LotusTalk - The Lotus Cars Community - View Single Post - Windshield Washer HELP!
post #7 of (permalink) Old 12-21-2009, 09:03 AM
MulhollandMotors
MulhollandMotors's Avatar
Originally Posted by tesprit View Post
I'm guessing the hose and/or washer jets are plugged with sludge. Do you have access to some compressed air with a blow nozzle/gun? If you do, disconnect the hose at the washer pump and direct a couple of blasts of air backwards through the washer jets below the windshield. This should expel the crud and open up the hose and/or the jets again.
Edit: I took another look at the the parts diagram and it appears there are some anti-backflow valves in the hose so be careful not to blast the air too hard through the jets and it may be actually better to try the air blast from the pump end of the hose. Also probing the washer jets with a small sewing needle works well for opening up clogged jets.
+1. I've done this to several cars.
Mulholland Motorsports -Premium Collision Center specializing in Lotus service and performance upgrades.
8630 West Pico Blvd. Los Angeles, CA 90035
(310)360-0948
www.mulhollandmotorsports.com
MulhollandMotors is offline
