LotusTalk - The Lotus Cars Community - View Single Post - IMPROVED A/C & HEATING SYSTEM
post #83 of (permalink) Old 09-10-2010, 06:05 AM Thread Starter
SirLotus
SirLotus's Avatar
If you get reverse airflow through the footwell vents that bothers you when you have no need of either AC or heat then I would recommend blocking them up. By doing so, remember, you will have no effective heat because no air can be drawn into the system (unless there are air leaks), unless the nose intakes are unsealed. I get no reverse airflow through my system with everything off, I imagine because the nose intakes are blocked and the climate box has no leaks.. The objective of my mods was to make the AC work more efficiently.
Originally Posted by Dylan View Post
Thank you, Michael. What do you think about seasonally blocking/unblocking the front ducts, too? It's only duct tape.
SirLotus is offline
