LotusTalk - The Lotus Cars Community - View Single Post - DIY Blower Motor Resistor Pack Replacement
post #6 of (permalink) Old 09-12-2009, 05:51 AM Thread Starter
rob13572468
rob13572468's Avatar
This is the harness with the new wires from the blower motor run directly into the connector. You can disassemble the existing connector and cut the old wiring off of the connector pins and then solder new wires to them. The connector can then be reassembled. This shows the wiring ready for everything but with the resistors not attached. Also note that the fan can run without any resistors if you only care about full speed. (full speed mode connects the orange wire to the blower directly without any resistor)
rob13572468 is offline
