LotusTalk - The Lotus Cars Community - View Single Post - IMPROVED A/C & HEATING SYSTEM
post #51 of (permalink) Old 05-16-2010, 05:14 AM Thread Starter
SirLotus
SirLotus's Avatar
My first observation is that this product is simply gold colored, not gold which is efficient at reflecting heat, so how effective it would be I don't know.
Secondly, reflective material is only good for radiant heat, therefore not applicable to convected heat where surfaces are in contact with each other, for that you need insulation. Interestingly enough, the McLaren F1's engine bay is coated in an actual gold finish.
I do believe that the the sealing of the gaps is highly efficient at reducing heat soak, however I would also refer to the procedure as insulating.
In saying all that, the only way to prove or disprove it's effectiveness is by scientific comparison.
Cheers,
Originally Posted by a43656 View Post
I haven't had my Elise long enough to contribute much here, but went through a prolonged war against intake air temperatures (airbox, not cockpit) in a production-based race car, spending countless hours on track and $$$ at the dyno with data logging to make sure I wasn't BS-ing myself.
With some coaxing from a turbocharger engineer, one thing I learned is this ridiculously expensive gold stuff ...
Pegasus - Self Adhesive GOLD Reflective Heat Barrier Film
... is amazing at keeping the thing you want to keep cold from being affected by the thing that is emitting the heat. In my case, I ended up wrapping intake and cooling plumbing that was near radiators and exhaust, and I had dramatically better results doing this than using "heat wrap" on the exhaust and silver foil/fiberglass "insulation" tape on the intake plumbing.
Anyway, based on this background, I would be interested in whether Viper or anyone else thinks there are any strategic places where the high-$$$ gold stuff might be worth it in the Elise A/C mod application?
My first thought was the accordion duct shown in #3 of Viper's writeup, just because it is similar to the application I was testing.
I'm also wondering how much of the #1 and #2 gains are due to sealing of gaps versus the "insulation" (or reflectiveness?).
Any thoughts?
SirLotus is offline
