Go Back   LotusTalk - The Lotus Cars Community > Motorsports > Solo timed events
Old 10-05-2008, 07:52 PM   #1 (permalink)
Traction control is driving me crazy!!!
I keep forgetting to turn this fricken feature off. I have resorted to putting a post it note on my dash but this is annoying. I even tried leaving the car running as to not have to remember but it keeps coming back on. Does anyone else have this problem? What are you guys doing to keep from running with the t/c on all the time?
TIA
We have evolved!! Two black marks now.
CrashTestDummy is online now   Reply With Quote
Old 10-05-2008, 08:01 PM   #2 (permalink)
(Formerly PESTODUDE)
Illumiloti's Avatar
...then, when I'm on the track and I start my session with it turned off, the way my seat is positioned, the back of my knee inevitably bumps the TC button within one or two laps and kicks it back on! Does this happen to anybody else?
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune.
Illumiloti is offline   Reply With Quote
Old 10-05-2008, 08:11 PM   #3 (permalink)
WTF
climb4fun's Avatar
That's terrible. Is this happened only one time?
climb4fun is offline   Reply With Quote
Old 10-05-2008, 08:16 PM   #4 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
I have hit it with my knee and turned it on as well. not anymore wince the race seat went in though. knee cant touch the console.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is offline   Reply With Quote
Old 10-05-2008, 08:23 PM   #5 (permalink)
I have never had an issue with my knee hitting to my knowledge. I will see if it is possible tomorrow.
Old 10-05-2008, 08:39 PM   #6 (permalink)
No, it's only an N/A
RichS's Avatar
Why the concern?
I've only had traction control cut in on one corner on one track. I'm not sure any extra wheel spin would make me faster there.
It's not like it's very intrusive.
The factory drivers keep it on at the factory track because they are faster with it on. At least that's what I was told by the folks from the factory. (I believe them.)
Useful links to vendors removed at Nadeem's request.
"Nice avatar by the way, I doubt Colin Chapman would have followed the herd as I have seen many here do. --Nadeem"
RichS is offline   Reply With Quote
Old 10-05-2008, 08:46 PM   #7 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
I hated the TC, tight second gear corner it always got in the way and that was while NA. With the blower now its more annoying.
Old 10-05-2008, 08:53 PM   #8 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
TC is very intrusive during auto-x... as I'm coming up to the start, I quickly scan the dash... making sure that TC is disabled is one of the things I check. I've never had it reset to "on" unintentionally though...
Old 10-05-2008, 08:59 PM   #9 (permalink)
Images: 26
That button is in a bad spot. I turn mine off quite often with my leg when driving spiritedly. The first time I saw the light on the dash go on I thought, O-NO.
Green Ghost is offline   Reply With Quote
Old 10-05-2008, 10:25 PM   #10 (permalink)
rnr
daily driver
rnr's Avatar
Happens to me all the time. The simplest solutions is to tape a bottle top over the button after you turn the TC off. I believe Surferjer even had this method officially declared legal by the SCCA.
http://www.rahulnair.net/blog
rnr is offline   Reply With Quote
Old 10-06-2008, 05:11 AM   #11 (permalink)
TedDBere's Avatar
That I'd like to see...
Seems to me putting a bottle cap over the switch would be the same intent as pulling a fuse. You are doing something mechanical to prevent a factory system design from functioning. It doesn't seem to me that just because the factory design is poor (your knee hits the switch) you should be able to add something to the car (a bottle cap) to eliminate the poor design function in a stock class car. IMHO
This would be like being able to move the pedals because they are so close together your feet hit both the clutch and the brake at the same time.
But, if Jerry has the letter....
TED
TedDBere is offline   Reply With Quote
Old 10-06-2008, 07:10 AM   #12 (permalink)
Sports Cars
Vampyre's Avatar
Relocate the switch, it is just press fitted in.
Make a new hole on the front on the center console, right under the power door locks.
2006 Chili Red / Touring / LSD / TC / Forged Wheels / Hard & Soft Top / Lifestyle Paint / Desnorkeled / Odyssey Battery / Sector 111 Extinguisher Bracket / Sector 111 LidBone / CF Splitter / CF Bits / Lotus Stage 2 / Pure X
C3 Corvette 383 TPI Stroker 6.3 liters of Torque / 1976 MG Midget, fun run about / 2005 Mits Evo 8 ACD/SSL / Dodge Van for hauling stuff / http://www.photobucket.com/mygarage
Vampyre is offline   Reply With Quote
Old 10-06-2008, 07:26 AM   #13 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
Originally Posted by RichS View Post
Why the concern?
Ahhhhh... the Fish Hook.
My traction control setting has been dialed back a bit.
xtn
Old 10-06-2008, 08:18 AM   #14 (permalink)
rnr
daily driver
rnr's Avatar
Denver Pro Solo Thread (post #8)
Old 10-06-2008, 08:45 AM   #15 (permalink)
TedDBere's Avatar
Yes I see where Jerry said he got the OK from Bob Tunnell, but I still don't see a letter or a Fastrack ruling.
The letters that I've sent to SAC/SEB for clarification have always had the clarifications, or denials, printed in Fastrack. Without being printed in Fastrack, or the rulebook, it's up for interpretation and appeal if protested, and if it doesn't say you can, then you can't. IMHO
That being said, Elise owners do run at national events with the "bottle cap" fix, and have never been protested. That doesn't mean you won't be protested in the future.
I do know that Brian and Pat's car doesn't use the botttle cap fix. I'm not sure if Matthew's car had it or not, I certainly don't remember seeing it in impound at either the Pro Finale or Nationals. FWIW.
TED
Old 10-06-2008, 09:23 AM   #16 (permalink)
SS = Arms Race
TexasGT3's Avatar
Please...Vettes have all sorts of "special rules" in the book that let them do a lot more that prevent the traction control from being switched back on....It's obviously a safety rule anyway and/or comfort and convenience. ; )
Stuart F. Maxcy
08 S2000CR BLUE!!
AS 188
2006 Southwest Div. Champion (Porsche GT3)
2005 Southwest Div. Champion (ZO7 C4 Vette)
Super Stock....The closest an autocrosser can get to an Arms Race...
TexasGT3 is offline   Reply With Quote
Old 10-06-2008, 09:32 AM   #17 (permalink)
TedDBere's Avatar
Originally Posted by TexasGT3 View Post
Please...Vettes have all sorts of "special rules" in the book that let them do a lot more that prevent the traction control from being switched back on....It's obviously a safety rule anyway.
Stu, I have no idea what you're talking about...what special rules? lol
BTW, you may be in the right car if we move to Nebraska next year. Pray for concrete....
TED
Old 10-06-2008, 09:53 AM   #18 (permalink)
SS = Arms Race
TexasGT3's Avatar
The thought has crossed my mind! But then again many thoughts crossed my mind on the long road home from Kansas. It's not so much the concrete in Nebraska but the potential for huge/wide courses that I'm excited about!
Stuart F. Maxcy
08 S2000CR BLUE!!
AS 188
Old 10-06-2008, 10:21 AM   #19 (permalink)
I thought we were going to Arkansas?
I really do not see how someone can turn it off with their knee. I will check when I get home. Can it turn itself back on?
Old 10-06-2008, 10:31 AM   #20 (permalink)
rnr
daily driver
rnr's Avatar
Well I dont compete in SCCA so I really have no idea about the rules. I assumed that the ruling meant it was ok but I guess I was wrong.
