Go Back   LotusTalk - The Lotus Cars Community > Motorsports > Solo timed events
Old 08-06-2008, 06:10 PM   #1 (permalink)
jmiesse's Avatar
Soooo what class is my Elise?
Only thing changed is exhaust to stage II.
Still SS or ASP?
I read alll the threads I could find.
Looks like ASP.
05 AS Elise. Tour and Sport Pack. Hard Top.Stage II
Exhaust, Sport ecu, Pagid RS 4-2s,Toyo R888's, Shifter Matrix brace, Micro Mirror
jmiesse is offline   Reply With Quote
Old 08-06-2008, 06:12 PM   #2 (permalink)
Randy Chase's Avatar
Images: 761
Exhaust is free in stock. So SuperStock
Unless you cut the diffuser to fit the exhaust. Unfortunately that would move you to ASP.
And maybe a detail, but technically in STOCK you would need to leave the snorkel in too.
http://www.facebook.com/randychase
1991 Toyota MR2. AutoX Beast
2006 Noble M400. Track weapon.
2009 Rossion Q1. Monaco Orange. Canyon Carver.
Lexus GX-470 tow vehicle. On Order: Lotus Evora Next: McLaren MP4-12C
Old 08-06-2008, 08:10 PM   #3 (permalink)
Sean G's Avatar
Images: 6
cutting the diffuser: not technically legal in ASP either
**SDG**
Sean G is offline   Reply With Quote
Old 08-27-2008, 03:19 PM   #4 (permalink)
Slipstreamer's Avatar
Is having the Lotus Sport ECU acceptable as a factory upgrade legal in SS(It merely retunes the 2nd cam from about 6,200 down to around 5,800rpm)?
'05 ELISE Storm Titanium LSS/TP/HT/Dual Oil Coolers/Starshield/Raptor Racing exhaust XP111 (LBH)/BWR 7/8" Anti Roll Bar
"Smooth is fast, but fast is quicker"
Slipstreamer is online now   Reply With Quote
Old 08-27-2008, 03:42 PM   #5 (permalink)
Images: 761
No. Sorry. ASP.
Old 08-27-2008, 03:44 PM   #6 (permalink)
I thought so. Thanks, Randy.
Old 06-27-2009, 08:23 AM   #7 (permalink)
Denuo Volatilis
...m...'s Avatar
Originally Posted by Randy Chase View Post
No. Sorry. ASP.
...i thought the lotussport ECU was standard in all the sport elises?..
Old 06-27-2009, 10:27 AM   #8 (permalink)
OOTAH
2Low4morego's Avatar
It is, the 2006 Sport Elise is classed in ASP. Regular na Elises and na Exiges are classed in SS.
The trick setup for SS seems to be a 2005 or 2006 Elise without Touring Pack (saves weight) and with Track Pack and LSD.
2Low4morego is offline   Reply With Quote
Old 06-27-2009, 10:32 AM   #9 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
There was no Track Pack for 05 or 06 Elises. Does SS allow putting and Exige option onto the Elise?
xtn
Old 06-27-2009, 12:01 PM   #10 (permalink)
Scott Bowman's Avatar
Images: 21
The Track Pack option was available for the Elise starting with the 2006 model. For stock purposes, you cannot substitute or change parts from another model (e.g., swap an Exige seat for an Elise seat). If it were the identical part number--such as the air filter--used by both models, it wouldn't matter (but there would be no reason to substitute).
2006 Elise British Racing Green; LSS, LSD-TC, 2bular exhaust, Blackwatch Racing front bar, BWR Supercharger, Tillett Seats
Scott Bowman is offline   Reply With Quote
Old 06-27-2009, 12:06 PM   #11 (permalink)
Denuo Volatilis
...m...'s Avatar
...are you limited to options from the same model year only?..
Old 06-27-2009, 03:18 PM   #12 (permalink)
Images: 21
For stock class, yes, any options or packages used on your car "must be run as specified by the factory with only standard equipment as defined by these Rules." You can do option package conversions between specific vechicles of a particular make and model, but only between configurations from within a particular model year. For example, on the Elise, you could run the LSS size 6.5" front rims if your car came with the sport package; and you could convert a base car ONLY if you also add the twin oil coolers, the LSS Bilsteins (which are upgradeable per stock rules), etc. In other words, you could retrofit your Elise with the LSS package, but it must include all the components that would have come on the car from the factory for that model year.
Old 06-27-2009, 04:48 PM   #13 (permalink)
2009 XP National Champion
fzust's Avatar
For Stock, it is easier to talk about what you CAN change. Cat back exhaust, with no mods to body to fit. Air Filter, Brake pads, shocks(must fit stock locations and spring perch heights), tires, Wheels(same size as stock +/-1/4" on offset.) I think that's it.
Old 06-27-2009, 08:21 PM   #14 (permalink)
Images: 21
You can change the front sway bar and mount. And run any DOT legal tires, including R-compounds, such as the Hoosier A6.
Old 06-29-2009, 06:09 AM   #15 (permalink)
No more cone damage!
Surferjer's Avatar
I converted my first Elise to an LSS Elise way back when. Of course I had an early year base model that thankfully came with the twin oil coolers. That's the hard part of the conversion. Springs are easy and you're probably replacing the shocks anyway.
1993 MR2 autox car
Old 07-16-2009, 06:59 PM   #16 (permalink)
Auto-x newbie, still SS with rear panel eliminator or ASP ?
05 Elise, Storm Ti, Black Int, Hardtop, Starshield, LSS
Newhouse is offline   Reply With Quote
Old 07-16-2009, 07:47 PM   #17 (permalink)
Images: 761
Technically ASP
Old 07-16-2009, 07:58 PM   #18 (permalink)
Denuo Volatilis
...m...'s Avatar
...i don't know of any aftermarket exhaust which fits the stock diffuser cutout, not even the lotus stage 2, so unless i'm wrong you're effectively limited to stock exhaust in super stock, short of doing custom tips...
Old 07-16-2009, 08:05 PM   #19 (permalink)
the Quicksilver works with the stock diffuser and sounds great. Run what you brung and have fun.
We have evolved!! Two black marks now.
CrashTestDummy is offline   Reply With Quote
Old 07-16-2009, 08:05 PM   #20 (permalink)
Images: 761
I did with the Quicksilver from Sector (I dont think they carry that brand anymore) and then later with one from 2Bular....but the 2bular may have been a custom exhaust. But it certainly could be true now. Custom tips would not be too hard to do.
