LotusTalk - The Lotus Cars Community - View Single Post - DIY Blower Motor Resistor Pack Replacement
post #24 of (permalink) Old 01-23-2010, 07:19 AM
tesprit
Moderator Extraordinaire!
tesprit's Avatar
Originally Posted by rob13572468 View Post
If you are going to tell people to crimp because its better then you should qualify that by letting them know that they need a proper crimper... Because if they go and get the $10 crimper from home depot you are doing them a disservice...
I am not going to argue the soldering point, but I am also never going to solder a wire connection on my airplane with the main reason for this being that type of repair is not FAA approved and would ground my plane. Also I do NOT recommend nor will I ever recommend someone buy one of those cheap $10 nutcracker type crimpers as you say I recommend. The tool I use and recommend is the ratcheting kind as shown in my posted links above. I have never had a crimped connection fail using this type of crimping tool, but as you have stated with your experiences YMMV.
tesprit is offline
