, Touring Pack, Track Pack, LSD, Premier Gold Pack
2008 BMW 535i - Sport Pkg, SportAT, etc
http://www.youtube.com/forkmeupscotty
forkmeupscotty is offline
post #5 of 8 (permalink) Old 03-20-2017, 06:24 PM Thread Starter
Yes they can modify the Ohlins to meet the requirement by changing out the shock body. I'm looking into that option now. It looks like nitrons can be ordered to the correct length too. With either option I'll probably be stuck machining custom spring adapters similar to the Blackwatch adapters, because its is unlikely the dimensions will fully match. Certainly not an impossible task, but easy to waste a bunch of time and maybe money re-engineering a solution. That's why I'm curious to see what model of Ohlins have been used in the past. Perhaps Ohlins can just rebuild of that spec.
I'm not keen on spending a ton of coin developing a shock on a car that is at present not particularly well classed.
post #6 of 8 (permalink) Old 05-30-2017, 05:18 PM
jrwiseman's Avatar
Any news on looking for shocks ?
jrwiseman is offline
post #7 of 8 (permalink) Old 05-30-2017, 08:11 PM Thread Starter
I luckily found a "like-new" set for sale built in 2011 with the correct dimensions. Same part number as sold now, but ~13.5"/16" extended length to match OEM.
I think Nitrons could be easily ordered in desired sizes, but the perch height remains an issue. I wrote a letter for clarification/adoption of a perch allowance, but I know that was also tried in the past.
post #8 of 8 (permalink) Old 05-31-2017, 05:48 PM
jrwiseman's Avatar
thanks for the update. Glad you found something but wish it was available to others as well
John
Human Verification
