LotusTalk - The Lotus Cars Community - View Single Post - IMPROVED A/C & HEATING SYSTEM
post #34 of (permalink) Old 08-13-2009, 11:10 AM
skelliott2
skelliott2's Avatar
I just finished wrapping the flexible air hose. It is a tight fit, but you can detach the two screws from the wiper motor cover (black cover with the fuse box on it) to help with making room to get it back in once wrapped. While the cover will not come off due to a zip tie holding it on, it gives enough clearance to get the covered tube back in. I also think the covering of the tube will have the added benefit of acting as a further barrier to heat from the master cylinder and other brake parts on that side of the car.
Michael, can you tell me some of the specific additional areas that your insulated? While I have it cracked apart, I want to get it all done at once. You mentioned that the goal is to prevent heat soak in the evaporator enclosure, where is that located? Is it the part that the lower cabin air tube connects into?
Now I just need to experience the fruits of my labors!! Cooler air here I come!!
PS. - Thanks for the corrections Michael. I am an auto guy in driving mostly as was evident from my post!!
Last edited by skelliott2; 08-13-2009 at 11:48 AM. Reason: So I don't sound like a complete idiot!!
skelliott2 is offline
