Go Back   LotusTalk - The Lotus Cars Community > Motorsports > Solo timed events
Old 01-31-2009, 09:17 AM   #1 (permalink)
rogersla's Avatar
Rear Track Brace
Quick question which I've found conflicting info on...
Did the 2006 Elise Sport come equipped with the Rear Track Brack from the factory?
My TrackPack did, but I'm changing shocks and switching to the Sport Springs. In order to stay SS legal, I need to know if the rear track brace needs to come off since I'll essentially be "downgrading" the car to a Sport with the Springs change.
And, I'll have to set my ride height at 130 front and rear.
My co-driver and I have decided to try the Sport springs for a few events. then, we'll decide if the 2 stage Trackpack springs are worth putting back on for the ride height adjustments.
Lynn
2006 Aspen White / Sport / Track / LSD
President SSSCC
www.ssscc.org
rogersla is offline   Reply With Quote
Old 01-31-2009, 09:59 PM   #2 (permalink)
sleepe's Avatar
yes, the sport elise came with the toe-link brace....same as track pack
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
sleepe is offline   Reply With Quote
Old 02-01-2009, 08:44 AM   #3 (permalink)
Ryno's Avatar
If you want to be 100% legal I've been told you have to change out the roll cage as well. (different steel)
www.jjsons.com
Ryno is offline   Reply With Quote
Old 02-01-2009, 09:41 AM   #4 (permalink)
rogersla's Avatar
Thanks for the reply on the track brace.
Roll cage. Are you referring to the structure inside the area rear of the tonneau cover. No, that is not changing. Someone is going to have to protest me on that one I guess. What would be the basis? Weight? Stiffness?
This may all become moot, cause even though the conventional wisdom is that the sport springs are better, I'm still not convinced that the softer first stage of the Track springs won't be better for dealing with corner entry push. We should be able to tell rather quickly. Our first event of the year is in about 3 weeks.
Lynn
President SSSCC
www.ssscc.org
Old 02-01-2009, 10:54 AM   #5 (permalink)
cone punisher
mtcossie's Avatar
The 2006 Sport package does not have the toe link brace. If they did I better call Lotus because mine 06 Sport Package doesn't have one. The Yellow Elise Sport wasn't eligable for SS
Hope to see the white Lotus at Helena this year!
2006 Lotus Elise
1995 Ford Escort Cosworth
SWMT SCCA Competition Chairman
mtcossie is offline   Reply With Quote
Old 02-02-2009, 08:27 AM   #6 (permalink)
Ryno's Avatar
No real basis other than it's the way they come.
www.jjsons.com
Old 02-02-2009, 12:26 PM   #7 (permalink)
Unless the SCCA rules have changed...
The brace is a FACTORY installed option not a DEALER installed option, so, it is legal on any version (LTS,LSS [sport pack],TP)
Also, I think the OP is confusing us. There was a "Sport Elise" that came with Ohlins, a harness bar (sometimes), special paint, wheels etc., then there is a Sport Pack that came as an option (different wheels, shocks, springs and an extra oil cooler). I assume you want to use the sports pack springs on your track pack shocks since you are trying to match the sport pack ride height. Seems legal to me.
I think sleepe and mtcossie comments are directed at the Sport Elise that is illegal in SS, not a Track Pack or Sport Pack equiped Elise.
AZReason is offline   Reply With Quote
Old 02-02-2009, 02:16 PM   #8 (permalink)
rogersla's Avatar
Ah yes, my mistake in being unclear.
I have installed the springs from the Sport Pack Elise. Mounted on Ohlins double adjustable shocks.
I need to set my ride height at the Sport Pack height, and I think I will be in compliance for SS.
And, MTCOSSIE, my tally says I've been to your site twice now and you've not been to mine at all. You've got to come this way sometime. Maybe we should meet in Spokane for an event. They have a great club going there now and a really nice site.
Lynn
President SSSCC
www.ssscc.org
Old 02-03-2009, 06:50 PM   #9 (permalink)
Ryno's Avatar
The problem is the brace came as part of a package, to add or remove you have to include all options that came in the package.
www.jjsons.com
Old 02-04-2009, 12:15 PM   #10 (permalink)
Oh, I thought the brace could be ordered independently. Ryno is most likely correct. Sorry for the confusion. I ordered my car in 2004. Make sure you use the Lotus recomended ballast for the ride height setup.
Old 02-04-2009, 01:39 PM   #11 (permalink)
BTC
This won't put you in compliance. The SCCA shock rule dictates the distance from the mount to the spring bearing surface. You have to match the OEM distances. There is no wiggle room on that measurement (other than part tolerances) and it will dictate ride height along with the nitrogen pressures. Ride height isn't actually a compliance issue in stock.
Here is part of the rule;
3. Adjustable spring perches are allowed, but the spring loadbearing
surface must be in the same location relative to the
shock mounting points as on the standard part. Shims may
be used to achieve compliance.
When you switched to the LSS spring your mounting distances are dictated by the two positions on the LSS shock.
05 Elise
4x2
BTC is offline   Reply With Quote
Old 02-07-2009, 08:45 AM   #12 (permalink)
Interloper
John Stimson's Avatar
You're going to confuse yourselves if you don't use the proper names for the cars.
The yellow/grey limited edition that with upgrades from Lotus Sport is called the Lotus Sport Elise. That's (Lotus Sport) Elise, because the in-house tuning group that created the package is called Lotus Sport.
Then there are Lotus Elises with the Sport Pack or Sport Suspension. You might want to call it a Lotus (Sport Elise) but that sounds and reads just like (Lotus Sport) Elise, so you're going to get into disagreements for no good reason if you do that.
2005 S2000 #42as
John Stimson is offline   Reply With Quote
Old 02-07-2009, 12:19 PM   #13 (permalink)
Form and Function
plastique999's Avatar
Off topic, but curious what your settings are on the Ohlins DA?
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 02-09-2009, 03:43 PM   #14 (permalink)
Newbie Elise Owner
codingparadox's Avatar
rogersla:
Are you codriving with Mitch this year? =D
2006 Lotus Elise - SS Autocross
2006 Mazda RX-8 - For Sale! Buy me!
1992 Mazda Miata - Spec Miata Club Racer
1994 Mazda Miata - DD when I'm scared to take the Elise out
1994 GMC Suburban - Gets the Miata and Elise to their respective tracks
http://akilla.net/pics/sig.jpg
codingparadox is offline   Reply With Quote
Old 02-17-2009, 10:50 AM   #15 (permalink)
rogersla's Avatar
Originally Posted by codingparadox View Post
rogersla:
Yeah, Mitch, I, and my GF are a team. Our car, his tires. We'll be at Packwood as much as possible. Looking forward to comparing times with you as we tune our settings.
Lynn
President SSSCC
www.ssscc.org
Old 02-17-2009, 11:12 AM   #16 (permalink)
Newbie Elise Owner
Cool! Did you switch back to the sport pack based on what I told Mitch?
Are you just having him buy tires for the whole year? I'm trying to figure out what to charge my codriver for the year. "Tires for the whole year" was my current thoughts, esp since I'm bringing a set of 80-run and a set of 40-run tires with me to start the season.
Ever gonna make it out to Bremerton or is that just too far?
Old 02-18-2009, 07:44 AM   #17 (permalink)
PedalFaster's Avatar
I hear that the latest in thing is to let codrivers drive for free... I read it on the internet, so it must be true.
PedalFaster is offline   Reply With Quote
