Go Back   LotusTalk - The Lotus Cars Community > Motorsports > Solo timed events
Old 04-22-2009, 04:00 PM   #1 (permalink)
Supercharged is SSM Class
I'm fairly new to autocrossing and hoping get a bit more serious about it this season. In reading through the "2009 Solo Rules" classifications an '05 Elise with BWR SC will be in the SSM class.
Page 180 Says Turbo or Supercharged engines are classified on a basis of adding 1.4L to actual displacement.
Page 181 has the minimum Weight Calcs:
Minimum Weight Calculations:
All listed weights are without driver.
FWD: 1350lbs + 125 lbs/liter
RWD: 1600 lbs + 200 lbs/liter
AWD: 1600 lbs + 300 lbs/liter
Cars with engine located behind driver: +25 lbs/liter
My math says:
Engine capacity 1.8
Super Charger addition 1.4
Engine Capacity Basis 3.2
RWD WT Basis 1,600
225lb / liter * 3.2 Liters 720
Minimum Weight 2,320
Actual Weight 1,984
Ballast Required 336
Am I figuring that right? I think 336 lbs exceeds the max capacity of both the
trunk and passenger compartment once you add a driver.
- Todd
Current: 2005 Elise LRG - BWR SC
Gone, but not forgotten: '91 NSX, '95 Z3, '79 280ZX, '66 Mustang and others. Friends don't let friend's drive 4-doors.
tpearsall is offline   Reply With Quote
Old 04-22-2009, 04:03 PM   #2 (permalink)
Found more on Page 180:
Weight Adjustments
Cars running tires with a rated width of 275 mm or less on all four
wheels may compete at a minimum weight 200 lbs less than their
calculated weight.
Engine capacity 1.8
RWD WT Basis 1,600
Adjusted Min Wt 2,120 For tires < 275mm
Actual Weight 1,984
Ballast Required 136
136lbs seems more do-able. I'm a ways off from being competitive enough for this to matter, but want to make sure I'm understanding the classification.
- Todd
Old 04-22-2009, 05:24 PM   #3 (permalink)
Sean G's Avatar
Images: 6
Todd,
Yes, your calculations are correct. You could even save a pound by using the actual displacement of 1795cc. You'd need creative places for the ballast to use the weight distribution to your advantage when you plan on being competitive, but you could bold lead under the passenger seat in the meantime. Run a full tank of gas, use a heavy battery, keep a subwoofer in the car...
I think the car could be competitive in SSM with decent power, 255 or 275 at all corners, and the suspension/aero/bodywork allowances.
**SDG**
Sean G is offline   Reply With Quote
Old 04-23-2009, 02:46 PM   #4 (permalink)
What SCCA class does the Elise SC run in?
How about an 06 Elise with aftermarket SC and no other mods?
Bobby Smith is offline   Reply With Quote
Old 04-27-2009, 04:06 PM   #5 (permalink)
spaf's Avatar
All factory SC'd Elise/Exiges run in ASP (no weight rules in ASP). They're also legal in SSM subject to the weight rules which means that you'd have to add weight to make the min.
Non factory SC and you're in SSM.
spaf is offline   Reply With Quote
Old 08-29-2009, 07:25 PM   #6 (permalink)
FIL
Serial Thrilla
FIL's Avatar
Or XP if you'd rather subtract weight rather than add weight.
05' Elise - BWR supercharger, Quaife LSD, Nitron Race Triple Adjustable, LETSLA, Larini Decat, Larini Exhuast, ACT HDSS, Fidanza flywheel, V2 Fuel Tank, V2 Steering Arms, BWR sway bar, desnorkled, ForcedFed CF splitter, Manly's engine mounts, S111 harness bar, Schroth harness w/ S111 seat grommets, Oil Drain Valve, Painted Black Diffuser, Braille battery, Custom Battery Switch
05' Corvette - Z51 Convertible - 630hp 6.6L [DON'T YOU JUDGE ME!!!] (SOLD!)
FIL is offline   Reply With Quote
Old 09-02-2009, 08:22 AM   #7 (permalink)
Cone Magnet
CosmosMpower's Avatar
I would rather go to XP than deal with the Strielnicks FD RX-7.
06 Canyon Red Elise
LSS, Touring, SS, Stg 2, HID, BWR swaybar
09 Mini Cooper S 6MT
2000 Grand Prix White S2000
CosmosMpower is offline   Reply With Quote
