Newbie Elise Owner
Rear Camber
I picked up a pre-prepped Elise (edit: for SS Autocross) a few months ago. I did very well at the first few events with it and am looking forward to the coming season. However, I need to bring it in for a full alignment soon. I know the front gets 0.8 camber on both sides, but how much rear camber do people tend to run? I'm about to switch to the mondo huge new BWR front bar, so I can probably end up getting away with a little less rear camber, but we'll see. Curious where to start. Suggestions? I don't know what the current setting is.
2006 Lotus Elise - SS Autocross 2006 Mazda RX-8 - For Sale! Buy me! 1992 Mazda Miata - Spec Miata Club Racer 1994 Mazda Miata - DD when I'm scared to take the Elise out 1994 GMC Suburban - Gets the Miata and Elise to their respective tracks http://akilla.net/pics/sig.jpg Last edited by codingparadox : 01-17-2009 at 06:01 PM. |
Newbie Elise Owner
... Needs to be stock legal for autocross...
2006 Lotus Elise - SS Autocross 2006 Mazda RX-8 - For Sale! Buy me! 1992 Mazda Miata - Spec Miata Club Racer 1994 Mazda Miata - DD when I'm scared to take the Elise out 1994 GMC Suburban - Gets the Miata and Elise to their respective tracks http://akilla.net/pics/sig.jpg |
He is running SS in SCCA so shaving the arms is not allowed.
Front should be maxed out. We found at with the fronts at .6-.8 neg, the rears did not work as well beyond around -1.5. YMMV. This was with Hoosier A6 tires.
#7 (permalink) |
User Restricted By ΑDMIΝ
Randy, the service manual quotes -2.0 to -2.7 degrees rear camber for the LSS suspension with -2.5 optimum... but of course that's for the stock A048's... was your camber setting a function of the Hoosiers, or spring rates, etc?
#8 (permalink) |
I am working from potentially faulty memory, but I know we pulled all the shims in the rear and the car oversteered more on the Hoosiers. We concluded that the front-rear was too different based on input from someone, so we put shims back in. I don't think it was over 2.
#9 (permalink) | |
#11 (permalink) |
Tes, toe out would be bad. That (IMO) should also be total, as in 1/16" per side.
#12 (permalink) |
No more cone damage!
I ran -2.25 degrees in each side in the back and that was a great spot for the car. I could have gotten all the way to -3, but that wasn't as good as -2.25. Hope that helps.
On toe in, I settled on 1/16 total toe in, 1/32 in on each side. Others ran more.
Jer-2005 Elise (retired from autox) 1993 MR2 autox car 2002 Ford Excursion DIESEL 4 X 4 1993 Miata (throwout bearing or clutch failure) 1987 Toyota Corolla FX16 Lemons car (needs new head) 1984 Chevy Citation Lemons car (needs a motor) |
#13 (permalink) |
car
I would take Randy's advice
but this is what I did got this setting from John K LA region SS champion in an Elise. Im set at all shims removed on the front for max camber left the rears shims alone. 4 mm total toe in on the rear (2mm each side) 0 mm toe on the front Lowered all the way down (track pack only) then raise or lower for corner balance. 2 clicks front and 1 on the back ( I might play with this though) BWR front sway bar set to one back from full stiff. I have yet to max out the front caster, which Im told helps. I have yet to test these settings in my Exige S, but I think its a good place to start.
1993 Mazda RX7 R1 2009 Scion XD 2007 Lotus Exige S arctic Silver, lsd, track pack, touring, FOR SALE Last edited by stubble88 : 01-22-2009 at 04:28 PM. |
#14 (permalink) |
Newbie Elise Owner
... 4 degrees toe? You might want to check on those numbers...
With less rear camber, you can get power down better. More camber = more power oversteer but less midcorner oversteer. It's all a trade. If you look at formula 1 cars they're running crazy front camber and very little rear camber, since it's all about putting the power down. I'll probably start around 1.5 and go from there, it sounds like.
#16 (permalink) | |
That is pretty close to what we ran. I took my advice from Pat Salerno and Brian Connors.
#17 (permalink) |
Newbie Elise Owner
I don't have the track pack, fortunately, so I get to deal with stock ride height. ;-)
#18 (permalink) |
I might be mistaken but corner balancing is only legal in ASP+, and not in SS (where the stock height is changed).
'05 ELISE Storm Titanium LSS/TP/HT/Dual Oil Coolers/Starshield/Raptor Racing exhaust XP111 (LBH)/BWR 7/8" Anti Roll Bar "Smooth is fast, but fast is quicker" |
#19 (permalink) |
Newbie Elise Owner
The track pack comes with adjustable height perches from the factory, so it's allowed.
#20 (permalink) |
My bad. Ride height adjustment in track packs are allowed.
