Rake vs corner balance?
It just came across my mind that, after setting the rake on the car, if then take it down the road for corner balance, wouldn't that mess up the rake?
![]() So should I just ignore that and proceed with the corner balance?
Ambrose "If you are not where you want to be, the index is not broken, you are just slow. - 47CP" |
User, Registered
If they raise one side as much as they lower the other, no.
2009 XP National Champion
![]() Join Date: Oct 2003
You will end up with a decent amount of rake anyway, since the desire will be to put weight in front. Corner balance will help and you should have more even rake WHEN you are in the car.....
registered nipple
you should really set up the car in "race trim"(scaleing the car).
amount of fuel used on track, and driver in the car. you can use weights to simulate your body if you are doing this alone.
2008-2009 SCCA AZ Regional "Driver of the Year" 1986 Swift DB-1 Sold 2008 HSR-West FF 3rd generation Champion 2008 "The Series" FF 3rd generation Champion 1987 Porsche Spec 944 2008-2009 season SCCA AZ regional Champion |
#5 (permalink) | |
Interloper
I agree with Francis.
2005 S2000 #42as |
#6 (permalink) | |
Yay, we're all right! raise the rear if puts more weight(not alot) on the front wheels. But Francis is correct a proper race corner balance is needed here of which Rake will be a part of the alignment.
#7 (permalink) | |
![]() I have set the car up according to the lotus service manual. Let's just assume I am going to drive with me and a full tank of gas. I am going to do a cross weight balance. (I have been hearing conflicting info on this so I just pick one method) Let's just say I raise the driver's side rear to take the weight off... now the rake is incorrect right. What do i do now? ![]()
#8 (permalink) |
McLareghini Bugatterrari
Adjusting the corner balance, if it's not horrendously off in the first place, shouldn't effect rake all that much. I mean if you're dropping the front 5mm lower than the rear, for example, and then you're going to adjust corner weights using only one thread of the shock body or less probably. So you're rake will probably stay within half a mm of where you started I'll bet.
xtn
#9 (permalink) | |
User, Registered
#10 (permalink) |
If you are corner balancing for stock class, there's not a whole lot you can do about shifting weight around. Its all about the 50/50 cross weights. I have the Track Pack so I can adjust the collars, I always start by measuring the collars to some reference point to "zero it out". I spent hours fiddling with it and you can try making huge height changes and it would only make about 5-10 pounds difference and really mess up the cross weight. The car stock with me in it was 51/49 and I couldn't do any better than my zeroed out setting. Why? Height changes don't make huge gains with a light car with tiny overhangs,relatively long wheelbase, and my 200# ass...and there isn't any ballast to move around (at least in SS)...like the battery that is on the wrong side for us Yanks.
2007 Calclub SCCA Regional Solo Champion SS 2006 Elise BRG Trackpack LSD for 2007 2006 Calclub SCCA Regional Solo Champion SK1 |
#11 (permalink) | |
